Old 09-11-2013, 10:01 PM   #4306
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by Dan View Post
For the guys that run blinky 17.5, do you guys run any drag brake as a result of the free-wheeling nature of the car and setup more for oversteer? Or do you guys use no drag brake and rely on tapping the brakes on most corners?
I run the same amount of drag brake I did with a belt car and changed how much I use the trigger brake. Though i'm sure everyone will give you a different answer. Just depends on your driving style.
Awesomatix USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 09-11-2013, 11:23 PM   #4307
hanulec's Avatar
Trader Rating: 23 (100%+)
in my prior touring cars (when I was fast) I never ran drag brake. i just learned how to push brake effectively into corners. every time I drive a car w/ drag brake I just drive into every corner or are 0.5-1.0s off the pace.
after switching over to the Awesomatix i haven't changed my driving style, but often you need more push brake to slow the car down (and sometimes, the car just carries so much corner speed you don't have to slow down as much).
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 09-12-2013, 04:28 PM   #4308
Travis S's Avatar
Trader Rating: 46 (100%+)
If you use the AM18 and the furthest holes like Gee's carpet setup do you still need shorter turnbuckles? Before I try and fail and piss myself off I thought I would ask...
Travis S is offline   Reply With Quote
Old 09-12-2013, 04:35 PM   #4309
hanulec's Avatar
Am18 and am19 both need shorter turnbuckles than stock.
Old 09-12-2013, 04:48 PM   #4310
Travis S's Avatar
That hurts... You don't have them in stock either and I need something by Tuesday! What size's can I use? I see your site lists them as 1 1/4" so would 4x30mm work? I am trying to find a place that I can get these fast so I am looking at all options...
Old 09-12-2013, 04:59 PM   #4311
hanulec's Avatar
1+ month lunsford back order
3mm diameter
30mm length
I have TOP photon steel rods on one of my cars right now..
Old 09-12-2013, 05:07 PM   #4312
NO TOP STUFF ON AWESOMATIX !!! JEES.....
bertrandsv87 is offline   Reply With Quote
Old 09-12-2013, 05:11 PM   #4313
No mailing address for Awesomatix Usa is the real issue at hand here !!! Come on, get it together !
Old 09-12-2013, 08:54 PM   #4314
Travis S's Avatar
I think Mike is afraid you might show up on his door step if he listed his address.
Well I am trying some blue tamiya 32mm turnbuckles from one of my other cars until I can get the punishers... Hope they work.
Old 09-12-2013, 09:11 PM   #4315
geeunit1014's Avatar
Length should be OK, hope your getting the Ti ones and not the Al ones, Al ones from tamiya are very weak
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 09-12-2013, 09:16 PM   #4316
Travis S's Avatar
They are AI... That is all I got for now (They came off a different car I have.) I need something before tuesday so I can get some track time with the car. Hopefully the track I am going to will have something better.
Old 09-13-2013, 01:14 AM   #4317
Travis S's Avatar
Is the overall height of the AM06S the same as the AM06? I don't have the AM06S so I am trying to adjust Gee's setup. Looks like I can just take out the 1mm at the bottom, but wasn't sure if I need to add anything to the top.
Old 09-13-2013, 03:00 AM   #4318
You can use our AT14 short turnbuckles.
Oleg Babich is offline   Reply With Quote
Old 09-13-2013, 07:03 AM   #4319
Cool
It does not have to be your home address... A PO box address is more appropriate to boost sales... Stop being afraid Mike, you don't live in Syria....lol..
Old 09-13-2013, 07:42 AM   #4320
No, the AM06s is 1mm shorter overall. If you dont have them, I would reccomend either making the lower arm as low as possible (0 shims with at21s), or run long links to the shortest hole on the bulkhead (like my mod asphalt setup)
Mike Gee
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
SEO by vBSEO 3.5.0
