Old 02-25-2013, 10:03 PM   #3076
Nemo racing's Avatar
Send a message via Yahoo to Nemo racing
Originally Posted by Oleg Babich View Post
Congratulations to Tony Tam (USA) !!!
Tony won No Boost class with A700 car at TITC 2013.
https://www.facebook.com/pages/HKS-H...C/257004281092
First off Thank you Oleg for designing such a good performace car.
It was easy to drive and adapt to the track changes very well.
Also I like to thanks Scotty and my friends for support.
Once I get back to the State, I am looking forward to race more with the A700
Thank you and see you at the race track
A800
Scorpion Power System
Nemo racing is offline   Reply With Quote
Old 02-25-2013, 10:19 PM   #3077
Kevin CBR's Avatar
Congratulations Nemo ! Great to see a local Southern California driver and friend win at such a prestigious International race. Especially with as little time you had with the car. Is it even a month old yet ?
Panda
Panda Performance / Nemo Racing top secret R&D lab hidden in a lush bamboo forest....
Kevin CBR is offline   Reply With Quote
Old 02-26-2013, 10:55 AM   #3078
masterhit's Avatar
Trader Rating: 14 (100%+)
Originally Posted by EAMotorsports View Post
Good job Mike. Glad to see you finally got a good run in!
EA
Thanks guys!
It was definitely a learning experience dealing with that much bite, even more so than last year at The Gate. I finally got the tire prep right for the third (and final) qualifier and tried my best to wrestle TQ from you EA, but it went up in flames. Literally!
Let me know when to send what's left of that motor in for warranty work (I jest)!
The car makes it easy, and I know the EAM pack and rotor helped too.
Mike Slaughter
masterhit is offline   Reply With Quote
Old 02-26-2013, 02:19 PM   #3079
OVA
OVA's Avatar
Trader Rating: 67 (100%+)
Question
Well how close can you get with all the electronics and batteries balance between two sides and front and back of the car?
OVA is offline   Reply With Quote
Old 02-26-2013, 04:46 PM   #3080
Trader Rating: 18 (100%+)
Originally Posted by OVA View Post
Question
How well close can you get with all the electronics and batteries balance between two sides and front and back of the car?
My cars are usually L50%/R50% and F48%/R52%
● AWESOMATIX USA ● ABSOLUTEHOBBYZ ● HEBIKI DESIGN WORKS ●
MDawson is offline   Reply With Quote
Old 02-26-2013, 05:08 PM   #3081
hanulec's Avatar
Trader Rating: 23 (100%+)
I had to add 80g of weight onto my A700L to make 1380.
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 02-26-2013, 05:22 PM   #3082
haywood's Avatar
Trader Rating: 47 (100%+)
Default Awesomatix
Micheal,
When do you plan to be up and running with product and website? I have Rubles burning a hole in my pocket!
/ Roche Rapida 2015-2016 / Hobbywing / Team Scream / Rc Painting By Mikey / Ko Propo / MMR / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 02-26-2013, 05:35 PM   #3083
OVA
OVA's Avatar
wow thta's pretty good Mark..Are you using the 4 scales set up ?
is the before the ride height adjustment made?
Old 02-26-2013, 07:41 PM   #3084
gwhiz's Avatar
I think it would be great if corner weights were added to the setup sheet.
x
gwhiz is offline   Reply With Quote
Old 02-26-2013, 08:01 PM   #3085
hanulec's Avatar
Originally Posted by haywood View Post
Micheal,
burning a hole, huh?
i was working on my cart tonight. looks like i'm going to have roughly 85 products available upon receipt of my first order. the plan isn't to allow for product back orders ... although that could change.
Old 02-26-2013, 08:27 PM   #3086
Wow. Including the spray bomb special? Considering that the bodies weigh 90-100 grams and your add-on of 80 grams - you have a 1200 gram car?
What are is your running gear now?
Without a body I am at 1270 with L chassis, 17.5, orca, ko servo, 228 lipo pack, fan and transponder.
4 scale setup in race trim
You have a good start of a bigger idea...
Would be interesting to see a second page to the setups that provided more technical notes like;
- corner weights
- graphing of current dampener rate to show the approximate softer and harder spring rates & dampening rates from the current setting.
Surely more to add.
Old 02-26-2013, 09:07 PM   #3087
hanulec's Avatar
dawson- my A700L has in it a Spektrum S6040, Orca VX, Trinity D3.5 17.5, Sanwa RX-471, MRT transponder.
hopefully folks will like the new logos-
Old 02-26-2013, 10:26 PM   #3088
OVA
OVA's Avatar
look great...XL please
Old 02-26-2013, 10:30 PM   #3089
OVA
OVA's Avatar
- corner weights
Surely more to add.
got it 50/50 finally for some reason I had a tweek ...now it is perfect.Thanks mark
Old 02-26-2013, 10:33 PM   #3090
My protoform lightweights (LTC-R, Speed 6, P37) have always come out right around 85g painted, with Faskolor, before they start accumulating clag. I have one I painted with Tamiya spraycan in Hong Kong I should weigh. It's translucent red.
Battery?
-Mike
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17189 Today 03:25 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
