Old 11-19-2013, 06:33 PM   #4801
OVA
OVA's Avatar
Trader Rating: 67 (100%+)
Hey Mike
Thank you to you for the Awesome Awesomatix USA T shirt you got for us....
wait until you hear the good news from Jake..
OVA is offline   Reply With Quote
Old 11-19-2013, 08:10 PM   #4802
Updated P06-1 downstop collars are available.
http://shop.awesomatix.com/index.php?productID=962
You should to remove some material from the available holes on your chassis according to the pictures. I use the thin round needle file for this.
This modification doesn't require the precise tolerance actually.
Oleg Babich is offline   Reply With Quote
Old 11-20-2013, 06:10 AM   #4803
SVARZEL's Avatar
Thumbs up
Fantastic!!!
SVARZEL is offline   Reply With Quote
Old 11-20-2013, 07:33 AM   #4804
Csaari77's Avatar
Trader Rating: 34 (100%+)
Is there an ETA for the new collars to be available from Awesomatix USA? I've got a kit on the way and I'm debating on if I should build it with these or the old collars that need to be glued in.
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 11-20-2013, 03:15 PM   #4805
Styles's Avatar
Why do I see that hardly anyone runs their covers over the diffs?
Tech reason? Just cause reason? For show?
-Attack this day with an enthusiasm unknown to mankind-
Styles is offline   Reply With Quote
Old 11-20-2013, 03:19 PM   #4806
Travis S's Avatar
Trader Rating: 46 (100%+)
It's all show, no go! The diffs and spool look 2 good to cover up! Most people seem to run without them indoors but use them outside.
I ran mine with diff covers indoors the first time this past week and I am happy I did. A part of the track was used that normally wasn't so my car was a fuzzy mess after each round and I wouldn't want that stuff in there.
Travis S is offline   Reply With Quote
Old 11-21-2013, 10:59 AM   #4807
hanulec's Avatar
Trader Rating: 23 (100%+)
Should be in the next 1-2 weeks..
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 11-21-2013, 11:42 AM   #4808
hana166's Avatar
Default diff
Built the new diff today..was a little tight, needed to sand the backs of the Xray sun gears a bit to free the mesh a bit..seems perfect now. I went slowly with it in small increments. I deburred the planet gears (not sure it was necessary). Here is a pic to show how far I went with the sanding (shown by grey areas) in case anyone else experiences the same. Started at 4.38mm ended at 4.28.
Its great to have that smoothness under load of the Xray diff now available in the Awesomatix. I've long felt Xray have the best diff. Maybe the NT1 metal gears will fit too.
hana166 is offline   Reply With Quote
Old 11-21-2013, 12:57 PM   #4809
Quantra's Avatar
I'll be trying the xray graphite gears in mine. p/n 304931
Vince Coleman
Quantra is offline   Reply With Quote
Old 11-21-2013, 02:28 PM   #4810
JayBee's Avatar
Trader Rating: 31 (100%+)
Just waiting for mine to ship. Can't wait to try it out.
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 11-21-2013, 02:39 PM   #4811
Where is the best place to order a kit? Always have had xray. This kit very much more complicated to build? What spare parts most needed? Will be running this car in Omaha large track. Same as iic . Same carpet same. Same layout.
Huskerfan1212 is offline   Reply With Quote
Old 11-21-2013, 02:55 PM   #4812
bkspeedo's Avatar
Awesomatix USA
http://shop.awesomatixusa.com/
There's a good size group of CO drivers that will be hitting Carpet Nats next year. We're also planning a pre-race weekend around the beginning of Feb, nothing official yet.
PM me if you need any help build your kit or with setup. What classes do you currently race?
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ ProtoForm ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 11-21-2013, 03:08 PM   #4813
Adam B's Avatar
The kit builds very nice. My ONLY complaint about the build was that you tend to have to dig through part bags sometimes to find something. I think the only thing that is a must to buy is the collars for the front DCJ/ECS shafts as far as parts to have ASAP. I haven't tried to break anything yet, but where I raced it the last couple times was pretty ugly and nothing broke. I did buy the plates to allow for shorter camber links, and ordered misc parts bundles just for spares. I also upgraded all the tie rods to lunsford ones. Assuming you run a fan on your previous car that was taped or glued to the chassis, you will need a fan mount of some type. R1 Wurks makes a nice one (if you can find one in stock), but I am using 2 of the orca ones posted a page or 2 go. You will need a spur gear also, the kit does not include one, and i highly recommend a servo saver, as the kit says to use a servo horn only.
Good luck, and I am sure you will enjoy the kit!!
Franchise Racing Products * Fantom Racing * Pro One R/C Tires * RC America/Xray * Discount R/C Store * F1 R/C Lab * NORCAR @ The Gate
Adam B is offline   Reply With Quote
Old 11-21-2013, 03:51 PM   #4814
It may just be my driving skill but I hope I can find a few tenths with new car.
Old 11-21-2013, 08:16 PM   #4815
Please check the length of your cross pin.
It should be short enough ( ~10,4 x 2 = ~20,8mm) for free movement in the slots after screwing of the diff's cases. This is very important!
All our test diffs are smooth without any sanding of the original gears ( ~ 4.35mm thickness). Our big washers are 0,3mm and small washers are 0,2mm in thickness.
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
SEO by vBSEO 3.5.0
