Old 10-31-2012, 02:01 PM   #2551
Magnet Top's Avatar
Korgae is talking about CA'ing P01 and P02 together.
( the outer upper ball cup assembly )
Jake D.
Magnet Top is offline   Reply With Quote
Old 10-31-2012, 02:24 PM   #2552
erchn's Avatar
Jake D.
Yea, this does work really well, even though it "feels" wrong.
erchn is online now   Reply With Quote
Old 10-31-2012, 02:34 PM   #2553
John.C's Avatar
Trader Rating: 36 (100%+)
Since we're on the topic of improvements/enhancement, I would like to throw out these 2 requests.
1) A tool to easily and accurately measure caster
2) A bracket to mount a fan (dual fan would be a bonus)
My motor (D3, D3.5, Sonic) is running hot compared to my belt drive cars with gearing, layout, track size all being equal. An effective and durable mounting bracket is desperately needed for us racers running 17.5 blinky.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 10-31-2012, 02:45 PM   #2554
erchn's Avatar
See this for caster.
Old 10-31-2012, 03:12 PM   #2555
theatriks's Avatar
+1 on the fan mount......and im like a fat kid is on a smartie on this thread and cant beleive i missed the info on the ball cups lol...well thanks guys im gonna make that change now and try it out this weekend.
theatriks is offline   Reply With Quote
Old 10-31-2012, 05:14 PM   #2556
Company Representative
Korgae's Avatar
Here is what I do to check and set caster:
Remove the 3x6 screw from the top of the hub.
Screw in a XRAY 808 outer hinge pin (# 357331) The hinge pin is long enough to read perfectly on a Hudy gauge set.
Setting caster front and rear is super easy and quick.
See pics:
Awesomatix EP Touring Car-photo.jpg   Awesomatix EP Touring Car-2.jpg   Awesomatix EP Touring Car-3.jpg
Awesomatix-Roche-Reedy-Sweeps Racing- ORCA-Sanwa-RCTagz-Avid
WCICS- Competition Director
Korgae is offline   Reply With Quote
Old 10-31-2012, 11:33 PM   #2557
Today I try using 2 small bevel metal gears in the rear diff. The diff is still not as smooth as plastic sets after 8 more flights. "Gear click sound" is still heard when rotating the wheels in static. The on power steering performance is not good and cause slow corner exit.
tinngsmile is offline   Reply With Quote
Old 10-31-2012, 11:42 PM   #2558
erchn's Avatar
Have people really found that the st20 and gear diff mods listed earlier insufficient? Every other car on the market runs plastic, why is metal needed?
Old 11-01-2012, 12:01 AM   #2559
Nico''s Avatar
Hi,
for the rear diff, I don't know but running a T4 too , I would love metal gear in front diff to use with Ride 70 or 45 putty. (plastic front diff gear broke quickly with Ride putty)
Nico' is offline   Reply With Quote
Old 11-01-2012, 01:23 AM   #2560
My A700 smash 4 sets rear plastic gears in the past year. Diff gears is the weakess point in this shaft driven car with all other parts in its drive chain are metal.
Old 11-01-2012, 03:21 AM   #2561
hana166's Avatar
Default Fan
I made my own some time ago. It is extremely efficient. Perhaps this will help someone
Page 146
http://www.rctech.net/forum/10835587-post2183.html
hana166 is offline   Reply With Quote
Old 11-01-2012, 03:26 AM   #2562
hana166's Avatar
Is it not smooth because of the design of the teeth on the gears? Or because it is too tight (not enough clearance)?
I sand the back of the plastic gears to make the mesh not so tight, and the diff is smooth right from the beginning.
What about sanding the back of the metal gears (and polish them)to loosen the mesh?
Old 11-01-2012, 03:54 AM   #2563
I compare the gear shape between metal and plastic, they are different and looks the metal gear with a shorter teeth. I believe it is not the clearance problem as I tried loosen the diff case bit by bit and get no luck to eliminate the "gear click sound". Still looking for the root cause and solution...
Old 11-01-2012, 04:16 AM   #2564
narcotiks's Avatar
check these out
http://www.speedtechhobbies.com/inde...path=60_74_198
narcotiks is offline   Reply With Quote
Old 11-01-2012, 04:39 AM   #2565
hana166's Avatar
Perhaps it is the profile of the teeth.
The plastic gears are similar or same profile as Spec-R but slightly lower. I found they are a little notchy. OK but not great.
The Xray gear diff is amazingly smooth even under load, the best I have seen by far. It makes a big difference in the handling and confidence, especially on power.
If we could have diff gears that perform at that level I am sure the car would make a laptime even lower.
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
