Old 01-10-2014, 08:21 AM   #5191
Trader Rating: 22 (100%+)
thanks for the response... so 2 years later and still the same issues are happening in a brand new kit (EVO), but yet it was never addressed by modifying the parts so they work well out of the box? ...They have come out with a couple new versions of the car since then? that is strange to me, but I guess it is what it is...
gocoogs is offline   Reply With Quote
Old 01-10-2014, 08:23 AM   #5192
erchn's Avatar
I've not actually seen it as loose as you mention, so something might be amiss. My diff worked fine out of the box, but the modification made it more durable for modified racing.
RCAmerica ; Team Powers USA ; Reflex Racing ; RC≥ RC Crew Chief ; Bezerk RC
erchn is offline   Reply With Quote
Old 01-10-2014, 08:42 AM   #5193
KHoff7's Avatar
If you overfill the diff it will push the outdrives outwards and that will cause it to lock up. This happens even with the metal Awesomatix gears. Either remove some oil or wait a run or two for it to seep out and then the problem will go away.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 01-10-2014, 09:01 AM   #5194
ok, that makes some sense... I will definitely say that the "fill line" is ambiguous, so that definitely could be the issue on my end! again, i am used the xray instructions where it gives you a weight the diff should weigh pre-oil and post-oil... so i could always get the exact amount of oil in the diff! thanks again for the advice... im going to eventually get there with the car
Old 01-10-2014, 09:07 AM   #5195
Quantra's Avatar
I like to weigh my diffs too. When I built the diff I put it on the scales to check how much oil I put in. I found the following to be good (weights are of the big half only):
Empty weight: 6.91g
Full weight: 7.63g
Weight of oil: 0.72g
It's not a large mass so accurate scales help.
Vince Coleman
Quantra is offline   Reply With Quote
Old 01-10-2014, 09:12 AM   #5196
awesome, thats perfect! i have a hudy scale so that should be accurate enough to match your weights!
Old 01-10-2014, 10:01 AM   #5197
hanulec's Avatar
Trader Rating: 23 (100%+)
(Likely) The "big" gear(s) in the diff are shot. I think your toothpaste polish method + not enough shims caused this.
Gd2 doesn't have the issue when built with the noted xray parts. Unknown about vbc internals.
Mike
So I have two of the GD1s built exactly to the manual specifications. If I hold them with gear side down and when I turn the out-drive, the other side doesn't move. However if i push the out-drive into the diff, it moves fine (although slightly notchy). Both of my diffs are exactly the same... and i have built and rebuilt them 3 times. Granted, I know I am new to this car, but the only think i can think is there needs to be some shims added somewhere, but it isn't noted anywhere in the manual that it needs to be done. I saw a few posts on Petit that talked about grinding down a small part .15mm and adding .1 shims in there, but it really baffles me that would be necessary given how precise everything else is on this car?
Anyone else experience this with the Diff? is that why they came out with a GD2?
Thanks,
Justin
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 01-10-2014, 12:21 PM   #5198
G-rem's Avatar
Will try VBC internals in GD2 very soon, I'll report it to you
G-rem is offline   Reply With Quote
Old 01-10-2014, 12:39 PM   #5199
John.C's Avatar
Trader Rating: 36 (100%+)
Originally Posted by Jerry P View Post
I live in the NYC area and i race on Saturday's in Horsham PA (about 1.5 hours from nyc) and on sunday's i run at Crispy critters in NJ (about 40 minutes from NYC). A few of the Awesomatix guys (me included) will be going to snowbirds in FL at the end of month.
Oh snap! S. Chocolate and Jerry at the same event for a whole week.
Please sound out if your going to the 2014 Snowbirds. Right now I'm aware of the following folks attend (along w/ myself).
Karl Hoffmesiter
Jerry Perez
Monti "The Mangler"
Brian Wynn
Larry Fairtrace
Roberto Falcon
John Choi
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 01-10-2014, 03:28 PM   #5200
Viljami Kutvonen A700 Evo car at 2014 DHI Cup.
http://www.myrcm.ch/myrcm/main?dId[E]=13851
http://events.redrc.net/
Oleg Babich is offline   Reply With Quote
Old 01-10-2014, 03:50 PM   #5201
bhambrent's Avatar
On the A700 EVO U.S. Spec kit I know you need to buy the AM24. but does it come with the AM19's,ST21S and 1 1/8 turnbuckle's?
Half-A$$ Racing - Cooperhobbies.com - Hot Bodies D413 - OneLug Hobbies - Awesomatix - Thunder RC Raceway - SpeedKingz Racing "G SERIES"
bhambrent is offline   Reply With Quote
Old 01-10-2014, 05:05 PM   #5202
hanulec's Avatar
A700 Evo doesn't require am24, nor does it include the am24.
USA Spec just replaces am06 parts with am06s.
All other parts are options
Old 01-10-2014, 06:33 PM   #5203
hanulec's Avatar
Hi Oleg-
Is Viljami running AM06S in front, and AM06 in rear? Or are those AM06 cut down (or w/o anodizing)?
Old 01-10-2014, 07:33 PM   #5204
BardSmith's Avatar
Trader Rating: 58 (98%+)
Hey all and perhaps Mr. H., question... is your shop.awesomatixusa.com about the only US source for Awesomatix parts? Where else can I get parts? I would like to get a new A700L chassis and I see it's out of stock there.
Brad "Bard" Smith
Destiny, Xenon-USA, Genesis, MMR, On-Road Only!
BardSmith is offline   Reply With Quote
Old 01-10-2014, 07:42 PM   #5205
haywood's Avatar
Trader Rating: 47 (100%+)
Check one of his dealers as they may have one. I noticed the place in Hawaii had most the kits in stock!
/ Roche Rapida 2015-2016 / Hobbywing / Team Scream / Rc Painting By Mikey / Ko Propo / MMR / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
