Old 01-01-2011, 07:03 AM   #286
Originally Posted by zoomster View Post
... how do you adjust for tweak on the rotary shockers,and how do you adjust for tweak on the roll bars...
Each shock has a special adjusting screw for for ride height/tweak setup.
Our roll bar's system is simple and straightforward and has very short joint members.
If you will keep our roll bars flat there will be no tweak due to roll bars.
In addition it is possible to use thin shims under sway bar holders for very precise tweak adjusting.
Oleg Babich is offline   Reply With Quote
Old 01-18-2011, 05:13 PM   #287
Trader Rating: 18 (100%+)
Hi Oleg,
Any new developments on this car? Is the release date still soon?
poop is offline   Reply With Quote
Old 01-19-2011, 11:48 AM   #288
poop,
We are remaking some parts now so they will match the overall high level of reliability of the entire car better.
Old 01-19-2011, 04:18 PM   #289
Originally Posted by Oleg Babich View Post
poop,
With that in mind was your previous release date still expexted to happen?
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 01-19-2011, 11:53 PM   #290
We make all our efforts now to start in February.
Old 01-20-2011, 12:19 AM   #291
Thats what you told me (beginning of feb). Are spare parts going to be available with the 1st order? I would prefer some basics (lower arms, knuckles/uprights, ball cups/ends etc..) to ensure brain fade doesn't send me home early.
Powered by Falco
Old 01-20-2011, 03:30 AM   #292
AdminD's Avatar
Oleg..
why is the awesomatix kit returned to the rear Motor as previously tc4,
and why not the centered motor ones ?
and where we can get this centered motor kit ones ?
Sliders
AdminD is offline   Reply With Quote
Old 01-20-2011, 03:47 AM   #293
A Ilievski's Avatar
Trader Rating: 39 (100%+)
Originally Posted by AdminD View Post
Oleg..
Theres a option in the kit to be able to use either motor positions, all this will be standard in the one kit.
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIGE BEARINGS*
A Ilievski is online now   Reply With Quote
Old 01-20-2011, 05:22 AM   #294
Oleg..
AdminD,
What do you mean under "centered motor"?
Motor's orientation only or smth else?
Two orientations of motor are possible in one kit now ( kid TT-01, thanks).
It takes several minutes to change this.
Old 01-20-2011, 07:14 AM   #295
snoopyrc's Avatar
That is the bomb! I hope this kit does well. It is certainly the most innovative kit anyone has seen in a while.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 01-24-2011, 03:40 AM   #296
Oleg... If you don't mind me asking... How long is it between the pivot points in the lower arms perpendicular to the chassis? (In other words if this car used hinge pins in the same position as the current pivots, what would the gap be between the inner and outer lower arm hinge pins?
Powered by Falco
Old 01-24-2011, 06:49 AM   #297
Dragonfire,
I hope it is what you want to know.
Old 01-24-2011, 10:09 PM   #298
Dragonfire,
Yeah that is excatly it... Interesting that the effective lower arm length is not different to the average TC, however the hinging points are considerably further towards the center of the chassis (opposite of all the latest chassis on the market). Is there a particular reason for this? Kinda seems like a way to have a chassis that grips like a narrow track but perhaps with the stability of a wide track? Best of both worlds?
Powered by Falco
Old 01-24-2011, 10:37 PM   #299
Dragonfire,
It is the compromise taking into account many factors.
There are additional holes on the lower deck for shorter optional lower arms.
Old 01-25-2011, 12:23 AM   #300
Dragonfire,
I have had a few TC's that use quite long arms, like the Atlas YM-34si and the Barracuda (arms mounted the same as Awesomatix with less than 5mm gap between the arms!). I have found them to be very quick everywhere with excellent side bite on even low grip tracks. So my preference is the longer the better unless lap times say otherwise.
Since its late Jan now, is there an official release date yet?
Powered by Falco
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
