Old 09-17-2013, 11:55 AM   #4366
Jerry P's Avatar
Trader Rating: 44 (100%+)
Originally Posted by Awesoman View Post
Hi all,
I just have a short question. Is any 2014 race kit in planning? Ill buy a second Awesomatix in either way,
but if there won't be a new one, ill just buy another L car
I hope you're not confusing this thread with the Xray thread.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 09-18-2013, 02:26 PM   #4367
Hi all
I have an idea about that the geardiff is one of the most importent things on the car. I will drive with the metal gears. So my question is how many shims do i set in the geardiff so it is perfect shimed up ?
Best regards
Frederik BrolÝs Mikkelsen
Yokomo bd7 2014 Black Edition - Muchmore - Sanwa
brolÝs is offline   Reply With Quote
Old 09-18-2013, 02:38 PM   #4368
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by Oleg Babich View Post
For me our metal gears are smoother with 2-3 pcs of 0.1mm shims total for both sides under inner B85 bearings and the plastic gears are smoother without any shims or with one shim only.
Please try to change the orientation of P17 plastic cross also as this part is not 100% symmetric.
Originally Posted by brolÝs View Post
Hi all
Best regards
Awesomatix USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 09-19-2013, 01:05 AM   #4369
Travis S's Avatar
Trader Rating: 46 (100%+)
What would cause a lot of play between the SPR01S - SPR02 and the ST05 in a rear damper. It is making a lot of slop and I can wiggle the wheel up and down a 1-2mm. The other 3 dampers do not do this. The car has only been used a total of about 6 min. so far...
Travis S is offline   Reply With Quote
Old 09-19-2013, 04:36 AM   #4370
hanulec's Avatar
Trader Rating: 23 (100%+)
Not enough ride height (not enough tension between on rhs). Look at all of the shs and rhs screws. They rhs screws should be about the same distance/height difference from the shs. Make sure you tweak the car.
Or Loose spr02/set screw on the dampener
Getting the dampeners right IS one of the most important parts of the car.
Also-- double check the screws at the back of the dampener. They are likely to be loose/get loose after the first run.
If your still lost leverage the team! Monti "The Mangler" will be at Dirlas race on Fri/Sat.
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 09-19-2013, 09:01 AM   #4371
Trader Rating: 18 (100%+)
Mangler = the best nickname in R/C
● AWESOMATIX USA ● ABSOLUTEHOBBYZ ● HEBIKI DESIGN WORKS ●
MDawson is offline   Reply With Quote
Old 09-19-2013, 11:20 AM   #4372
hana166's Avatar
Hi all,
I think maybe there will be an updated car next year. So I'll put in my wishlist now:
1 Topdeck centre brace
2 Floating front gearbox
3 New diff Corally style http://www.redrc.net/2012/12/corally-sgx-gear-diff/
- I had something very similar in my Avante back in 1988
hana166 is offline   Reply With Quote
Old 09-19-2013, 08:43 PM   #4373
Dear Travis
Try to straighten SPR02 a little at a time then asemble the unit and check until the slop with ST05 is gone, it is not a fast process but sure worth the time spending.
Most of the case is a over bended SPR02 by pressing forming process, I did the trick to all my cars and the slop never come back.
Best regard
Wen
rcpinky is offline   Reply With Quote
Old 09-19-2013, 11:19 PM   #4374
Please check this before adjustments of the ride height and downstops:
http://www.rctech.net/forum/12338328-post3801.html
In case of all SPR02 are OK the most probable reason of the increased play is too low downstop and not enough spring preload on the particular corner.
The well adjusted car should have the equal play of the left/right wheels ( 0-2mm depending of the ride height and spring's rate).
Oleg Babich is offline   Reply With Quote
Old 09-23-2013, 05:31 PM   #4375
JayBee's Avatar
Trader Rating: 31 (100%+)
Default GREAT START
Had a great start to our indoor season to jump off one of our carpet series up here in Seattle (SRCR).
