Old 12-16-2013, 09:38 AM   #5011
Bert never sells his cars, not even the Radioshack ones !!!...lol... Whatever Car you ran before, you'll be faster with the Awesomatix....OK.....
bertrandsv87 is offline   Reply With Quote
Old 12-17-2013, 10:18 PM   #5012
SavageCanadian's Avatar
Trader Rating: 58 (100%+)
Send a message via MSN to SavageCanadian
So I finally got to run my EXL last weekend and with the Fairtrace setup it was ok, change the front to 6 castor and -2 camber and it was better. BUt im still lacking the steering and response that im looking for, any tips? Car was running on jacos since my sorex were blown out and junk.
Colin Roussel
PRCC
2013/2014 WCICS CTA Champ
Awesomatix | Roche | Trinity/Revtech | SANWA | ORCA
SavageCanadian is offline   Reply With Quote
Old 12-18-2013, 04:51 AM   #5013
hanulec's Avatar
Trader Rating: 23 (100%+)
Does the car have enough physical throw in your outside front wheel? You need to be able to produce 17 degrees. I've seen "steering" issues be build issues before.
And to confirm -- your running am19?
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-18-2013, 10:48 AM   #5014
Trust me, listen to him and check this. Hanulec's hands changed my life.....
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 12-18-2013, 01:03 PM   #5015
JayBee's Avatar
Trader Rating: 31 (100%+)
Ewww!!
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 12-18-2013, 01:11 PM   #5016
Cool
Wow guys..... Keep the XXX action for the Horsham thread...lol... Use better language please, if you can !!!
Old 12-18-2013, 01:37 PM   #5017
oeoeo327's Avatar
Trader Rating: 70 (100%+)
Wish I checked this before chasing what felt like a tweak issue. Sure enough, the right front didn't produce 17 degrees (more like 15 in my case). I will always check steering throw before hitting the track from here forward.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
✯Jackson RC✯Horsham RC✯SJCCR✯
oeoeo327 is offline   Reply With Quote
Old 12-18-2013, 01:59 PM   #5018
hanulec's Avatar
Lol. If only you were a hot woman and said this..
It's more like the beating I've taken from Larry drove me to not take the small things for granted. If your car is the same/perfect every time it hits the track you'll be better off. That is where caster doodles can play a big part.
Old 12-18-2013, 02:10 PM   #5019
JayBee's Avatar
It's always the small things...
I love my caster doodles, a 'must have' for this car IMHO.
Old 12-18-2013, 02:19 PM   #5020
oeoeo327's Avatar
+1 - too much setup-related guesswork involved without them...
Old 12-18-2013, 04:01 PM   #5021
Yes im running the am19 front and rear, car gets 15 on one side and 16 on the other, dualrates are maxed. how do I get more?
Colin Roussel
PRCC
Old 12-18-2013, 04:25 PM   #5022
hanulec's Avatar
Your attachment point on the servo must be vertically higher.
If the link rubs on the top deck just lower the shim # on the steering rack.
My cars get 18 to 19 degrees on each side at full throw/full dual rate. I generally race with 17 degrees (70-80% dual rate)
Old 12-18-2013, 04:26 PM   #5023
I have a xray servo saver on the car and i cant go any higher on it or lower on the other end or is rubs the top deck and the center shaft, should i be running a different saver or just a servo horn?
Colin Roussel
PRCC
Old 12-18-2013, 04:45 PM   #5024
hanulec's Avatar
I run the "pointy" new xray servo saver but use the top hold to the outside of the car. Ie off center in the saver but at a 90 degree angle.
Old 12-18-2013, 05:26 PM   #5025
Thats the same way im running it
Colin Roussel
PRCC
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 Today 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
