Old 01-07-2013, 07:12 PM   #2851
Originally Posted by masterhit View Post
There is section 6.2. The only problem I can foresee is that depending on wheel spacers (or different track widths) they are really close to being past the tire edge. I did have some different widths cut.
6.2 BUMPER RULES
6.2.1 Bumpers are not required in all classes, but when used, they must be shock absorbing and non-metallic, with no sharp edges. For safety, rigid bumpers, such as fiberglass and composites, are not permitted.
6.2.2 Front bumpers must be of at least 1/8 material (3/32 for 1/12). Bumpers will not extend forward of the body except on off-road cars. The bumper may not extend to the side beyond the outer edge of the tires.
6.2.3 Rear bumpers must be made of a solid material with rounded edges and may not extend to the side beyond the outer edges of the tires, and may not extend beyond the rearmost part of the body except in off-road vehicles.
Those are the ones I was thinking of. I guess it's open to interpretation what exactly "sharp" and "rigid" mean. Delrin is pretty damn hard.
-Mike
Old 01-07-2013, 08:05 PM   #2852
hanulec's Avatar
Trader Rating: 23 (100%+)
Originally Posted by Magnet Top View Post
Great to see you got an Awesomatix, Mr.Hanulec. I'm trying to make it to the Roar Carpet Nats... so may see you in a couple months.
Cheers,
Jake D.
I'm just trying to keep myself with one A700 for now
Hope you can make it out. Stock and super stock will have one of the deepest fields in the USA..
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 01-08-2013, 01:06 AM   #2853
Video from LRP-MCSS-OPEN 2013 with Dionys's and Max's cars:
Dionys starts from 2nd here: http://www.twins-racing.de/video/lrp-mcss-open-2013.htm
Max starts from pole: http://www.youtube.com/watch?v=UeZdU...vLKLZYzQxvVL4Q
Oleg Babich is offline   Reply With Quote
Old 01-08-2013, 03:43 AM   #2854
Another win for Awesomatix, and me :-) ... in Canada this time ! ...
Jake D.
Congratulations to Jake, Frank and Korgae too!
Old 01-08-2013, 08:18 PM   #2855
Congrats guys !!!!! Got my A700EX today ! Thanks Oleg for putting up with me.....ahahah....
bertrandsv87 is offline   Reply With Quote
Old 01-10-2013, 03:28 PM   #2856
Oleg,
when do you expect to have AM06S back in stock?
malkiy is offline   Reply With Quote
Old 01-10-2013, 11:56 PM   #2857
Originally Posted by malkiy View Post
Oleg,
In a few days.
Old 01-11-2013, 06:12 PM   #2858
Smile
Oleg, is the spur gear only held by pressure in the transverse layout ??? If so, is the pressure great enough to hold under mod motor treatment ???
Old 01-11-2013, 07:56 PM   #2859
erchn's Avatar
The metal gear that attaches dig into the spur a bit when tightening the nut. Tighten it quite a bit, don't use threadlock.
Works fine when I ran a 4.0.
erchn is offline   Reply With Quote
Old 01-11-2013, 08:20 PM   #2860
You mean the metal gears teeth are the only thing holding the spur gear or does the nut pressure also contribute ??? But not a pin through the spur gear though ???
Old 01-11-2013, 08:28 PM   #2861
I guess tire traction will probably never overcome the 12mm nut's pressure... Beats me, but I will make sure to tighten the nut well... Thanks....
Old 01-11-2013, 08:57 PM   #2862
erchn's Avatar
Yea, it's a bit weird, but it does work if tightened well. If your spur is narrow you'll need to find a spacer, I used one from TOP.
Old 01-11-2013, 08:59 PM   #2863
No problem, thanks......
Old 01-11-2013, 09:15 PM   #2864
OVA
OVA's Avatar
Trader Rating: 66 (100%+)
question
AM06S what most of the driver perfer them for high grip condtion..I know the letter S stand for short,,but what is short ? shorter camber links or wheel width?
OVA is offline   Reply With Quote
Old 01-11-2013, 09:22 PM   #2865
gwhiz's Avatar
Originally Posted by OVA View Post
question
"~1mm shorter distance between wheel axis and the lower ST03 ball".
Check page 39 of the EXL manual.
x
gwhiz is offline   Reply With Quote
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
