Old 12-04-2013, 06:01 PM   #4921
hanulec's Avatar
Trader Rating: 23 (100%+)
Originally Posted by Monti View Post
Travis the ring gear is just glued and press fit together, my suggestion is use two sockets that can push on either side of the spool towards one another to create I vise effect. Not sure how to protect the teeth on the gear but I am sure you can get it done.
Monti
i think a vice would do a good job too..
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-04-2013, 06:46 PM   #4922
moparSRT's Avatar
Originally Posted by Jerry P View Post
Build an A700L and the amain could be in your future. just ask Ron Burgundy about his local vta run.
it's beyond my budget
will get a FT TC4 ready like every year and have FUN yeah its shaft drive too
2014 IFMAR Warm-Up Pics >>> www.rcactionpics.com <<<
Check it out >>> www.RaceVTA.com <<<
moparSRT is offline   Reply With Quote
Old 12-05-2013, 07:10 AM   #4923
Travis S's Avatar
Trader Rating: 46 (100%+)
Going to try out my EXL in VTA this weekend. With Awesom-o behind the wheel, I am expecting good things.
Travis S is offline   Reply With Quote
Old 12-05-2013, 03:45 PM   #4924
Luppi Stefano's Avatar
Hi all, I have a question
Who can measure the diameter of ST03?
thanks
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 12-05-2013, 03:45 PM   #4925
Lab F1-01
Old 12-05-2013, 11:03 PM   #4926
thanks
The ball diameter is 4,98-4,99 mm.
Oleg Babich is offline   Reply With Quote
Old 12-05-2013, 11:05 PM   #4927
erchn's Avatar
Any way you could be a little more exact? ;-)
RCAmerica ; Team Powers USA ; Reflex Racing ; RC≥ RC Crew Chief ; Bezerk RC
erchn is offline   Reply With Quote
Old 12-05-2013, 11:17 PM   #4928
Stefano doesn't informed "how more exact" number he wants.
At any case I don't have more than Mitutoyo 0,01mm calipers in hands right now.
Old 12-05-2013, 11:19 PM   #4929
erchn's Avatar
I suppose that'll do then. LOL
Old 12-06-2013, 11:32 AM   #4930
SavageCanadian's Avatar
Trader Rating: 58 (100%+)
Send a message via MSN to SavageCanadian
Hey guys, I picked up a EXL and cant wait to get it on the track!! Just a question, on the setup im putting on the car, the downstop says 6.2mm and 5mm, with a ride height of 5.5 all the way around. What is this measurement measured from? I cant for the life of me seem to figure it out.
Colin Roussel
PRCC
2013/2014 WCICS CTA Champ
Awesomatix | Roche | Trinity/Revtech | SANWA | ORCA
SavageCanadian is offline   Reply With Quote
Old 12-06-2013, 11:39 AM   #4931
If it is one of Mikes latest setups he measured with the car still attached to the setup station. There are a few different ways people measure droop. This being one of them, I'm sure Mike can elaborate more once he sees your post.
HawaiiBob is offline   Reply With Quote
Old 12-06-2013, 11:41 AM   #4932
Travis S's Avatar
Originally Posted by hanulec View Post
We are measuring droop using a ride height gauge with chassis on flatboard.
Measuring droop from the "outside" of the two little screws connecting the p04 to c04.
Using the rh gauge from the center of the car to the ends.
PLEASE NOTE -- for this method to work your chassis must sit flat on your flatboard. you'll need to trim the excess plastic from the P06.
I think this is the info you are looking for.
Old 12-06-2013, 11:47 AM   #4933
Did that exact method, but when i measure it out after, it says there is 4mm up travel over the ride height in the rear and over 6mm in the front. That doesnt seem right to me at all.
Colin Roussel
PRCC
Old 12-06-2013, 11:58 AM   #4934
I measure droop with the car flat on a setup board. I run the guage along the inside of the 2 button head screws at the end of the arms. I usually set the front to 4.5mm and rear to 4.8mm. I don't know how that translates to orh. Since I started using this method the car has been a beast on the track. So..... I think I will stick with it.... for now. Maybe this weekend I will check to see what the orh measurement is with this method.
Old 12-06-2013, 12:05 PM   #4935
hanulec's Avatar
Is the entire setup applied? These droop measurements don't work if you don't have the at21s
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
