Old 11-20-2012, 12:53 PM   #2641
Originally Posted by ale.pac View Post
Damn it! So I installed my dampers in the wrong way
DL6 in front left tyre, and DR6 in the front right. Do you think it could have caused damages? ...
Please don't worry.
The arrangement of L and R dampers influences only on the operation at asymmetric mode and can't damage the dampers.
Oleg Babich is offline   Reply With Quote
Old 11-20-2012, 06:11 PM   #2642
Default to buy or not to buy??
There's no doubt that this car is an absolute work of art that more closely resembles a pan car than any other touring car available on the market today.
My only concern is the durability.
Can this car survive light crashes to finish races?
What is recommended for small/tight high grip carpet track A700EX or A700L?
Why did the price of the A700L drop so much? How was is cheapened?
Does the car come with front spool and rear gear diff?
What are the must haves in terms of tuning/option parts? In other words, how much more money should I prepare to spend to get this car to be competitive?
These are only a subset of the questions that I have in my mind at this time. If I haven't annoyed you guys already, I may just as a few more.
Appreciate everyone's support.
Thanks!
mhavlena is offline   Reply With Quote
Old 11-20-2012, 07:08 PM   #2643
erchn's Avatar
Yes, it's fine.
If you run the A700L in longitudinal mode you'll find alot more setups, and it does switch direction quicker.
It wasn't cheapened, it just doesn't have parts to switch the motor to the traditional direction.
The manual answers this, and yes.
The car is competitive out of the box, all option parts are truly optional and probably have very minimal gains (like the central servo mount). Some spares will be desired as with any car, but nothing dramatic. I would budget 10% over car price.
Thanks!
Questions are fine, but a little bit of search on rctech (especially using "<search text> site:rctech.net" on Google) will yield many answers.
erchn is offline   Reply With Quote
Old 11-20-2012, 07:54 PM   #2644
daktulos's Avatar
Hey Michael ! I can even make a little contribution if you bring one at our track
daktulos is offline   Reply With Quote
Old 11-21-2012, 01:44 AM   #2645
Tof
Hello,
I try to mount the speed passion Reventon Pro on a A700L. What made you a clean intallation? The ESC is bigger, have you a pics?
Thanks,
Chris
Tof is offline   Reply With Quote
Old 11-21-2012, 03:52 AM   #2646
Hello Alex!
I might just take you up on that offer!!..
BTW, congrats on your new arrival..!!
Talk soon!!
Old 11-21-2012, 04:01 AM   #2647
Originally Posted by erchn View Post
Yes, it's fine.
Appreciate the elaborate responses...thanks!!
Is the instruction manual available online? Found that you could purchase it..or perhaps I didn't look hard enough?
Thanks!
Old 11-21-2012, 05:13 AM   #2648
Nico''s Avatar
Originally Posted by Magnet Top View Post
ST24 is a shorter ball-end ( it is .7mm shorter than the standard kit ball studs )
thus it allows greater height adjustment range of camber and caster links.
Hi,
thanks a lot for your reply, so maybe it can allow to put Xray shock ball joint?
about damper 6 , 3 and the old ones, what is the order in viscosity please?
about P18/19 S are they just shorter or for stronger fixation?
I read on set up sheets, AM24 centered or offset, does it mean where is two way to fix AM24 ( I didn't see that in the manual)
About AM18-1 and AM26, how do these option work please? what do they give to the car on the track please?
Thanks a lot for all the explanations,
Nico'
Nico' is offline   Reply With Quote
Old 11-21-2012, 08:11 AM   #2649
ropezz's Avatar
A700 for sale
ropezz is offline   Reply With Quote
Old 11-21-2012, 11:45 AM   #2650
Thanks!
Please download it from:
https://dl.dropbox.com/u/43565480/A7...NSTRUCTION.pdf
Old 11-21-2012, 01:11 PM   #2651
Magnet Top's Avatar
Replies in Red.
Originally Posted by Nico' View Post
Hi,
Maybe! , but use of open ball cups would be advisable for easy fixation and removal ...
I believe the old one and 6 are basically the same viscosity and function the same. The optional 3 is half of 6 viscosity but I cannot answer for sure
I haven't used them nor ever seen them
Yes, the AM24 can be mounted centered or offset
They change the camber link position changing roll center and camber gain as well as active caster effects. I recently experienced more off power steering than I wanted using Viljami's setup and intend to try longer camber links in the rear, as suggested by Freddy. AM18-1 allows more camber link lengths while AM26 allows shorter links and at a different angle.
Hope it helps.
Nico'
Jake D.
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 11-21-2012, 04:35 PM   #2652
Nico''s Avatar
Replies in Red.
Jake D.
Thanks for all!
Old 11-22-2012, 07:21 AM   #2653
pchroma24's Avatar
Trader Rating: 73 (100%+)
A700 for sale or trade... too many cars lol!!
Tekin, Hudy, WTS/WTT Awesomatix
If you can't explain it simply, you don't understand it well enough... Einstein
pchroma24 is offline   Reply With Quote
Old 11-22-2012, 08:28 AM   #2654
theatriks's Avatar
I don't think anybodies buying used awesomatixs anymore ...I Remeber at the beginning of the year they wouldn't last a day in the for sale section ...now there's like 5 for sale here and mine has been for sale for 2 months on here .....wild how things change in a matter of months.
theatriks is offline   Reply With Quote
Old 11-22-2012, 09:00 AM   #2655
Perhaps it will be interesting for collectors to know -
only 222 kits of А700 car were produced for the whole world.
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17189 Today 03:25 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
