Old 01-13-2014, 09:04 AM   #5236
So this is absolute torture. I have my FFG KIT, but no a700l to fit it 2! so stoked.
Awesomatix a700l+ffg when it arrives!!
Diggity*Designs Dc4 le #11
Schumacher Mi5
2 Schumacher Mi4 cxl*Schumacher Mi1*HPI Savage XS*Schumacher MENACE 21 Schumacher fusion 21
Captain go slow is offline   Reply With Quote
Old 01-13-2014, 09:44 AM   #5237
Trader Rating: 22 (100%+)
Default Setup Question
I have noticed the car turns so much quicker and carries more corner speed compared to my Xray, but I am struggling coming out of the corner... As I am exiting the corner the car doesn’t want to straighten out (oversteer on exit), what would be the first thing you would look at changing?
Also, on the EVO... What tape do you use on the front bulkhead? I really don’t have any ‘low friction’ tape… I have some battery tape I could use or can order the right stuff. The Manual mentioned some, but I have never seen that.
Lastly, how free should the FFG feel up front and how should it 'rest'? I can move it by hand but it doesn't just rotate back to the 'middle' on its own... it just sits where i put it. I lightly sanded the carbon tube on the ends and it slides in the peices ok, but i wouldnt say the FFG is freely moving at all? Is that the correct way for it to be?
Justin
gocoogs is offline   Reply With Quote
Old 01-13-2014, 10:00 AM   #5238
Default Front Camber Links
I noted this spot on the set up sheet for the EVO with blue circles and the picture I have attached I have marked with Red Stars... is this the correct corresponding spot? The diagrams I have seen in the past don't seem to make much sense to me...
thanks
Justin
Old 01-13-2014, 10:03 AM   #5239
JayBee's Avatar
Trader Rating: 31 (100%+)
From looking and talking to a local racers' EVO, no...the ffg should return to center. Something is bound up there.
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-13-2014, 10:19 AM   #5240
Step 14 of the FFG Instruction Manual: 3M 810 Magic Tape.
Available in the departments of stationery/office products of supermarkets.
http://www.hyatts.com/art/3m-810-mag...x-36yds-R13045
Oleg Babich is online now   Reply With Quote
Old 01-13-2014, 10:31 AM   #5241
!Mad Max!'s Avatar
Send a message via ICQ to !Mad Max! Send a message via Skype™ to !Mad Max!
thanks
Justin
Attachment 1154407
Attachment 1154408
Hi gocoogs,
yeah your Blue dots on the Setup sheet are the position with the Red stars on my FFG Bulkhead !
But you will also have the same "Upper link arm length" if you use the holes which marked Red in the Setup Sheet screen shot.
The advantage of this is that you do not need to unscrew the AM42 and AM54 top link holders.
See for this Post #5188 from Oleg!
Best Regards Max
Best Regards Max Mächler
Team Manager Awesomatix Europe
Sponsored by: Awesomatix / LRP / LEESPEED / PROTOform / Wild Turbo Fan / MMP / APaint / MPE Stickers
!Mad Max! is offline   Reply With Quote
Old 01-13-2014, 11:40 AM   #5242
bozzplayer's Avatar
Trader Rating: 16 (100%+)
Hi everyone, was looking at getting the new A700 evo, this would be my 2nd attempt at owning this car after having the original car for 2 weeks when it 1st launched back when. So I'm hearing a lot of positve things about the car from when i was following it about 2yrs ago, my first question is what spares should i look at getting for the new A700 evo, i run on low/medium traction carpet in 17.5 stock, also i go to some of out of town races where the track is high traction, any help would be appreciated.
bozzplayer is offline   Reply With Quote
Old 01-13-2014, 12:05 PM   #5243
bkspeedo's Avatar
Check out Hanulec's racerlog. Here's a list of parts to buy right away and in the future.
http://racerlog.com/wiki/Awesomatix_...2F_Consumables
I would also recommend the metal gears for the rear gear diff if your not getting a GD2 gear diff and the AM24 floating servo mount.
For some reason Kyle and I have been breaking SPR02's lately, really the only thing we've broke on this car in the last few months and we run a lot of laps per week 1500+, so i would have at least one extra pack on hand.
Also buy an extra hard front bumper, either make one from a Parma block or buy Mike's precut for the car.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ ProtoForm ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 01-13-2014, 12:07 PM   #5244
In one year of racing with the car, the only spare parts i needed were:
One set of springs (S or Std)
4x SPR02
Diff gears. I'd go for the steel ones
Awesomatix | LRP
Awesoman is offline   Reply With Quote
Old 01-13-2014, 01:27 PM   #5245
Bittydesign's Avatar
Justin
The Bodyshell!
www.bittydesign.net | info@bittydesign.net
Follow us! >>> www.facebook.com/Bittydesign
Share our photos! >>> www.instagram.com/Bittydesign
Watch us! >>> www.youtube.com/Bittydesign
Bittydesign is offline   Reply With Quote
Old 01-13-2014, 05:25 PM   #5246
Styles's Avatar
I just received all my parts and built my GD2 with ARC internals thanks to Kody's part numbers post a while back. FYI for those that didn't see it before you ask why I used ARC parts - the Xray parts are sold out or hard to find all 3 part numbers in stock.
Everything went together as the assembly drawing shows and is pretty smooth.
Trimmed cross down to 20.8.
After a dry assembly checking backlash I used 2 shims (ARC# R103023) behind the spider gears.
Filled it with oil, bled through the out drive and its pretty smooth.
Ill let you know how it runs after this weekend.
-Attack this day with an enthusiasm unknown to mankind-
Styles is offline   Reply With Quote
Old 01-13-2014, 09:50 PM   #5247
Trader Rating: 15 (100%+)
Default Gd2
Would it be easier to shim the cross piece and install it so its centered in the tangs then trim so it's equal each way?.
AARON YOUNG is offline   Reply With Quote
Old 01-13-2014, 09:54 PM   #5248
JayBee's Avatar
He prolly did that Aaron, just didn't mention that step.
Old 01-13-2014, 10:02 PM   #5249
Styles's Avatar
Aaron-
The ARC (and Xray) cross stock are too long for the GD2 housing. You have to trim the cross to get it to fit. The 20.8 dim is from the assembly instructions. My point in showing it was to show that it too needed to be cut down like you would if you used the Xray part.
Old 01-13-2014, 10:13 PM   #5250
Default Cross piece
Yes I understand it needs to be cut down . I just wanted to point out for anybody doing it that it needs to be trimmed in the housing or at least shimmed and marked in the housing. You can either just use the housing as a guide and a real sharp exacto or score a line and remove it and cut and sand the ends.
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
