Old 09-14-2013, 10:48 PM   #4336
hanulec's Avatar
Trader Rating: 23 (100%+)
Congrats to Karl Hoffmeister for his TQ and Win of the Middle River Hobbies IIC Warmup. Now if only Karl was going to IIC ... but he needs to worry about graduating college first...
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 09-14-2013, 10:54 PM   #4337
hanulec's Avatar
on another note -- anyone looking to attend IIC and run 17.5 or 13.5 should take a look at Mike Gee's 17.5 Club setup from 7 September 2013. i got a chance to run this today. it is very good, finishes super strong, nice and consistent, not too loose.
http://www.awesomatixusa.com/p/setup-sheets.html
i also have a personal 'loose' setup that i've been working on. it could be good for anyone willing to hang onto a car. i haven't written this one down yet... but i will soon.
Old 09-15-2013, 02:00 AM   #4338
Сongratulations, Karl !
Michael, please add the diff gears info ( metal or plastic, 2 or 4 satellite gears ) into setup sheets from US drivers.
Oleg Babich is offline   Reply With Quote
Old 09-15-2013, 02:09 AM   #4339
Originally Posted by hana166 View Post
Try 0.2mm gear side and 0.1mm bell side. Metal or plastic. Meshing tighter, but without binding actually makes the diff smoother especially with the metal gears.
Its quite notchy even when shimmed correctly but seems ok on the track.
For me our metal gears are smoother with 2-3 pcs of 0.1mm shims total for both sides under inner B85 bearings and the plastic gears are smoother without any shims or with one shim only.
Please try to change the orientation of P17 plastic cross also as this part is not 100% symmetric.
Old 09-15-2013, 05:02 AM   #4340
hanulec's Avatar
Will do from now on.
Nearly 100% of the setups posted have metal gears with the complete set of satellite gears
What are the advantages of two gear setups?
When running only two satellite gears, how much additional oil weight is required?
Old 09-15-2013, 05:05 AM   #4341
hanulec's Avatar
Running the plastic gears without shims usually yields extreme tooth wear. At least one sh01 is required to prevent tooth decay
Old 09-15-2013, 06:42 AM   #4342
Some of drivers suppose that their diffs are smoother with two metal gears. Two gears need ~1.5 times thicker oil usually.
Old 09-15-2013, 09:38 AM   #4343
Travis S's Avatar
Trader Rating: 46 (100%+)
So you are saying that I could need up to .3mm shims on both sides for the metal gears for a total of .6mm?
Also I thought running 2 gears was not a good thing to do. I am not planning on running anything faster then 17.5 any time soon so maybe this is only an issue in mod?
Travis S is offline   Reply With Quote
Old 09-15-2013, 09:43 AM   #4344
JayBee's Avatar
Trader Rating: 31 (100%+)
For me our metal gears are smoother with 2-3 pcs of 0.1mm shims total for/of both sides under inner B85 bearings and the plastic gears are smoother without any shims or with one shim only.
See above quote again....I hope I'm thinking that out correctly
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 09-15-2013, 09:55 AM   #4345
Travis S's Avatar
I was thinking this as well, but wanted to make sure before I go trying to stuff in .6mm and .3mm was really the max. However when I look at the picture for the diff mod it does show .1mm on the left and up to .3mm on the right making it a total of .4mm. So .6mm doesn't seem far off.
Also from the mod picture the shims should be between the B85 bearings and the OR05 o-ring correct?
Old 09-15-2013, 10:26 AM   #4346
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
Oleg,
You have PM
Luke
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 09-15-2013, 12:04 PM   #4347
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
For all the gear diff shim talk, is that for the ST07 or ST26 out drives? Or do you shim them the same? I run the ST07's and have to use 0.4mm total shims with my plastic gears to make my diff smooth/reliable.
Awesomatix USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 09-15-2013, 01:01 PM   #4348
This picture is our recommendation for the first A700 cars.
We have used the original Spec-R plastic gears for our diffs that time and this recommendation included ST20 modification also.
Our current plastic gears are a bit wider and need less shims in average.
Old 09-15-2013, 08:51 PM   #4349
bhambrent's Avatar
I'm looking at getting a awesomatix for 17.5 Blinky, which kit should I get and what extra parts would be best to buy?
Half-A$$ Racing - Cooperhobbies.com - Hot Bodies D413 - OneLug Hobbies - Awesomatix - Thunder RC Raceway - SpeedKingz Racing "G SERIES"
bhambrent is offline   Reply With Quote
Old 09-15-2013, 08:56 PM   #4350
Travis S's Avatar
Most people I see on here are running the A700L USA version for stock and the EXL for Mod.
Here is a post about the spare parts. http://www.rctech.net/forum/9984890-post1002.html
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
