Old 01-13-2014, 10:19 PM   #5251
Styles's Avatar
Originally Posted by AARON YOUNG View Post
Yes I understand it needs to be cut down . I just wanted to point out for anybody doing it that it needs to be trimmed in the housing or at least shimmed and marked in the housing. You can either just use the housing as a guide and a real sharp exacto or score a line and remove it and cut and sand the ends.
Yes, having the pin tight in the housing is key for cross pin float and there isnt a tolerance to the 20.8 dim. I did measure the housing and 20.8 was good for me. Correct spider gear shimming also controls cross pin float as well. I agree marking in the housing and cutting and sanding would be super safe and a cleaner install. I should have taken more pics while working on it.
-Attack this day with an enthusiasm unknown to mankind-
Styles is offline   Reply With Quote
Old 01-14-2014, 05:03 AM   #5252
hanulec's Avatar
Trader Rating: 23 (100%+)
That is how I do it. You just take a bit off each end until it looks good. You want to make sure the diffs screw together nicely.
This past weekend I had issues build two diffs. The problem was the ST31 outdrive seating against the large shim and bearing w/in the diff. Once the o-rings got lubed better everything would fit well, but until then I couldn't get one of the outdrives into the hole.
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 01-14-2014, 07:15 AM   #5253
Jerry P's Avatar
Trader Rating: 44 (100%+)
Damn waiting on my new Evo kit and FFG upgrade... I cant wait.. Passing through customs quickly for the win!!!
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 01-14-2014, 08:00 AM   #5254
Travis S's Avatar
Trader Rating: 46 (100%+)
Has anyone tried to run the EVO kit on an EX chassis or is everyone running the L or the new aluminum chassis. If so what were your thoughts?
Travis S is offline   Reply With Quote
Old 01-14-2014, 08:26 AM   #5255
hanulec's Avatar
Do you mean an FFG on EXL?
That isn't a problem -- JD great video a few weeks ago was running on the EX chassis plate.
Old 01-14-2014, 08:27 AM   #5256
Travis S's Avatar
Yeah that is what I meant the FFG that is on the EVO.
Old 01-14-2014, 09:12 AM   #5257
Has anyone of you opened the damper.
I like to know how its looked inside.
eded1 is offline   Reply With Quote
Old 01-14-2014, 12:37 PM   #5258
haywood's Avatar
Trader Rating: 47 (100%+)
Default Gd1/Gd2
So I was told gd1 has issues and I should get gd2. Is gd2 ready to install minus filling with fluid or does gd2 need attention also? Thanks!
/ Roche Rapida 2015-2016 / Hobbywing / Team Scream / Rc Painting By Mikey / Ko Propo / MMR / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 01-14-2014, 01:01 PM   #5259
hanulec's Avatar
Two options--
Use the kit supplied gd1 and add g05st/g06st -- and never worry about it again (additionally perform outdrives upgrade)
Buy gd2 plus necessary gears/cross/shims from a 3rd party.
Old 01-14-2014, 02:27 PM   #5260
Styles's Avatar
As Mike said the GD1 is great with the metal gears (g05st/g06st). I just added the GD2 with ARC brand internals to mine for the rear and moved my GD1 with g05st/g06st to the front diff. I just posted pics of it yesterday on thread page 350.
Old 01-14-2014, 04:39 PM   #5261
haywood's Avatar
Default Gd1
Two options--
Thanks!
Old 01-14-2014, 05:26 PM   #5262
hanulec's Avatar
this thread has been really active. back orders are huge. phone is blowing up. emails is flowing.
2014... wow. what could happen next?
Old 01-14-2014, 07:53 PM   #5263
ApexRCProshop's Avatar
that is what happen when you have the best toys....
Apex RC Exclusive North & South American Pro-Spec Distributor
Share & Like Our Page:https://www.facebook.com/ApexRCProshop
ApexRCProshop is offline   Reply With Quote
Old 01-14-2014, 11:03 PM   #5264
josecarlo1129's Avatar
FFG is settling on well, very well, making the grip so awesome on asphalt. Cheers!
Nitro: On-road 1/8: Motonica P81-RS2/Vox/Savox
Off-road 1/8: JQ TheCar/Vox/Savox
Electric: On-road 1/10 TC: Awesomatix A700 EVO/AE BD/Team Orion/Ko Propo
On-road 1/10 F1: 3Racing FGX + RC9394 Carbon Conversion AE BD/Team Orion/Ko Propo
josecarlo1129 is offline   Reply With Quote
Old 01-14-2014, 11:03 PM   #5265
Douple post.
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
