Old 08-08-2013, 11:55 AM   #4021
Hi Oleg
The bumber brace could be an optional part so them there will be sure it not will break can bought that and them there not will have it can choose to not buy it
Best regards
Frederik BrolÝs Mikkelsen
Yokomo bd7 2014 Black Edition - Muchmore - Sanwa
brolÝs is offline   Reply With Quote
Old 08-08-2013, 12:07 PM   #4022
Magnet Top's Avatar
Originally Posted by syndr0me View Post
How much should I fill the gear diff? Mine still seems too tight after many runs with the metal gears.
I have noticed, especially with the metal gears, and even more especially, when they are new , it is important to replace the gear diff oil very frequently. Thankfully, it isn't difficult to do on the A700. Especially in mod I've noticed more stable cornering after fresh fluid is used.
Oleg suggested, if there is excessive metal shavings, to use 3x6x0,1mm steel shims between G06 satellite gears and AT24. A slight bit of reduction in G06 (big or small face) might be necessary due to the added shim so G06 won't bind.
as far as filling it, I'd go with what the manual says.
Jake D.
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 08-08-2013, 12:48 PM   #4023
syndr0me's Avatar
Trader Rating: 32 (100%+)
Good call, I forgot the fill line was already mentioned in the manual. I'll give it a good cleaning tonight. I might try some different o-rings too, I feel like most of the binding is that o-rings between the bearings.
syndr0me is offline   Reply With Quote
Old 08-08-2013, 01:17 PM   #4024
Originally Posted by nutsisneat View Post
Hello Oleg
I heard, Raceberry is producing a thin chassis too.
What are your thoughts about that?
Or do you even work toghter in a way with Toni?
Regards
With our new floating front gearbox we are not limited in the choice of the chassis. The chassis for A700 can be very soft soon without any negative torque twist effects.
So welcome for all aftermarket chassis makers.
We also will produce the best possible chassis for our cars.
Oleg Babich is offline   Reply With Quote
Old 08-08-2013, 01:21 PM   #4025
ropezz's Avatar
ropezz is offline   Reply With Quote
Old 08-08-2013, 01:56 PM   #4026
Originally Posted by ropezz View Post
It looks good.
Does the additional carbon part only touches the front gearbox?
Old 08-08-2013, 02:01 PM   #4027
Originally Posted by Awesoman View Post
Can anybody explain how to dismount the Spool? I need to clean my bearings and have no clue how to get them out of it
Please: http://www.rctech.net/forum/12337062-post3797.html
Old 08-08-2013, 02:24 PM   #4028
Thanks !
Awesomatix | LRP
Awesoman is offline   Reply With Quote
Old 08-08-2013, 02:35 PM   #4029
Thanks !
Please be careful and apply your force to the ST07 outdrives but not to aluminium wheel as you can bend the wheel if you are strong enough.
Old 08-08-2013, 03:18 PM   #4030
I will take care.
Thank you.
Awesomatix | LRP
Old 08-09-2013, 12:46 AM   #4031
ropezz's Avatar
Hello Oleg,
the answer to your question is yes.
The chassis belongs to the very first series, as the rest of the car.
Old 08-09-2013, 05:00 AM   #4032
witch parts have you used to make the "topdeck"
Old 08-09-2013, 10:16 AM   #4033
josecarlo1129's Avatar
I just really love the steering set of A700 and can't help myself to dissect it (again) and have a proper photo. Well thought.
Cheers!
Nitro: On-road 1/8: Motonica P81-RS2/Vox/Savox
Off-road 1/8: JQ TheCar/Vox/Savox
Electric: On-road 1/10 TC: Awesomatix A700 EVO/AE BD/Team Orion/Ko Propo
On-road 1/10 F1: 3Racing FGX + RC9394 Carbon Conversion AE BD/Team Orion/Ko Propo
josecarlo1129 is offline   Reply With Quote
Old 08-10-2013, 06:55 PM   #4034
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
If anyone's looking for an aluminum servo horn, the dynamite (PN: DYN2531) works great. Full lock left and right using the second hole from the top.
Awesomatix USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 08-11-2013, 01:36 AM   #4035
JayBee's Avatar
Trader Rating: 31 (100%+)
Default A700
My A700...
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
