Old 11-17-2012, 10:01 AM   #2626
Our congratulations to Gabriele Vignolini !
Gabriele won the Italian Indoor Nationals in Stock 13.5 (Rc-Landia - Scandiano).
You can find very interesting setup of Gabriele's A700L for Sweep tires here: http://awesomatix.com/download/
Oleg Babich is offline   Reply With Quote
Old 11-17-2012, 01:07 PM   #2627
Originally Posted by theatriks View Post
So i looked over everything and im not having any problems with po1 po2 or po4....the problems im having are the arm itself is popping off the at21 balls that are mounted on the chassis everytime i tap a board .......everything else stays together.......if theres a fix for that !...let me know.
The main rule for P03 - press fresh P03 on the AT21 balls first and put the lower arm on these P03 after that.
Please check are you doing it in that manner?
Old 11-19-2012, 10:05 PM   #2628
According to numerous requests:
Pro Stock ETS 2013 Rd1 setup from Dominic Vogl
Old 11-19-2012, 10:20 PM   #2629
Nico''s Avatar
Hi OIeg,
Who is distributor for France please?
best regards,
Nico'
Nico' is offline   Reply With Quote
Old 11-19-2012, 11:40 PM   #2630
Originally Posted by Nico' View Post
Hi OIeg,
best regards,
Nico'
Nobody still.
Old 11-20-2012, 12:09 AM   #2631
Nico''s Avatar
Originally Posted by Oleg Babich View Post
Nobody still.
so I can order in Germany please? http://www.rccar24.de/artikelueber.p...30f2a1aed21167
Old 11-20-2012, 12:20 AM   #2632
Yes, you can order in Germany and here also:
http://shop.awesomatix.com/
Old 11-20-2012, 12:47 AM   #2633
Nico''s Avatar
thanks a lot Oleg!
Old 11-20-2012, 01:24 AM   #2634
Nico''s Avatar
Is L version sold with soft or normal springs please?
Old 11-20-2012, 02:16 AM   #2635
Magnet Top's Avatar
The A700L comes with the soft springs.
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 11-20-2012, 02:24 AM   #2636
Magnet Top's Avatar
A new revision of my Time Zone II setup has been posted replacing the old one. The reason for the revision is I corrected a couple errors , mainly the position of the inner / upper ball studs.
note, I used Freddy's setup as a starting point , so kudos go to him.
Jake D.
Old 11-20-2012, 04:20 AM   #2637
The picture of correct DL and DR damper's arrangement on the car is here.
Some misunderstanding was possible especially from the guys who did not read the Instruction Manual for A700EX/A700L cars carefully before installing.
Old 11-20-2012, 07:42 AM   #2638
Damn it! So I installed my dampers in the wrong way
DL6 in front left tyre, and DR6 in the front right. Do you think it could have caused damages?
Thank you Oleg!
ale.pac is offline   Reply With Quote
Old 11-20-2012, 09:01 AM   #2639
Nico''s Avatar
Jake D.
hi,
What is this advantage of ST24 parts please?
and thanks a lot for the reply for the springs.
Old 11-20-2012, 12:31 PM   #2640
Magnet Top's Avatar
hi,
ST24 is a shorter ball-end ( it is .7mm shorter than the standard kit ball studs )
thus it allows greater height adjustment range of camber and caster links.
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 Yesterday 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
