Awesomatix EP Touring Car (A700 Shaft Drive) >
Like Tree143Likes
Old 03-12-2013, 07:51 AM
  #3181
G-rem's Avatar
Nobody knows where I can find the setup sheet of Viljami at the last ETS Race in Gran Canaria?
Thanks,
G-rem
G-rem is offline
Old 03-12-2013, 08:53 AM
  #3182
Trader Rating: 27 (100%+)
Good luck to Awesomatix USA & drivers at this weeks ROAR Nationals. The track is looking really good.
Too bad we cant run our one ways or overdrive
MDawson is offline
Old 03-12-2013, 08:55 AM
  #3183
KHoff7's Avatar
Originally Posted by MDawson
Next stop Pennsylvania to visit with cousin Karl, cousin Gee, Uncle FJ & the rest of the R/C hooligans!
Awesomatix to the Nats!
How many are you bringing?!
KHoff7 is offline
Old 03-12-2013, 09:09 AM
  #3184
One for each seat of the rental car!
MDawson is offline
Old 03-12-2013, 10:25 AM
  #3185
KHoff7's Avatar
Has anyone tried the new AM26
KHoff7 is offline
Old 03-12-2013, 10:48 AM
  #3186
Thanks,
G-rem
Viljami says that his setups were not perfect for low grip conditions of Gran Canaria.
He did not have enough time on this track with these new Ride Rex 34 tires for good preparation.
Viljami's setups are attached herewith.
File Type: pdf
File Type: pdf
Oleg Babich is offline
Old 03-12-2013, 11:59 AM
  #3187
G-rem's Avatar
Thank you very much Oleg, will try this at my local track ;-)
G-rem is offline
Old 03-12-2013, 01:16 PM
  #3188
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Note the AwesomatixUSA banners on the back wall . 7 banners up already. Awaiting 6 more for lucky (?) #13 in total.
hanulec is offline
Old 03-12-2013, 03:18 PM
  #3189
AwesomatixUSA's Avatar
Stock order placed. Should arrive right after the ROAR Nats next week..
AwesomatixUSA is offline
Old 03-13-2013, 05:28 PM
  #3190
geeunit1014's Avatar
Trader Rating: 14 (100%+)
See everyone going to nats tomorrow!
geeunit1014 is offline
Old 03-13-2013, 09:36 PM
  #3191
You'll be amazed how packed the joint is!
MDawson is offline
Old 03-14-2013, 09:06 AM
  #3192
Why can't you run one ways? The awsomatix has a 2 speed tranny available?
Juan Aveytia is offline
Old 03-14-2013, 08:24 PM
  #3193
hanulec's Avatar
The boys are running well at the Nats. Looming very fast for 3 laps... Now let's do it for 6 minutes
hanulec is offline
Old 03-15-2013, 11:32 AM
  #3194
Congratulations to Korgae Scales!
Korgae won the stock 17.5 class of Round #5 of the WCICS series races (Canada).
The setup is attached.
Korgae reports that car was amazing to drive.
Old 03-17-2013, 03:41 PM
  #3195
After rebuilding and setting up my car this weekend I've noticed that it has bump steer on the rear of the car, in my case the toe increases as the suspension is compressed. Is it just a matter of tuning this out with more shims on the rear steering link. It would be nice to run a low toe in setting for extra speed on the straights but if I'm thinking correctly when the car leans into a turn the extra toe would only be on one side of the car so not good. Most setups I see use a 2mm shim which gives the situation I have.
vwvrt is offline
