Old 11-01-2012, 04:59 AM   #2566
Originally Posted by hana166 View Post
Perhaps it is the profile of the teeth.
The plastic gears are similar or same profile as Spec-R but slightly lower. I found they are a little notchy. OK but not great.
The Xray gear diff is amazingly smooth even under load, the best I have seen by far. It makes a big difference in the handling and confidence, especially on power.
If we could have diff gears that perform at that level I am sure the car would make a laptime even lower.
Yes, agree! The X-ray gear is perfect and here the guys running TC6 also chose X-ray gears. I ran 417 before and the 2nd version diff is far better than the 1st spec-r gear.
Many people overlook the diff gear smoothness and this is critical to the laptime.
tinngsmile is offline   Reply With Quote
Old 11-01-2012, 05:06 AM   #2567
Btw I try the ball diff today. The on power steering is very responsive and good traction on corner exit. But this ball diff has a serious oil leakage problem.
Old 11-01-2012, 05:16 AM   #2568
John Doucakis's Avatar
Hi,
I also tried the balldiff and I liked it very much. Conditions where low-medium traction outdoors asphalt.
My balldiff has never leaked. Make sure you apply the right amount of oil inside.
It does not require a lot, just enough to fill in the gaps.
Usually I take out one outdrive when assemplying it with the oil inside to help excess oil come out and then I re install the outdrive.
After that it has silky smooth operation and does not leak at all.
Regards,
John
John Doucakis is offline   Reply With Quote
Old 11-01-2012, 05:41 AM   #2569
Originally Posted by John Doucakis View Post
Hi,
Regards,
John
Thx for your advice.
I plan to switch to ball diff, any idea how long does it needs maintenance?
Old 11-01-2012, 05:54 AM   #2570
I've already done more than 10 runs with it without any hint of performance change.
On the average I change oil every 6-8 runs as a precaution and because I experiment with different viscosities.
Old 11-01-2012, 06:16 AM   #2571
theatriks's Avatar
Originally Posted by narcotiks View Post
Had them great design but super weak...i broke 3 of them and at 30 bucks a piece wasnt happy.....like i said great design but super weak flimsy bracket.
theatriks is offline   Reply With Quote
Old 11-01-2012, 06:58 AM   #2572
hana166's Avatar
I too like the ball diff. John gives good advice, I also put in one outdrive first then assemble. Incredibly smooth, and consistent.
Mine slips too much for my liking. I understand others might not agree but I think the plate material is too hard. I fitted standard steel balls, much softer than ceramic, and this almost eliminated the slip completely. However I do prefer the gear diff for the rear, I really like the forward bite it provides.
Also the ball diff is quite good in the front with 500,000 cst. Definitely worth a try if you're into experimenting.
hana166 is offline   Reply With Quote
Old 11-01-2012, 11:52 AM   #2573
Trader Rating: 26 (100%+)
Is the A700 L suited for mod racing indoor carpet. I can't find an explanation of what the difference is to a EX
eddie10 is offline   Reply With Quote
Old 11-01-2012, 03:12 PM   #2574
theatriks's Avatar
So i looked over everything and im not having any problems with po1 po2 or po4....the problems im having are the arm itself is popping off the at21 balls that are mounted on the chassis everytime i tap a board .......everything else stays together.......if theres a fix for that !...let me know.
Old 11-01-2012, 05:38 PM   #2575
erchn's Avatar
I would have always replaced P03 after it popped off, I think they start to stretch over time. If there is any wear marks on at21 (shouldn't be) replace it too.
erchn is offline   Reply With Quote
Old 11-02-2012, 03:46 PM   #2576
G-rem's Avatar
Hi all,
is it possible to use Tamiya 0.4 gears motor and spur on the A700L?
Thanks,
G-rem
G-rem is offline   Reply With Quote
Old 11-04-2012, 12:38 AM   #2577
G-rem's Avatar
Originally Posted by G-rem View Post
Hi all,
Thanks,
G-rem
No one?
Old 11-04-2012, 08:15 AM   #2578
Ray k's Avatar
Trader Rating: 46 (98%+)
Hi all,
Thanks,
G-rem
Yes , The only problem is limited spur gear sizes . I think the smallest spur from Tamiya is 111 tooth .They do have a 96 and a 104 but they are spec gears just for the F-1 and will not work on a touring car. So if your running any Spec class ,17.5 or 13.5 ,your spur will not be small enough . You can run Tamya pinions with 64 pitch spurs ,but you have to run gear mesh a hair looser .
Ray k is offline   Reply With Quote
Old 11-04-2012, 10:36 AM   #2579
hello,
i had a race today at longwy rc track...the track had a good gripp on it and a little bit bumpy on the straight..i'm on A700L version using the kit soft springs and dampers..and heard that those springs are made for asphalt..can someone help me out...
thanks.
method699 is offline   Reply With Quote
Old 11-06-2012, 10:53 AM   #2580
hana166's Avatar
Default A700L
Just a few pics of the new car
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
