Old 12-06-2013, 12:12 PM   #4936
SavageCanadian's Avatar
Trader Rating: 58 (100%+)
Send a message via MSN to SavageCanadian
I put Larry Fairtraces halloween classic setup on the car, the entire setup and yes the car has the at21s installed.
Colin Roussel
PRCC
2013/2014 WCICS CTA Champ
Awesomatix | Roche | Trinity/Revtech | SANWA | ORCA
SavageCanadian is offline   Reply With Quote
Old 12-06-2013, 12:48 PM   #4937
Luppi Stefano's Avatar
Originally Posted by Oleg Babich View Post
The ball diameter is 4,98-4,99 mm.
Perfect!
thanks!
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 12-06-2013, 04:50 PM   #4938
geeunit1014's Avatar
Originally Posted by SavageCanadian View Post
Did that exact method, but when i measure it out after, it says there is 4mm up travel over the ride height in the rear and over 6mm in the front. That doesnt seem right to me at all.
Hes not measuring travel over ride height, its the height of the arm from the setup board with the car sitting flat on the board (no tires)
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 12-06-2013, 04:52 PM   #4939
Travis S's Avatar
Trader Rating: 46 (100%+)
He is saying he did the board method, but after he checked the ORH measurement and that was 4mm and 6mm. That does seem very high vs the 2mm standard range most run for droop.
Travis S is offline   Reply With Quote
Old 12-06-2013, 05:02 PM   #4940
EXACTLY!!!
Colin Roussel
PRCC
Old 12-06-2013, 05:04 PM   #4941
Ah.. Thats why I always just measure travel over ride height, less confusion.. larrys settings should equate to something like 1.5mm over in the front and 2mm over in the rear. Maybe 2/2.5.
Mike Gee
Old 12-06-2013, 05:10 PM   #4942
hanulec's Avatar
Trader Rating: 23 (100%+)
i don't have a car setup that way right now to measure over ride height. i've been working on some new setups. i'll see Larry tomorrow @ Horsham --- i can remeasure then if he doesn't respond before then...
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-06-2013, 05:10 PM   #4943
Ok thanks, I usually measure it after as well, but since this cars screws are on the underside its not as easy as say my T4'14
Colin Roussel
PRCC
Old 12-06-2013, 05:21 PM   #4944
Travis S's Avatar
The tire diameter used will effect this. So if you are not running the same tires as the setup this method wouldn't work. If a tire is taller when setting ride height the arms would be angled up more. So when you set your droop using this method it would be much more then if you used a smaller diameter tire.
For example USVTA tires are much taller then USGT tires and USGT tires are taller then lets say Sweeps. Not all stock brand rubber tires are going to measure out the same either I am sure.
Old 12-06-2013, 05:47 PM   #4945
2mm over ride height is always 2mm over ride height.. 5mm on blocks or larrys method will give different over hide height values for different tires, # of shims under the arms, etc
Mike Gee
Old 12-06-2013, 05:52 PM   #4946
I have the same Sorex tires on my car if that helps
Colin Roussel
PRCC
Old 12-06-2013, 07:52 PM   #4947
I cant even get my car close to 2mm orh, I dont know what im doing wrong but obviously a lot.
Colin Roussel
PRCC
Old 12-06-2013, 08:02 PM   #4948
JayBee's Avatar
Trader Rating: 31 (100%+)
Its really hard to diagnose problems of this sort without the car in my hands....
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 12-06-2013, 08:22 PM   #4949
I got it down to the proper droop settings, the downstop screws are stick out about 3.5mm from the chassis, does that sound normal?
Colin Roussel
PRCC
Old 12-06-2013, 08:28 PM   #4950
Magnet Top's Avatar
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10911 11-28-2016 07:09 AM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
