Old 04-03-2013, 07:37 AM   #3286
KHoff7's Avatar
Originally Posted by Awesoman View Post
Hi all,
I ordered some g05st and g06st gears.
I heard that some people are using only two g06st gears instead of four when using steel gears.
What is better? Using four satellites or just two?
Thx
I am running all 4 steel gears its a bit heavier than plastic, but that only matters in stock. That said, I used this setup at carpet nationals in the stock class and did just fine.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 04-03-2013, 07:56 AM   #3287
Thank you all
And what about the wear compared to the plastic gears? Are you putting shims under the two g05st gears or not?
Awesomatix | LRP
Awesoman is offline   Reply With Quote
Old 04-03-2013, 08:08 AM   #3288
KHoff7's Avatar
Thank you all
I used no shims, it seems like it will go maintenance free for a long time.
Karl Hoffmeister
Old 04-03-2013, 08:15 AM   #3289
hanulec's Avatar
Trader Rating: 23 (100%+)
Originally Posted by EAMotorsports View Post
Looks nice Mike! Glad to see you take the opportunity for Awesomatix USA and its going well!!
See you at asphalt nats???
EA
It is a real learning experience. I cannot wait to start reaping the benefits of racing the car in the track..
We missed u at the carpet nats.. Once my vacation is approved I'll make the rest of my arrangements
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 04-03-2013, 08:16 AM   #3290
hanulec's Avatar
Karl - are you running steel g05 and g06 (total of 6 gears)?
Old 04-03-2013, 08:18 AM   #3291
Team EAM
EAMotorsports's Avatar
Trader Rating: 73 (100%+)
Send a message via AIM to EAMotorsports
I know what you mean! Im sure you'll do well with it though as its already starting to show with good results at the Carpet nats.
Me....naaaa....I would have just been more lapped traffic for you guys!
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID | Futaba.
EAMotorsports is offline   Reply With Quote
Old 04-03-2013, 08:25 AM   #3292
Jon Williams's Avatar
EA
Oh, man. EA, you and Scooby Horton gotta be brothers from another mother.
Some of the gems Scoob gives us weekly:
'Nah, man. Williams, you so faaast. My s**t is slloooow. I'm just in your way.'
'Pssst, Williams. What shock oil you running? You running antidive?'
'Hanulec, that car is FAAST! My car is so slooow. Wish I could get me some motor like that.'
Jon Williams is offline   Reply With Quote
Old 04-03-2013, 09:41 AM   #3293
KHoff7's Avatar
yes
Karl Hoffmeister
Old 04-03-2013, 09:48 AM   #3294
hana166's Avatar
Thank you all
First assemble the diff dry, with the gears you intend to use. Shim 0.1mm one side and reassemble. If its too tight, take it out. If not then shim the other side as well. again, if too tight, take it out. And so on..I go through the process each time to get it spot on, if I have time.
The ideal is to have the gears mesh as tight as possible to prevent excessive wear or premature failure, but avoiding binding. This keeps it smooth as possible under load.
hana166 is offline   Reply With Quote
Old 04-03-2013, 10:02 AM   #3295
Thumbs up
Thanks! I will do it this way
Awesomatix | LRP
Old 04-03-2013, 02:56 PM   #3296
hello, i want to listen to some guggestions about the type of chassis, originally y bought the exl version, i only run in asphalt, my car goes fine, i only use the motor in longitudinal mode, my question is: wich chassis do you think goes best, the EXL o the L one.
thanks
Christian
osorron is offline   Reply With Quote
Old 04-03-2013, 06:51 PM   #3297
gwhiz's Avatar
thanks
Christian
http://www.rctech.net/forum/11623614-post2810.html
http://www.rctech.net/forum/11722247-post2946.html
x
gwhiz is offline   Reply With Quote
Old 04-04-2013, 09:15 AM   #3298
san.'s Avatar
Trader Rating: 59 (100%+)
If you live in the NY/NJ/CT/PA/MD/VA area, there will be 3 Awesomatix drivers and Awesomatix USA (Mike Hanulec) at our event this Saturday, April 6th.
Come join us and see the A700 in action. Here's the link for more info.
Critters Onroad Trophy Race - New Jersey April 6th 2013
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 04-04-2013, 04:21 PM   #3299
thanks gwhiz!!!!!!!!
Old 04-05-2013, 06:34 AM   #3300
Hello oleg,
could you check your mail box , i had send you mail about problem with C04 that i had ordered.
jeje76 is offline   Reply With Quote
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 Yesterday 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
