Old 11-17-2013, 10:10 PM   #4786
Adam B,
3) my spur gear came loose today! Again, something that should just be checked often, or did I not do something proper? On my way home I was wondering it it had to do with my use of push brakes today.
Please sand ( with rough sandpaper) the contact face of AT12 nut. It will increase the friction between the spur and this nut significantly.
AT12M optional nut is available also for all who doesn't like to apply more force to the wrench.
4) after a not minor contact with another car, my drive shaft came out. Is this normal also?
Please check your SPR06 wire ring. I think that you have unclenched it too much at installation. Squeeze it to the original size and try to install more carefully again.
Oleg Babich is offline   Reply With Quote
Old 11-17-2013, 11:19 PM   #4787
bkspeedo's Avatar
Originally Posted by Adam B View Post
1) there seems to be a bit of slop between the ball studs and ball cups. Is this normal or anything of concern?
There ball cups this happens over time. Instead of replacing them cut small squares and plastic bag, place between the ball and cup when snapping together, remove the excess. The plastic will take up the slop in ball cup. If the link feels to stiff, remove, find a thinner plastic material, and repeat
2) I noticed one rear ball stud likes to back out. Being this kit is a lot of metal into metal, is it good to use blue loctite, or just keep double checking them?
Don't get to crazy with loctite it will make the car hard to work on when trying setup changes
Great suggestion by Oleg, i'll give this one a try, i've had the same problem on my mod car.
Another idea and what I've done on my cars. Cut a small piece of soft foam and place in the hole on the spear gear side where the drive shaft mounts. This will act as a spring against the drive shaft which helps it from being knocked out of the front.
I really enjoy this car so far. So many others have inquired about it and probably placing orders since I got one.
Answers above
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ ProtoForm ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 11-18-2013, 04:08 AM   #4788
hana166's Avatar
A while back I modded the battery holder to make fore and aft changes easier. Once the grub is set for the battery width you're good to go. Used a small body reamer to make the hole. Easy. Only takes a moment now to change position and no more worries about keeping the balance
hana166 is offline   Reply With Quote
Old 11-18-2013, 05:51 AM   #4789
Adam B's Avatar
I guess I should have made it clear that this was only my second race day with the car. That's why I was asking about the ball cup thing. Thanks for the tips guys, I will be going over all that this week.
Franchise Racing Products * Fantom Racing * Pro One R/C Tires * RC America/Xray * Discount R/C Store * F1 R/C Lab * NORCAR @ The Gate
Adam B is offline   Reply With Quote
Old 11-18-2013, 04:55 PM   #4790
Bigz84's Avatar
Trader Rating: 15 (100%+)
Default wtf fans
Thanks for the fast shipping Mike, I got the fans today. thank you.
Radiopost : EA Motorsports : Speedzone : Orca : Waldorf RC : Reflex Racing/RSD : Wild Turbo Fans : Franchise Racing Products : RCAmerica : Hudy : Xray : Diggity Designs: Pro One Racing
Bigz84 is offline   Reply With Quote
Old 11-18-2013, 10:24 PM   #4791
bhambrent's Avatar
Will the RDS T4 bumper fit A700EXL?
Half-A$$ Racing - Cooperhobbies.com - Hot Bodies D413 - OneLug Hobbies - Awesomatix - Thunder RC Raceway - SpeedKingz Racing "G SERIES"
bhambrent is offline   Reply With Quote
Old 11-19-2013, 04:52 AM   #4792
Trader Rating: 30 (100%+)
There is a bumper specific for the awesomatix.
http://shop.awesomatixusa.com/access...am-bumper.html
Monti
Monti is offline   Reply With Quote
Old 11-19-2013, 10:39 AM   #4793
Travis S's Avatar
Trader Rating: 46 (100%+)
Oleg - Just wondering why you didn't add a way to put a C clip (something like what holds the carbon arms in place) on top of ball studs under the rims to help prevent the top one from popping off vs the zip tie method some people are using.
Travis S is offline   Reply With Quote
Old 11-19-2013, 03:01 PM   #4794
Styles's Avatar
In looking at the manual ( car will be here in a couple days ) is the spur just clamped with the 12mm nut and not retained radially with any other holes?
Also is there a preferred brand of spur or "special" spur to use?
I can only read the error so many times.... On the USA site the "spur dampening kit"... to Dampen means to moist or wet... the term is Damper or Damp.
-Attack this day with an enthusiasm unknown to mankind-
Styles is offline   Reply With Quote
Old 11-19-2013, 03:09 PM   #4795
Jerry P's Avatar
Trader Rating: 44 (100%+)
The plate it mounts on has 2 tabs that use 2 of the holes on the spur. I run kimbrough and Xenon spurs. they both fit with no issues.
Jerry
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 11-19-2013, 03:12 PM   #4796
Travis S's Avatar
The part the spur gets mounted on AT20 has 2 little pieces that stick out and fit into the holes on a spur gear. Then the nut keeps it in place. No special spur gear needed for that. Only the "moist" aftermarket spur gear holder needs a special spur or bigger holes put into a regular one.
Well son of a....... Jerry you are fast!
Old 11-19-2013, 03:26 PM   #4797
Styles's Avatar
Thanks guys... LOL..moist spur! I'm no grammar expert but I couldn't help that one.
Jerry - I got Teach's car.
Old 11-19-2013, 04:30 PM   #4798
erchn's Avatar
Dampen is the verb to damper's noun. They mean the same thing in different contexts. I hope you enjoy the car.
RCAmerica ; Team Powers USA ; Reflex Racing ; RC≥ RC Crew Chief ; Bezerk RC
erchn is offline   Reply With Quote
Old 11-19-2013, 04:42 PM   #4799
Jerry P's Avatar
You got a good ride. I beat up on a him a few times but it was driver not the car. Good luck with it. As you see the thread is a live and kicking so come by and ask away. Lot's of knowledgeable people run the car right now. You wont be disappointed with Teach's car.
Jerry P
Old 11-19-2013, 05:05 PM   #4800
Quantra's Avatar
I run an Xray hard bumper (with a chassis brace), so I'd imagine that if the bumper you posted fits an Xray it will fit the A700 too =] Only thing I've had to do is add 6mm of foam to the front of my bumper to bring it forwards to the same position the kit bumper sits in.
Vince Coleman
Quantra is offline   Reply With Quote
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10911 11-28-2016 07:09 AM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
