Old 12-18-2012, 07:28 AM   #2731
Trader Rating: 24 (96%+)
I have some extra parts left over from my a700, the first original version, I have a brandnew gear diff, new ias steering assembly, new front arms x2 complete assembly, and extra bearings and end links and tie rods a whole bag of first aid things for this car, let me know if anyone is interested, paypal only will ship also, price is best offer on everything, thanks
zaraz is offline   Reply With Quote
Old 12-18-2012, 12:00 PM   #2732
Magnet Top's Avatar
Originally Posted by hana166 View Post
Simply cannot beat a ball joint reamer. Easy and it allows you to adjust it super precise then you can do all the joints the same in a minute. Its a regular tool for heli guys
Thank you Mark and Hana ! It's on my Christmas list now !
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 12-20-2012, 09:41 AM   #2733
Trader Rating: 1 (60%+)
i am looking for an a700. i have a yokomo bd7 which i used in one single race. i would be happy if someone who wants to trade send me a pm about it.
cico is offline   Reply With Quote
Old 12-22-2012, 04:05 AM   #2734
G-rem's Avatar
Hi guys,
I currently run on the L version of this fantastic car.
I'd like to buy some stuffs as Christmas gift and I'm asking questions about some optionnal parts:
-how and when use AM18-1? How does it affect the behaviour of the car?
-same questions for damper #3?
-AM26?
-AT21S?
-AT28?
-C06?
-ST24?
-A700-IAS and AM20?
-How better are P18/P19 than original P01/P02?
Thanks a lot,
G-rem
G-rem is offline   Reply With Quote
Old 12-24-2012, 03:27 AM   #2735
G-rem's Avatar
Originally Posted by G-rem View Post
Hi guys,
-AM26?
-AT21S?
-AT28?
-C06?
-ST24?
-A700-IAS and AM20?
Thanks a lot,
G-rem
No one to help me with some explanations?
Old 12-24-2012, 12:26 PM   #2736
Hi guys,
-AM26?
-AT21S?
-AT28?
-C06?
-ST24?
-A700-IAS and AM20?
Thanks a lot,
G-rem
Hi G-rem,
AM18-1 - for shortening of the upper arm. It increases the camber gain at up travel of suspension and reduces the roll of car also.
AM26 should be used with AM06S on the rear suspension. It gives the possibility to have very low roll center at still good level of camber gain.
AT21S has 0.5mm lower ball height than AT21. It extend the range of roll center setting.
AT28 - precise metal axis for 10T gears inside of geardiff.
C06 - carbon version of AM19 for old A700 cars. I don't recommend it for A700L and A700EX cars.
ST24 - steel replacement of AT21 for suspension's links. ST24 has 0.7mm lower ball height than AT21 and provides increased operation angle for P13 ball ends.
A700-IAS provides increased Ackermann setting but reduces max steering angle.
AM20 should be used as the component of A700-IAS.
P18/19 are shorter than P01/P02. Material of P18/19 is more hard and fragile.
Oleg Babich is offline   Reply With Quote
Old 12-24-2012, 06:27 PM   #2737
G-rem's Avatar
Thank a lot for that detailled explainations Oleg, and thank you very much for having done this master car
Old 12-24-2012, 11:24 PM   #2738
Merry Christmas and Happy New Year!!!
According to requests from drivers we are introducing new version of A700EX kit.
A700EXL is the special version of A700EX kit without the parts for transverse motor layout.
A700EXL kit doesn't include:
AM02
AM04
AM13
ST06
C03-1
G01
G02
B84RS x2
All others parts are the same as in A700EX kit.
http://shop.awesomatix.com/index.php...&productID=917
Old 12-24-2012, 11:33 PM   #2739
hacker's Avatar
Trader Rating: 139 (100%+)
I know this has been beaten to death before but im having probs with the search feature on my phone.
Someone please give a short description of the 3 kits available. Looking at another TC for mod.
Thanks in advance
hacker is offline   Reply With Quote
Old 12-25-2012, 12:15 AM   #2740
Magnet Top's Avatar
Thanks in advance
Hey Hacker,
Sorry, I don't do short !
The A700 is the very first product from Awesomatix ( released over a year ago )
The A700 EX and A700 L are the latest models. The EX can be used in the transverse motor configuration as well as longitudinal motor configuration. Whereas the L cannot be used in transverse motor configuration.
The EX and L's bottom deck differs from the original A700 in that it has cuts to allow more flex with the ability to use optional parts to stiffen it up to be similar to the original A700's stiffness. The EX and L also have counter bores for greater adjustment of lower A-arm position ( up to .5mm lower ) for lower roll center. Also, the EX and L can use the optional one piece "floating" servo mount whereas the original A700 cannot.
There are other differences but those are the most dramatic differences between the two new models ( EX and L ) compared to the original A700.
The L version has these main differences from the EX version. Narrower bottom deck , so it does not rub as much as the EX when rolling. Also different flex characteristics because the A700L is narrower and there is no recess for motor clearance because it does not allow transverse motor configuration.
I also believe the L ships with soft springs standard whereas the EX has the original standard springs. I'm actually not 100% sure what the EX ships with. Other than that, I believe there are minor differences.
I'm very happy with the L version. At least for me, so far on carpet , I have not felt the need to use the car in Transverse motor configuration and it costs less than the EX version. I am told that the EX chassis can be easier to drive in Mod ( in LONG motor mode ! ) but I've been running a 4.5 and 5.0 with the L and have been happy so far.
I would consider buying the L and later, if you feel the need, getting the optional EX bottom deck when they become available again.
Only thing I can suggest is to order the standard springs if you order the L version. I've been using them instead of soft springs that come with the L kit. This is in Stock and Mod.
Also consider AM26 and AM06S and AM18-1. They are nice tuning options. Also, if you are running mod, get the optional metal gear diff gears.
(Edit ! I did not notice that Oleg posted above about the very new EXL configuration )
Hope that helps,
Jake D.
Old 12-25-2012, 01:23 AM   #2741
Thanks a lot, Jake!
Both SPR01 standard springs and SPR01S soft springs are included in A700EX and A700EXL kits.
Old 12-25-2012, 03:28 AM   #2742
G-rem's Avatar
AM02
AM04
AM13
ST06
C03-1
G01
G02
B84RS x2
So, what are the main difference between the EXL kit and the actual L kit?
Old 12-25-2012, 03:48 AM   #2743
hana166's Avatar
I haven't run transverse for a year.. I found the car changed direction slower as the mass is less central, which wasn't good for tight chicanes on carpet. But, apart from that, does anyone think there is an advantage to using this orientation, or perhaps certain situations where it is the best option?
hana166 is offline   Reply With Quote
Old 12-25-2012, 07:42 AM   #2744
I also run transverse mode using a 4T motor in a high speed big and wide track, the motor temperature is a lot lower than using longitude mode with the same motor. Lower temperature result longer powerful time.
tinngsmile is offline   Reply With Quote
Old 12-25-2012, 10:01 AM   #2745
Magnet Top's Avatar
Do you feel the lower temperature is because airflow to the motor is better in transverse mode ?
Jake D.
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10911 11-28-2016 07:09 AM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
