Old 07-14-2013, 05:34 PM   #3826
Suspended
Originally Posted by hanulec View Post
I'd try..
Less rear droop
More front spring (smaller B value)
More front dampening (higher A value)
Is this in high speed or low/medium speed sections?
I would say low to medium speed
.....rayzerdesigns.....www.jconcepts.net...
i am cornholio is offline   Reply With Quote
Old 07-14-2013, 07:59 PM   #3827
geeunit1014's Avatar
What does your setup look like?
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 07-14-2013, 09:23 PM   #3828
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by IIGQ4U View Post
BlackedOutREVO was in SoCal this weekend and I had the opportunity to race with him at Cal Raceway.
This was my first time seeing an Awesomatix in person and I must say, the simplicity of the car is impressive. There are so many small things that have been addressed to make setup changes, faster, simpler and more effective.
After watching the Awesomatix through practice and in one of the rounds during racing, all I can say is the car is an absolute beast! The way that the car cornered flat but maintained grip and carried an insane amount of corner speed was like nothing I have driven. When you entered a high speed corner with the Awesomatix, instead of waiting for the car to roll and turn, the car would turn in impressively and maintain a solid line.
After driving and seeing Brandon's Awesomatix car in person, I am definitely a believer and can say that this is the only other car I would purchase right now.
Awesome job guys!
It was fun racing with you guys! Wish I didn't have to leave so soon. Hope to make another trip back soon.
Here is my setup from this past weekend, and what I run at my home track Speedworld. Very easy to drive, lots of steering, and is super consistent.
http://racerlog.com/w/images/a/a6/A700calraceway.pdf
Awesomatix USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 07-14-2013, 09:26 PM   #3829
Magnet Top's Avatar
ditto what Mike said.
Also, play with ackerman and front toe as well.
and, this might seem counter intuitive but if nothing else is working, try just a little less rear toe if you are already using a lot. Adding rear toe can make a car rotate more into the first third of a corner at low speed. Also check your "bump toe" to make sure it is not changing during compression. As Mike said in a previous post, allowing some bump toe is something that can be used to advantage but it generally should be restricted to smooth tracks and stock classes without ... ahem... bumps
Jake D.
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 07-14-2013, 09:29 PM   #3830
trigger's Avatar
Nice running with you at cal raceway (blackedoutrevo) Brandon. You are a class act and very talented. Hope to run with you again.
Minh Nguyen-FD
[Hobby Authority Distribution][Maclan Racing][Xpert]
trigger is offline   Reply With Quote
Old 07-14-2013, 09:34 PM   #3831
Suspended
hey gee...its the manual set up..3 degrees rear toe..1degree toe out front, a spacing is 0 front and rear, b spacing is 1.2 front, and 1.0 rear..ride height front is 5.2 rear is 5.5..its a bumpy track..and droop is 2.5 mm over ride height front and rear..track is low to medium bite depending on time..usually main is a bit higher traction than the day
Old 07-14-2013, 10:20 PM   #3832
I would add some damping (increase a gap spacing) front and rear, and also maybe less rear droop like FJ suggested. Personally I also like the rear sprung much firmer than the front (my 17.5 car is 65.7gf/mm front, 83.3 gf/mm rear), I find it makes the car more stable
Mike Gee
Old 07-15-2013, 12:16 AM   #3833
Suspended
ok..will try it..thanks..you going to iic??
Old 07-15-2013, 08:02 AM   #3834
unfortunately not, still in school. maybe next year though
Mike Gee
Old 07-15-2013, 09:51 AM   #3835
Suspended
do you have a good carpet setup?? I really liked your rsd6 setup..
Old 07-15-2013, 12:30 PM   #3836
I really liked Kutvonen's mod setup from ets r2, just changed to 2k diff oil and a ltc body for stock. Its on awesomatix.com
Mike Gee
Old 07-15-2013, 02:21 PM   #3837
Suspended
cool..thx
Old 07-15-2013, 03:08 PM   #3838
syndr0me's Avatar
Trader Rating: 32 (100%+)
How much taller is AM18-1 than the top deck?
How much shorter is AM19 than AM18-1?
In the setup Mike mentioned, Kutvonen says he's measuring the shim height from the top deck, and is using AM18-1 up front. It appears to be in the hole that overlaps with AM19, so I'm trying to figure out how much I would need to shim AM19 to be at the same height.
syndr0me is offline   Reply With Quote
Old 07-15-2013, 04:17 PM   #3839
hanulec's Avatar
Trader Rating: 23 (100%+)
Am19 is at top deck height.
Am18 sits on top of bulkhead or top deck.. It is a top deck thickness. 2mm
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 07-15-2013, 07:13 PM   #3840
Thanks Minh, was great racing with you!
Has anyone messed with the ST27 chassis stiffener's? Do they make a noticeable difference on the track?
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
