Old 09-02-2013, 04:52 PM   #4216
JayBee's Avatar
Trader Rating: 31 (100%+)
Default Damper Issues
With 4 runs on my freshly built A700 on asphalt the car perform pretty well. With carpet season almost here, wanted to get some laps in on the car. Had a long practice day on Saturday and the first half of the day went pretty much perfect. The latter half...totally opposite. On power, off power the car just kept spinning to the right. No matter what I tried...couldn't mend it. After stripping the car down to the chassis and electronics, took the rear geardiff apart and found close to no fluid in it I was told that this could have been the big issue. No bent or broken parts, or anything bound up. So everything seemed normal.
Putting a different setup on the car as I'm rebuilding it though, I see that my RR and LF dampers have spooge coming out the front of the 'barrel' around the screw and also the backside. No biggie, I wipe clean and I set the dampers from Sym (kit settings) to Asym and find that they are not behaving the same as their opposites. Same compression and rebound strokes After awhile of fiddling, I gave up. They behave Symmetrically no matter what.
My question is- is something wrong with the dampers and are these original dampers still available? And if not, what can I do to get my car back up and running again?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 09-03-2013, 11:56 AM   #4217
JayBee,
It is difficult to say what is actually wrong with your dampers being at such long distance from them.
Right after release of the new dampers we have offered the replacement of old dampers by new dampers at discounted price for owners of our old A700 cars. I recommend you to do this now.
The alternative possibility - to send your dampers to our Taiwan factory for reparing.
Please inform me via PM what do you prefer.
Oleg Babich is offline   Reply With Quote
Old 09-03-2013, 12:00 PM   #4218
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by KHoff7 View Post
A pic of my car using the 40mm WTF fan.
Do you run your car without the diff/spool covers?
(great wiring job.. super clean)
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 09-03-2013, 12:32 PM   #4219
bkspeedo's Avatar
I like running mine with the covers. I think to car is a bit quieter than those at our track without. Plus i like to lube the gears slightly to help with wear. If I used this car outside i would definitely run with the covers.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ ProtoForm ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 09-03-2013, 12:36 PM   #4220
oldrcr's Avatar
Trader Rating: 43 (100%+)
Hey Brandon,
much to Jakes chagrin, I haven't run covers when running indoors on carpet. Never seemed to be an issue, but there is always a first time...
I suppose even indoor dust will be attracted to any lube on the gear teeth, so it should be considered as wear potential. They are not hard to put on I was just lazy and never put them back on forgetting to after switching out from asphalt set up the season before.
It is nice to look at the gears spinning. It brings back memories of being a kid watching mechanical things going around and around, and that helps makes us feel young again.
-Alex
Alxd - Seattle RC Racers - AWESOMATIX - Having Fun :-)
oldrcr is offline   Reply With Quote
Old 09-03-2013, 01:19 PM   #4221
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by hanulec View Post
A few months ago I got this info from Oleg--
http://racerlog.com/wiki/Awesomatix_A700#Sway_Bars
Personally, I've tried a bunch of setups, but I really like bars on the A700. The bar mount system makes it easy to work w/ them...
Yeah that's the post I was talking about. I'd agree with you, I've liked my car better with sway bars so far. Seems like everyone does.
Looks good man!
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 09-03-2013, 01:33 PM   #4222
hanulec's Avatar
Trader Rating: 23 (100%+)
On carpet you don't need diff covers...
And it look sexy
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 09-03-2013, 03:25 PM   #4223
KHoff7's Avatar
Outside=covers
Inside=no covers
For what it's worth I like swaybars.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 09-04-2013, 01:29 AM   #4224
hana166's Avatar
I recommend moving the fan above the motor, its toast when the inevitable happens
hana166 is offline   Reply With Quote
Old 09-04-2013, 01:37 AM   #4225
Oleg, please see pm
Regarding diff cover a team mate and I have both been running without diffcovers inside.
However outside I used them and he did not. He didn't have a single problem.
Cp Grafix is offline   Reply With Quote
Old 09-04-2013, 02:17 AM   #4226
Have you tried those body stiffeners angled outwards? Pushing down on the body, they felt more effective that way on my T4.
-Mike
Old 09-05-2013, 09:24 AM   #4227
part-time racer's Avatar
Is a one-way available and if so, has anyone tried it?
Richard Clarke
EWS Event Organizer
CPD Racing ___MuchMore-UK___Awesomatix UK___OTM Racing
part-time racer is offline   Reply With Quote
Old 09-05-2013, 11:45 AM   #4228
OVA
OVA's Avatar
Trader Rating: 72 (100%+)
Are you sure they're in stock?
OVA is offline   Reply With Quote
Old 09-05-2013, 11:48 AM   #4229
Team EAM
EAMotorsports's Avatar
Trader Rating: 75 (100%+)
Send a message via AIM to EAMotorsports
For you Awesomatix guys I just saw Freddy Sudhoff post his plane ticket for IIC was purchased today and he will be there!
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID | Futaba.
EAMotorsports is offline   Reply With Quote
Old 09-05-2013, 11:52 AM   #4230
OVA
OVA's Avatar
EA
that's an awesomatix...lol
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17195 01-10-2017 05:04 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
