Old 07-25-2013, 08:23 PM   #3901
hanulec's Avatar
Trader Rating: 23 (100%+)
The Awesomatix family keeps on growing. This party at IIC might be really big. For anyone looking for an A700L USA SPEC kits -- more are in the air right now. There are also A700EXL and A700EX available right now..
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 07-25-2013, 08:30 PM   #3902
haywood's Avatar
Trader Rating: 47 (100%+)
I think Scotty mentioned that Awesomatix has VIP pitting outside by the tire truer!
/ Roche Rapida 2015-2016 / Hobbywing / Team Scream / Rc Painting By Mikey / Ko Propo / MMR / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 07-25-2013, 08:40 PM   #3903
syndr0me's Avatar
Trader Rating: 32 (100%+)
I haven't really been happy with my steering setup using the XRay servo saver. It's kind of a chunky monkey. Gonna try the Tamiya (with a black horn) next week.
syndr0me is offline   Reply With Quote
Old 07-25-2013, 08:52 PM   #3904
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Wink
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 07-25-2013, 09:02 PM   #3905
Trader Rating: 18 (100%+)
I have had greater failure with the Tamiya 3 ring setup. The XRAY units dont get nearly as mushy as the Tamiya units do after months of use.
● AWESOMATIX USA ● ABSOLUTEHOBBYZ ● HEBIKI DESIGN WORKS ●
MDawson is offline   Reply With Quote
Old 07-25-2013, 09:03 PM   #3906
syndr0me's Avatar
No doubt. I saw a post from someone saying they put a second black spring in the Tamiya saver, but I tried that and it wouldn't clear the 1pc servo mount.
What hole are you using in the XRay saver? Did you shim your servo away from the mount so the steering rack would clear it?
Old 07-25-2013, 09:09 PM   #3907
Trader Rating: 31 (100%+)
I use a Ko one10 servo and don't use a servo saver at all. One car has a Losi aluminum servo horn and the other uses a ko aluminum horn. No issues at all, I saw JD uses an aluminum Losi as well.
Monti
Monti is offline   Reply With Quote
Old 07-25-2013, 09:16 PM   #3908
Top hole on the XRAY servo with 3mm of spacers under the ballstud link on the rack. You might have to relieve .025mm of material on the buttom side of the top deck. It might 'brush' the top deck without the additional clearance.
Ideally I should have redrilled the XRAY servo saver hole about .5mm below the top most hole.
In the past I would have gone to the aluminum arm for the outdoor season but that was until I found the XRAY 'optimized' servo saver
Old 07-25-2013, 09:22 PM   #3909
hana166's Avatar
Dremel a half millimeter or so off the 1pc mount (maybe less) under the 4th spring. Half inch drum sander does the job nicely and you can't see it once its all put back together.
hana166 is offline   Reply With Quote
Old 07-25-2013, 09:28 PM   #3910
syndr0me's Avatar
I've wondered about going to a solid horn and how it might work out on a track like ours. Blowing up my one10 would suck. I guess I could look into replacement gears to see what that would set me back.
Yeah, that's the same thing I experienced, where the top hole of the XRay saver was a bit too tall and the one below it was too low. I'll revisit it.
Good call, thanks.
Old 07-25-2013, 09:29 PM   #3911
hanulec's Avatar
I'm running the top "outside" hole in the xray servo saver..
Old 07-25-2013, 09:32 PM   #3912
syndr0me's Avatar
That's what I was doing as well. Wasn't sure if it was the right way to go about things.
Old 07-25-2013, 09:37 PM   #3913
Here is a pic of my servo mount converted to a fan mount. Hanulec was the genius behind the idea.
Monti
Old 07-25-2013, 09:38 PM   #3914
hana166's Avatar
Thinking about shimming the drivetrain up 1mm in order to flatten the driveshaft angle. Can I expect more traction or less. Never used this adjustment when I had a conventional TC so was considering giving it a go. Anyone who knows what effect raising the diffs has please chime in.
Old 07-25-2013, 09:39 PM   #3915
It's not like I am easy on the boards some people do call me the Mangler!
Monti
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17189 Yesterday 03:25 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
