Old 09-13-2013, 09:15 AM   #4321
bkspeedo's Avatar
Originally Posted by Travis S View Post
Is the overall height of the AM06S the same as the AM06? I don't have the AM06S so I am trying to adjust Gee's setup. Looks like I can just take out the 1mm at the bottom, but wasn't sure if I need to add anything to the top.
Travis,
Before going gung-ho on the none kit parts, you should give my setup a try that i posted a few days ago, which uses all kit parts. I did make some mods to this setup over the weekend and this week which i feel makes the car faster but maybe a touch harder to drive. The caveat is all my testing has been done on very high carpet traction. So it may not be the best but still decent on low traction.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ ProtoForm ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 09-13-2013, 09:30 AM   #4322
Travis S's Avatar
Trader Rating: 46 (100%+)
Originally Posted by bkspeedo View Post
Travis,
I will check it out. I don't plan on getting the lower hubs anytime soon if at all... If I can't get the shorter ti-rods I need before I go to Southern Nats in Nashville next week I will give your setup a shot. Heck I might give it a shot anyways and see what I like better out of the 2. Thanks all for the help.
Travis S is offline   Reply With Quote
Old 09-13-2013, 09:38 AM   #4323
Travis S's Avatar
Originally Posted by geeunit1014 View Post
No, the AM06s is 1mm shorter overall. If you dont have them, I would reccomend either making the lower arm as low as possible (0 shims with at21s), or run long links to the shortest hole on the bulkhead (like my mod asphalt setup)
Sounds like if I take out that 1mm shim at the bottom by the ball in your setup it should be very close to the same then. However the longer links idea sounds appealing since I don't have the short ones yet! :P
Old 09-13-2013, 01:33 PM   #4324
geeunit1014's Avatar
Sort of, but I also have that shim in to create a little width. you can add 0,5mm shims all around to get the width back but the camber links will be a little shorter
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 09-13-2013, 03:16 PM   #4325
Travis S's Avatar
First off thank you for your help! I just need a little clarification and hopefully I will be set.
So if I got this right, going from top down.
Front:
  • 3mm
  • 1.5mm
  • .5mm
Back:
  • 3.5mm
  • 4mm
  • .5mm
Old 09-13-2013, 05:55 PM   #4326
If you were to use the regular am06 instead of the am06s, the shims would be:
Front:
2
1.5
0
Rear:
2.5
4
0
w/ 0.5mm hex shims all around if you want the width.
Mike Gee
Old 09-13-2013, 05:59 PM   #4327
Travis S's Avatar
Front:
2
1.5
0
Rear:
2.5
4
0
Got it. I didn't realize you were talking about hex shims. I thought it was for everywhere else.
Old 09-14-2013, 12:12 AM   #4328
brent, are you using jaco blues??
FUBFTC is offline   Reply With Quote
Old 09-14-2013, 08:35 AM   #4329
bkspeedo's Avatar
Yes, its our spec tire at 5280.
Brent Klingforth
Old 09-14-2013, 02:04 PM   #4330
have u tried gees setup?? how does it compare tp urs
Old 09-14-2013, 04:03 PM   #4331
Travis S's Avatar
I am having some issues trying to make this gear diff smooth. I am using the metal gears and it can really feel each tooth when I turn it. It feels notchy if that is even a word. I have tried to rebuild it multiple times and it still doesn't seem right. Anyone else running into this or have any advise?
Old 09-14-2013, 04:43 PM   #4332
Did you use any shims in the diff? If so take them out, they aren't needed with the metal gears. Run in the diff a few times then change the oil. You will probably see that the oil has become silvery looking. After that it should feel smooooth....
HawaiiBob is offline   Reply With Quote
Old 09-14-2013, 04:51 PM   #4333
Travis S's Avatar
No shims, but the car has not been ran yet. I did try break it in by running it on a stand and holding each tire at a slower speed to try to see if that helped but so far it didn't do much of anything. The first time on the track with it will be tuesday and I can't wait! Just trying to get all setup before I make the 3 hour trip to my "local" track.
Old 09-14-2013, 09:50 PM   #4334
hana166's Avatar
Try 0.2mm gear side and 0.1mm bell side. Metal or plastic. Meshing tighter, but without binding actually makes the diff smoother especially with the metal gears.
Its quite notchy even when shimmed correctly but seems ok on the track.
hana166 is offline   Reply With Quote
Old 09-14-2013, 09:56 PM   #4335
Travis S's Avatar
I'll give that a try. The way it is now is that I can hear the gears click when I turn it. The diff doesn't get hung up or anything so maybe that is normal. I was just expecting to feel really smooth or hear nothing with how nice this car is. After I get a chance to run it maybe it will get better.
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17189 Yesterday 03:25 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
