Old 02-11-2013, 12:42 PM   #3016
Originally Posted by John Doucakis View Post
Short update in my blog.
Did some proper testing on Saturday and ended up with a pretty nice car.
On Sunday there was a club race where I TQed had the best 5min run and lap record (faster than 1/10 ic cars)
More in my blog
JD RACING BLOG
I've also posted a short video. I start to push after the 3rd lap until later on I step on a paddle of water and spin off bigtime!
In the video I run old tyres and laptimes are around 20.3 - 20.5. Next day I did 19.7 on new tyres.
John, what setup did you use during this race?
Oleg Babich is online now   Reply With Quote
Old 02-11-2013, 12:52 PM   #3017
John Doucakis's Avatar
I need to make some measurements on my droop settings and will post it soon.
Briefly I will mentioned that again I ended up using ball diff, full tight by hand force (I am not Arnold but it still is quite tight) and 1.000 cst Hudy oil. The diff has stayed consistent and smooth after more than 20 runs. It is incredible.
Std shocks and springs of original car, L chassis, Motor moved forward by adding 3mm shims between motor case and motor mount.
More details on the set up sheet.
Track had medium traction yet the car never felt unstable.
John Doucakis is offline   Reply With Quote
Old 02-11-2013, 01:27 PM   #3018
Magnet Top's Avatar
Congratulations Mark !
I was able to "watch" your race on LiveRC via live laptime streaming. Nice win!
Cheers,
Jake D.
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 02-11-2013, 01:48 PM   #3019
Trader Rating: 18 (100%+)
Cheers,
Jake D.
Thanks Jake. Forgot the race was on LIVERC. At some point in that race I decided that race pace wasnt important anymore. Plenty left in the tank to turn fast laps if needed.
● AWESOMATIX USA ● ABSOLUTEHOBBYZ ● HEBIKI DESIGN WORKS ●
MDawson is offline   Reply With Quote
Old 02-11-2013, 07:30 PM   #3020
Congrats M. Dawson ! Many more wins to go..... It's the best chassis design ever.... Anyway to get a real car designed like that with a porshe type flat six engine ?????
bertrandsv87 is offline   Reply With Quote
Old 02-11-2013, 09:08 PM   #3021
OVA
OVA's Avatar
Trader Rating: 66 (100%+)
Awesome win buddy..I wish I was there to watch...
OVA is offline   Reply With Quote
Old 02-11-2013, 10:49 PM   #3022
Thanks! Enough motivation now to pack up the race program and head to the carpet nats!
TQ should be posting the video tomorrow.
Old 02-11-2013, 11:33 PM   #3023
Default ROAR Carpet Nats!
I wanted to get a headcount of how many Awesomatix entrants are registered for ROAR Carpet Nats. If you are entered, please let me know and your the class you are entered. Thanks.
Old 02-12-2013, 12:26 AM   #3024
Setup from Mark Dawson is here now: http://awesomatix.com/download/
Please see the roll centers and camber gain picture also.
Video from A-Main Final:
+ YouTube Video
Old 02-12-2013, 01:10 AM   #3025
Damon's Avatar
Congratulations Mark!!!
Awesomatix A800
Awesomatix A800AH
Damon is offline   Reply With Quote
Old 02-12-2013, 05:26 AM   #3026
Setup and roll centers from John for your attention.
Please note low roll centers, floating top deck, longer wheelbase, forward battery position and asymmetric front dampers.
File Type: pdf Duke Asphalt FRT 'EXL' chassis SET2-1.pdf (315.0 KB, 127 views)
Old 02-12-2013, 06:58 AM   #3027
geeunit1014's Avatar
Karl and I are in for 17.5tc
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 02-12-2013, 02:04 PM   #3028
CraigM's Avatar
Trader Rating: 34 (100%+)
Hi Oleg,
I've been experimenting with the rc crew chief software & I wanted to know your thoughts on setups with camber loss. I notice both John and M Dawson's setups have a small amount of camber loss, as do a number of setups for other chassis - do you think it is desirable to have some camber loss, particularly in the rear which seems most common?
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 02-12-2013, 02:26 PM   #3029
Originally Posted by CraigM View Post
Hi Oleg,
Camber loss occurs in case of you are trying to move roll center more and more down.
At some conditions you can get more benefits from such very low roll center despite of some camber loss.
You can compensate this camber loss by means of the increasing of initial camber. For example in John's setup the camber loss is compensated by 2 deg initial camber.
I think that it is very important to have the optimal actual camber on the outer wheels at the stage of maximal side roll ( the stage of maximal side traction). And you can acheive this optimal camber even with the negative camber gain at correct adjustment of the initial camber.
Old 02-12-2013, 02:52 PM   #3030
hanulec's Avatar
Trader Rating: 23 (100%+)
Oh snap -- that is a big "win" for awesomatix. You two kids are fast.
Maybe its time for an awesomatix USA
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
