Old 07-07-2013, 09:05 AM   #3766
G-rem's Avatar
Quick question: is there any complete kit for the spur damper system that includes all the parts we need to do this modification in the right way?
Thanks for replies,
G-rem
G-rem is offline   Reply With Quote
Old 07-07-2013, 09:35 AM   #3767
Thanks for replies,
G-rem
SD1 set:
http://shop.awesomatix.com/index.php?productID=931
Oleg Babich is offline   Reply With Quote
Old 07-07-2013, 02:46 PM   #3768
G-rem's Avatar
Nice!
Old 07-08-2013, 12:10 AM   #3769
zoomster's Avatar
Default AOC win
The second round of the Asian Onroad Champion (AOC) was held in Melbourne, Australia,their was several big names came out from Europe,Asia,USA for the event,and to Scotty thanks for a top event.
It was my first time ever that i had ran on carpet,so for me and 95% of the other drivers it was too.From day one the car felt good,so i let the track came to the car,and only changed two settings,from what i have been running out side leading up to the event.
So after practice ,qualifying,rounds i placed the car 2nd in the A main,i was over the moon with this placing,onto the finals,after a bad round one,it was up to the last 2,I managed to win the 2nd ,but placed 3nd in the last,but this was enough for a WIN in the 17.5 stock class,and on the way helping the only other Awesomatix driver at the event.
Team Bust Out The Shorts Racing
zoomster is offline   Reply With Quote
Old 07-08-2013, 12:30 AM   #3770
My greatest congratulations, Scott!
Please inform your setup.
Old 07-08-2013, 12:57 AM   #3771
Well done Scotty
Was great to meet another awesomatix driver to bounce ideas off see you soon.
markmarshall is offline   Reply With Quote
Old 07-09-2013, 11:56 AM   #3772
More weekend's news from Awesomatix drivers:
Richard King won the the BTCC championship round in West London.
Congratulations, Richard!
3rd place for young Dionys Stadler at the first round of the CONRAD Electronic Touring MASTERS Series in Andernach ( modified class).
First A-final: 1.Marc Fisher, 2. Dionys , 3. Tim Wahl.
Second A-final: 1.Marc Fischer, 2.Christopher Krapp, 4. Dionys
Third A-final: 1. Christopher Krapp, 2. Dionys, 3. Marc Fischer
The car was good, on the same pace as the winner.
http://www.myrcm.ch/de/conradelectro...nMo/index.html
2nd place for Max Mächler at the same CONRAD Electronic Touring MASTERS Series race ( Stock Class).
A-main also for Michael Kiesewetter. Michael even won the first A-final.
http://www.myrcm.ch/de/conradelectro...Sto/index.html
Congratulations for Max and Michael !
Awesomatix EP Touring Car-20130707_165124-small.jpg   Awesomatix EP Touring Car-max-2small.jpg
Old 07-09-2013, 02:14 PM   #3773
Suspended
hey guys I am having a problem with the front spring on one side..the slop before it makes any tension..its on the spr01s and st05 as well as spr02..its only on one side..i have taken apart a few times and double checked that its on the pin..not bound up..it is exactly as other 3 corners..but there is about 2 to 3mm of uptravel before it makes any tension on spring..though it might work itself out..but ran car..its severely tweaked with it theway it is..turn to right and wants to dump and spin out..any suggestions
.....rayzerdesigns.....www.jconcepts.net...
i am cornholio is offline   Reply With Quote
Old 07-09-2013, 04:10 PM   #3774
hanulec's Avatar
Trader Rating: 23 (100%+)
the spr02 might not be sitting right w/in the dampener. do you see that the st05 is scratching the shock holders? you can also potentially hear a 'clicking' noise as you move the arm...
you must adjust the depth of the spr02 w/in the shock slot. someone has posted a trick of using part of a paper clip to provide additional spacing between the spr02 and shock body. i generally just move the spr02 in and out re-adjusting the set screw until it runs perfectly.
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 07-09-2013, 05:31 PM   #3775
JayL's Avatar
Anyone from Norcal think the AM06S would be the way to go for our local tracks: Nor-cal, Speedworld and new Delta indoor asphalt?
13.5 or 10.5 blinky
A800 HW XR10Pro HW G2 4.5T|||B5MFL HW StockSpec Team Powers 17.5|||VTA: Awesomatix EVO 1.1 Orca VX3 |||F1:
Xray X1 2016, HW V3.1, Ride XR Tires, D4SS 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 07-09-2013, 06:11 PM   #3776
hanulec's Avatar
13.5 or 10.5 blinky
I haven't run at norcal but--
The shimmed out "AM06S" with 1.0mm at the bottom is very similar to the AM06 but provides a slightly longer link (this is Mike Gee's setup). I've personally been running super low roll centers in stock / 13.5. I'll be trying that soon in modified on asphalt too.
also -- the A700L (non USA spec) and A700EXL are available at shop.awesomatixusa.com
Old 07-09-2013, 06:25 PM   #3777
JayL's Avatar
Yep, that's why I was asking, trying to decide which kit to buy from you, usa spec or non A700L
I tried the regular A700L, Brandon's AKA BOR, and I can't imagaine a car being more dialed: crazy steering but still stable and he had a slower motor than me but still pulled my car out of every corner.
He sold me and I am sure one other guy, who is selling his other cars in order to buy, in one day
Old 07-09-2013, 06:49 PM   #3778
hanulec's Avatar
LOL
I'm happy to hear that he was making things happen over at SpeedWorld (i'm guessing...)
Old 07-10-2013, 08:02 AM   #3779
syndr0me's Avatar
Trader Rating: 32 (100%+)
A few questions:
What's the right way to remove the outdrives from the spool should I ever need to replace them or replace a bearing?
Any tips for making the gear diff smoother? I've got all the upgraded parts (including metal gears) and it feels a bit tight and notchy. Going to two gears helped some. It seems like the o-ring between the bearings is binding it up a bit.
Really enjoying the build so far. What a marvelously engineered kit.
syndr0me is offline   Reply With Quote
Old 07-10-2013, 08:17 AM   #3780
Originally Posted by syndr0me View Post
A few questions:
2 small gears wont help, it will make the 2 big bevel gears unstable and not sitting probably during high speed. I put 4 gears and shim them all with 0.1mm shim, it reduce the fiction between the small gears and the cage. Put the car in the track for more than 20 flight to get the diff smooth. Now my diff is prefect!!
tinngsmile is offline   Reply With Quote
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
