Old 07-01-2013, 10:16 PM   #3736
hanulec's Avatar
Trader Rating: 23 (100%+)
Originally Posted by AARON YOUNG View Post
I also Tqed both vta and 17.5 this weekend. Lapped the field in vta till a lap car took me out but still won . 17.5 had it and made a mistake and ended up finishing fourth only because I failed on my part. Car was killer again .
i was thinking the awesomatix could probably make a killer VTA car because of the corner speed. keep up the good works on the "left" coast!!
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 07-01-2013, 11:30 PM   #3737
OVA
OVA's Avatar
Trader Rating: 66 (100%+)
Would like see VTA set up sheet thanks
OVA is offline   Reply With Quote
Old 07-02-2013, 02:11 AM   #3738
Suspended
hey guys need some suggestions on the diff..built car..went together great..my problem is with the diff..when I tighten its very notchy and super tight..i built per instructions..made sure deburrred..even ran a whole battery pack switching between holdin rear wheels..thinking it mught break in..i have built many gear diffs..but I have had it apart 4 times now..its still super tight and notchy..any help would be greatly appreciated..im wanting to get this on the track
.....rayzerdesigns.....www.jconcepts.net...
i am cornholio is offline   Reply With Quote
Old 07-02-2013, 04:25 AM   #3739
hanulec's Avatar
If your running plastic gears you need to play with the 0.1mm shims to get it to feel right. Do this without any grease/silicone installed.
If you buy the g05st/g06st combo you just slap the diff together and run it.
Old 07-02-2013, 04:38 AM   #3740
Please be careful at the final 1mm screwing of the AT23 gear case.
All inner gears should be aligned properly to avoid the teeth jamming.
Oleg Babich is offline   Reply With Quote
Old 07-02-2013, 05:30 AM   #3741
josecarlo1129's Avatar
I also read here that was reported by one of the A700 drivers that the combination of g06st and plastic gears (2 and 2) will make it a lot smoother. Haven't tried it yet, though.
Nitro: On-road 1/8: Motonica P81-RS2/Vox/Savox
Off-road 1/8: JQ TheCar/Vox/Savox
Electric: On-road 1/10 TC: Awesomatix A700 EVO/AE BD/Team Orion/Ko Propo
On-road 1/10 F1: 3Racing FGX + RC9394 Carbon Conversion AE BD/Team Orion/Ko Propo
josecarlo1129 is offline   Reply With Quote
Old 07-02-2013, 08:35 AM   #3742
Suspended
There are no shims shown in instruction manual
Old 07-02-2013, 08:39 AM   #3743
Suspended
The only thing I can figure is the 0r03 o-ring is what is making it too tight
Old 07-02-2013, 08:43 AM   #3744
hanulec's Avatar
Your correct.. It isn't in the manual. You use sh01 thin shims behind the big gears
Old 07-02-2013, 09:08 AM   #3745
OR03 is the big O-ring that seals the join between AT23 and AT24.
Do you mean OR05 maybe?
Could you please to measure the outer and the inner diameters of your OR05.
It should be JIS P4 o-ring sizes: 3,8/7,6mm.
Old 07-02-2013, 09:29 AM   #3746
Trader Rating: 49 (100%+)
I'd like to see your VTA setup too. My plan is to make my A700 a VTA car, and see if I can get a newer kit leading into carpet season.
SpeedMerchant Rev7
oceanhighz is offline   Reply With Quote
Old 07-02-2013, 10:25 AM   #3747
Suspended
Ok..measured everything..I ended up playing with shims behind the st 20...2 on at24 side..and 1 on at23 side..feels much better..still a little notchy..but maybe will wear in..thx for help guys
Old 07-02-2013, 01:48 PM   #3748
DS Motorsport's Avatar
Originally Posted by John Doucakis View Post
Curious to know what application would that be?
I had the chance to test my newly built EXL kit with some modifications I made.
It was a good first test.
A bit more info and video in my blog
JD RACING BLOG
Awesomatix with a noisy motor.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 07-02-2013, 02:19 PM   #3749
John Doucakis's Avatar
Are you referring to my car or to your project?
John Doucakis is offline   Reply With Quote
Old 07-02-2013, 02:20 PM   #3750
My project.
P1-RC.com
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
OLD ONE
SEO by vBSEO 3.5.0