Since I'm running the original A700, I went with Ivan's Prostock ETS2011 setup. Followed it to the letter. Car was really good in the first heat but felt the car leaning a bit too much in the quick corners. So just for giggles decided to put on the 'brown-ish' swaybars (the ones right after the super thins). In practice in between rounds I couldn't believe what a difference that made. The car was just that much better and a lot more predictable. I could put the car anywhere I wanted w/o fear.
Second heat, it felt like I was mad at the track and just attacked. Myself and the leader was on a new TQ pace until with 3 laps left, a fellow lapper decided to play a little nasty. I qualified 2nd on the grid. Oh well...
The main was great...but coming back in the middle of the summer from a 2 year layoff, my driving showed I still have some rust to shake off. My ability of holding a tight line just isn't quite back yet
It'll come
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 09-23-2013, 06:36 PM   #4376
bkspeedo's Avatar
I was playing around with droop this weekend and saw some profound improvements in car handling. As many owning this car should know, it responds to the smallest setup changes, like no other car I've owned before anyway. It's an awesome thing, pun intended.
When i set droop i do it over ride height by measuring chassis height to ground, just behind the front wheel and in front of the rear, by lifting the car when holding the wheel on the side i'm checking. Pretty standard operation for those doing droop over ride height. I've been setting front to just under 1.5 mm and rear to just under 2 mm. Car has been handling very well and fast, just as fast as anyone else at our track. So i tried removing some to see what would happen. Went to 1 mm front and 1.5 mm back, what an improvement. Pulled my fastest lap to date in 17.5 and if it wasn't for me hitting shit probably my best average. Car transitioned through chicanes so nice and was even easier to drive.
If you never thought about playing with droop try 3-4 runs starting around .5\1 mm (Frnt\Rr respectively) and go up in .5 mm increments and see what happens.
I'm so looking forward to running this car at IIC this year, should be very good.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ ProtoForm ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 09-23-2013, 06:45 PM   #4377
Well said bkspeedo..... I think 1mm is the magic number to stay around, and the Awesomatix's already low Center of gravity will get even lower in the turns with these droop settings... Droop adjustment alone should make the A700 TQ...lol....
bertrandsv87 is offline   Reply With Quote
Old 09-23-2013, 08:35 PM   #4378
robk's Avatar
Trader Rating: 22 (100%+)
Travis S made a nice A main run in USGT at the USVTA Southern Nationals in Nashiville this weekend. On top of this, he was running a sweet Tamiya NSX for the laydown shock cars, which fits the Awesomatix since there's no shock towers!!
robk is online now   Reply With Quote
Old 09-23-2013, 09:15 PM   #4379
Travis S's Avatar
This car is well... Wait for it... Awesome! I wasn't expecting to make the A that is for sure. Some really good drivers in that race including ^ Rob the VTA King himself. I was just happy I made it to the show. (Crazy thing is I have only raced 1 time in over a year and this was the first time really getting to run this car.) Sunday I was going into the last qualifier I was 11th and midway into it I hear the announcer say "Travis is on a new TQ pace." I thought to myself that can't be right... Then I was like OMG REALLY and then the hand shakes came in and at about 4:30 seconds into it I tapped a corner and wedged my car into a board... I was still managed to qualify 7th and ended up finishing 4th overall. Overall I am very impressed with this car and can't wait for the Halloween classic to run it again.
I used Gee's Setup and really didn't change much of anything the whole weekend. Well... other then when Rob was checking out the car and pointed out something really dumb on my part. Also met "The Mangler" and he had a couple pointers as well. Since the car felt so good I didn't have to bug him much.
Old 09-24-2013, 12:43 AM   #4380
blackshark3's Avatar
First of all, with Thanks to Oleg, Wen and Angus, my parts are finally coming within this week.
As I am making up a list of things to order, what parts should I order to keep stock? Also, what is the use of AM18-1 and AM 26?
blackshark3 is offline   Reply With Quote
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
