Old 06-19-2013, 12:52 PM   #3676
Ok
Sorry for my poor english
Awesomatix | LRP
Awesoman is offline   Reply With Quote
Old 06-20-2013, 11:51 PM   #3677
Congratulations for Mike Gosvig !
http://www.redrc.net/2013/06/mike-go...ts/#more-67625
Oleg Babich is online now   Reply With Quote
Old 06-21-2013, 07:46 AM   #3678
hi, can we have setup from last ets?
guru83 is offline   Reply With Quote
Old 06-21-2013, 08:26 AM   #3679
The original Stock setup from Viljami
and his setup after corrections for upper AT21 and 3mm chassis:
Old 06-21-2013, 08:53 AM   #3680
thank you, i will try it next weekend!
Old 06-21-2013, 11:15 AM   #3681
Well,
I didn't want to go to the track before being sure everything is ok.
So i checked everything.
Result: 2 springs bent
So i changed all the four to hard ones.
But now, i still have a problem.
At the rear left side, there is almost 2mm play before the suspension begins to work.
It's like there is not enough downstop (5mm), but on the right side, there is no problem...
Does anybody know?
Hope you understand what i mean.
Cheers
Awesomatix | LRP
Old 06-21-2013, 12:36 PM   #3682
Trader Rating: 31 (100%+)
Originally Posted by Awesoman View Post
Well,
Does anybody know?
Cheers
Check the ride height screw or downstop one of those is not touching.
Monti
Monti is offline   Reply With Quote
Old 06-21-2013, 12:58 PM   #3683
hanulec's Avatar
Trader Rating: 23 (100%+)
Since there where two bent spr01s --- What else is bent. Please check to see if these are bent--
Spr02
C04
Disconnect the am06/p04 from the c04. Does the arm move freely??
Does the p01/p02 move freely only the on the st14?
Does the p13 move freely on the st14 when the p01/p02 is disconnected from the am06?
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 06-21-2013, 12:58 PM   #3684
hanulec's Avatar
Dupe..
Old 06-21-2013, 02:15 PM   #3685
Everything moves freely, C04 isn't bent.
I'm not sure if spr02 is bent but i think not.
When i put the car with wheels on it it works normally.
Cheers
Awesomatix | LRP
Old 06-21-2013, 10:04 PM   #3686
hanulec's Avatar
i was building a car for a friend tonight -- and while applying the final setup i noticed the rear end was overly stiff, and had a different feel from left to right. the problem ended up being a binding of the rear toe links and the above set screws holding the upper links. the simple solution was using shorter set screws in my upper links. the car features am19 camber plates.
Old 06-22-2013, 05:40 PM   #3687
Dragobrat's Avatar
Default Wanted to buy
Hi there, I am looking to buy 1x used A700l or ex. Please send me a PM. Thanks.
Dragobrat is offline   Reply With Quote
Old 06-22-2013, 06:55 PM   #3688
gazza's Avatar
Awesomatix USA's new factory driver
Kyle Majikas E-Town posse, Pro One R/C, TQ wire, SpeedMerchant, MC˛ Racing
gazza is offline   Reply With Quote
Old 06-22-2013, 06:58 PM   #3689
Trader Rating: 18 (100%+)
Stunned. Factory is not what it used to be. Look forward to the Wack Packs insight to tuning and setup.
● AWESOMATIX USA ● ABSOLUTEHOBBYZ ● HEBIKI DESIGN WORKS ●
MDawson is offline   Reply With Quote
Old 06-22-2013, 07:08 PM   #3690
Lance C's Avatar
Trader Rating: 52 (100%+)
Is that Larry fairtrace wow he aged
Lance C is offline   Reply With Quote
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
