Old 07-14-2013, 02:55 AM   #3811
Suspended
first time on track tonight..car was good..little loose..but fast..kyle ran the new top deck in the main..he was 5 seconds up on myself and cooper..he said it made the car easier to drive hard..cant wait to get my hands on one
.....rayzerdesigns.....www.jconcepts.net...
i am cornholio is offline   Reply With Quote
Old 07-14-2013, 09:59 AM   #3812
What new top deck? What's different about it?
HawaiiBob is offline   Reply With Quote
Old 07-14-2013, 10:07 AM   #3813
syndr0me's Avatar
Trader Rating: 32 (100%+)
Does everybody run the shaft support, even in the 17.5/13.5 classes?
syndr0me is offline   Reply With Quote
Old 07-14-2013, 10:19 AM   #3814
OVA
OVA's Avatar
Trader Rating: 66 (100%+)
Yes. you should use them ..the shaft support keep the drive shaft perfect straight under the acceleration and you want to bent them
OVA is offline   Reply With Quote
Old 07-14-2013, 10:43 AM   #3815
hanulec's Avatar
Trader Rating: 23 (100%+)
just some new parts under test. very similar to the t-shape top deck, just a bit more narrow.
my attempts to test yesterday got wrecked by rain, and then later humidity turning a soda prepped track into a skating rink.
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 07-14-2013, 11:17 AM   #3816
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
I would recommend you run it also.
Awesomatix USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 07-14-2013, 11:42 AM   #3817
Suspended
defanately let the car flex more..even with the center support..i will order one as soon as available..he was using the super narrow one mike
Old 07-14-2013, 11:53 AM   #3818
Suspended
also..whats the easiest way to measure caster on the car?? and what changes do the am06s do??
Old 07-14-2013, 12:08 PM   #3819
hanulec's Avatar
some folks have replaced the screw on the hub w/ a long set screw to help provide that straight line to measure caster w/in a setup station. awesomatix usa is working on some 'caster doodles' (inspired by Mike Gee's initial design) to help w/ fine grained caster measurement. no eta yet -- as the design isn't finalized. looking to make the manufacturing idiot proof and yet cost effective.
the am06s lower the hub by 1mm.
Old 07-14-2013, 12:21 PM   #3820
hanulec's Avatar
in what way was your car loose? just lacking overall grip? or loose on power?
if lacking overall grip i'd recommend two things 1) cutting your top deck. either removing the front + rear sections, or making a t-shape design. 2) trying the type 2 shock config
if your loose on power i'd recommend reducing the amount of shim you have on the rear toe link between the outside ball and the rear toe arm. i've used this change to tighten up/make my mod car rotate less. i should probably make this change to my stock car too, and then i can add some dual rate back into the car.
Old 07-14-2013, 01:00 PM   #3821
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
BlackedOutREVO was in SoCal this weekend and I had the opportunity to race with him at Cal Raceway.
This was my first time seeing an Awesomatix in person and I must say, the simplicity of the car is impressive. There are so many small things that have been addressed to make setup changes, faster, simpler and more effective.
After watching the Awesomatix through practice and in one of the rounds during racing, all I can say is the car is an absolute beast! The way that the car cornered flat but maintained grip and carried an insane amount of corner speed was like nothing I have driven. When you entered a high speed corner with the Awesomatix, instead of waiting for the car to roll and turn, the car would turn in impressively and maintain a solid line.
After driving and seeing Brandon's Awesomatix car in person, I am definitely a believer and can say that this is the only other car I would purchase right now.
Awesome job guys!
IIGQ4U is offline   Reply With Quote
Old 07-14-2013, 03:47 PM   #3822
Suspended
hey mike..off throttle loose mainly
Old 07-14-2013, 03:49 PM   #3823
Suspended
car still has a slight tweak still due to the front spr02..i bent it flat as best I could..but need to order new ones..what does lowering the hub actually do??
Old 07-14-2013, 04:50 PM   #3824
hanulec's Avatar
http://racerlog.com/wiki/Awesomatix_...ter_Adjustment
Old 07-14-2013, 04:57 PM   #3825
hanulec's Avatar
I'd try..
Less rear droop
More front spring (smaller B value)
More front dampening (higher A value)
Is this in high speed or low/medium speed sections?
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10911 11-28-2016 07:09 AM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
