Old 02-12-2014, 02:40 PM   #5641
haywood's Avatar
Trader Rating: 47 (100%+)
Originally Posted by DS Motorsport View Post
Let's start building:
Was only disappointed when I found out the single piece servomount isn't included in the kit. I had expected it to be part of the kit.
You gonna run Gd1 or Gd2?
/ Roche Rapida 2015-2016 / Hobbywing / Team Scream / Rc Painting By Mikey / Ko Propo / MMR / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 02-12-2014, 02:55 PM   #5642
geeunit1014's Avatar
Originally Posted by zaraz View Post
I am about to pull the trigger on the evo kit, just some questions, I know to get the metal gears for the diff, does the evo kit come with the floating servo mount, or do I need to order it seperatly, are all the shims included or do I need to buy those seperatly, and the battery holders, i saw some aluminum ones on their web site, does the car come with them or are they plastic, if so will the aluminum ones fit the evo kit, thanks
The floating servo mount is separate
The kit comes with shims
The aluminum battery mounts are separate, but I prefer the plastic ones, They are much easier to adjust
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 02-12-2014, 03:44 PM   #5643
Originally Posted by JayBee View Post
Also...have anyone of u made a complete list of bearings used on the AMX EVO + FFG? I wanna go ceramics on this bad boy
Oleg did you change suppliers for the EVO kit bearings? Gotta say from the first build of my EVO compared to my USA the bearings were much smoother and immediately the car was freer.
JB-- Ceramic, they will be nice no doubt but the latest batch of bearings I got in my EVO were super free right away.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 02-12-2014, 03:44 PM   #5644
DS Motorsport's Avatar
GD2, forgot to include it in the picture.
Just hope I can find a short, central stiffener so I can build the car with aluminium chassis.
Should be back in stock in time, first need two weeks to reverse-engineer the car into CAD.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 02-12-2014, 10:53 PM   #5645
josecarlo1129's Avatar
Originally Posted by markova View Post
Do You use ceramic or normal bearings? Are ceramic worth to buy for Awesomatix and if so, which Do You recommend?
I am using this set: Awesomatix A700 Ceramic Ball Bearing Kit by ACER Racing. Got it from ebay. Try it. The feel is now more fluid, making the awesome car more awesome. Cheers.
JC
Nitro: On-road 1/8: Motonica P81-RS2/Vox/Savox
Off-road 1/8: JQ TheCar/Vox/Savox
Electric: On-road 1/10 TC: Awesomatix A700 EVO/AE BD/Team Orion/Ko Propo
On-road 1/10 F1: 3Racing FGX + RC9394 Carbon Conversion AE BD/Team Orion/Ko Propo
josecarlo1129 is offline   Reply With Quote
Old 02-13-2014, 12:44 AM   #5646
hanulec's Avatar
Trader Rating: 23 (100%+)
Awesomatix USA will be building a ceramic kit from avid shortly. I ran ceramic in my drive line (not hubs) at birds...
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 02-13-2014, 03:18 AM   #5647
Does somebody have the A700 EVO manual in a pdf file ?
I don't success to find it on awe website.
Team Speedpassion driver
http://www.speedpassion.net/en/ourteam.asp
chrispys is offline   Reply With Quote
Old 02-13-2014, 06:20 AM   #5648
Styles's Avatar
Here are the manuals for an Evo assembly. The combination is the standard A700L + the FFG/Evo manuals together.
There are some steps that require you to be mechanically intuitive to switch between the 2 and may not be exactly clear when to do so. With that said, read through the A700L manual fully, maybe a couple times before you build.
-Attack this day with an enthusiasm unknown to mankind-
Styles is offline   Reply With Quote
Old 02-13-2014, 08:01 AM   #5649
Jerry P's Avatar
Trader Rating: 44 (100%+)
+1
Very important to understand the build.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 02-13-2014, 08:32 AM   #5650
Travis S's Avatar
Trader Rating: 46 (100%+)
Just wondering why a lot of the setups put the .5mm shims under all the arms vs running the lowest center of gravity possible?
Travis S is offline   Reply With Quote
Old 02-13-2014, 09:16 AM   #5651
erchn's Avatar
It's about controlling the roll center, not about center of gravity.
http://www.formula1-dictionary.net/roll_center.html
RCAmerica ; Team Powers USA ; Reflex Racing ; RC≥ RC Crew Chief ; Bezerk RC
erchn is offline   Reply With Quote
Old 02-13-2014, 05:29 PM   #5652
Dan Hamann's Avatar
Originally Posted by jason cheng View Post
guys get me a list of what i need to get it all tricked out link to stuff or part# like i said i haven't ran a touring car in 13 years
Jason, you buy and I'll build.
RCAmerica - Xray - Hudy - RC^2 - Motiv - Team EAM - Sanwa - Avid - Max.FX - Protoform - Pro-Line - Gravity R/C - Prolevel R/C - 2MM Designs
Dan Hamann is offline   Reply With Quote
Old 02-13-2014, 09:58 PM   #5653
jason cheng's Avatar
Trader Rating: 37 (100%+)
Its on the way i guess
jason cheng is offline   Reply With Quote
Old 02-14-2014, 07:38 AM   #5654
Csaari77's Avatar
Trader Rating: 34 (100%+)
What is the correct size turnbuckle wrench for the Lunsford titanium turnbuckles? I have the Lunsford wrench, but it's pretty worn out and I need to order some other tools today anyway.
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 02-14-2014, 10:16 AM   #5655
SavageCanadian's Avatar
Trader Rating: 58 (100%+)
Send a message via MSN to SavageCanadian
4mm
Colin Roussel
PRCC
2013/2014 WCICS CTA Champ
Awesomatix | Roche | Trinity/Revtech | SANWA | ORCA
SavageCanadian is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17189 Yesterday 03:25 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
