Old 07-16-2012, 03:51 AM   #2266
dontfeelcold's Avatar
Trader Rating: 20 (100%+)
What did you change to the car?
dontfeelcold is offline   Reply With Quote
Old 07-16-2012, 07:34 AM   #2267
John.C's Avatar
Trader Rating: 36 (100%+)
For the most part the setup changes you'd make on the A700 is not that much different than on a traditional TC. What worked for my Tamiya TCs are working on the A700. Changes to droop, ride height, camber, roll center, sway bars, dampening, dive, squat, etc are all producing results that are expected. The one area that's a little different is the rear toe. The outboard toe-in doesn't seem to generate as much mechanical grip as inboard toe-in. As such, I'm running a little more rear toe-in than usual. For 17.5 stock TC I typically ran 1.0 or 1.5 degrees of inboard toe-in. With the A700 I'm running between 2.0 to 2.5. The outboard toe-in setup should result in more corner speed if all things are equal. I'll need to keep working on my setup till I get there.
John.C is offline   Reply With Quote
Old 07-17-2012, 10:52 AM   #2268
John.C's Avatar
Hi Oleg,
Would you be able to provide any info on the optional lower deck (C01L)? Release/restock date would be great appreciated as well.
-John
Old 07-18-2012, 06:59 AM   #2269
Originally Posted by John.C View Post
Hi Oleg,
-John
This item and several others new items will be released soon after the final approval of our test drivers.
Oleg Babich is offline   Reply With Quote
Old 07-18-2012, 07:03 AM   #2270
Congratulations to Viljami Kutvonen!
Viljami won Finnish Championship serie 2012.
Old 07-18-2012, 07:07 AM   #2271
John Doucakis's Avatar
Default contact
Hi Oleg,
Please check email and PM.
John
John Doucakis is offline   Reply With Quote
Old 07-18-2012, 07:50 AM   #2272
John.C's Avatar
Thanks for the update! Will the revised/improved ball joints be one of the 'other new items'?
Old 07-18-2012, 07:56 AM   #2273
Yes, the improved ball joints are in this list.
Old 07-18-2012, 08:13 AM   #2274
theatriks's Avatar
Is the new lower deck gonna have more flex or be more stiff
theatriks is offline   Reply With Quote
Old 07-18-2012, 08:22 AM   #2275
John.C's Avatar
Good to hear!! I have a stock pile of the current style joints. Hopefully, the revised pieces will be released before I burn through them.
Hopefully, it'll be a little bit narrower.
Old 07-18-2012, 08:30 AM   #2276
theatriks's Avatar
Ok thanks and whats this talk about ball joints i havent had to replace any...am i overlooking something
Old 07-18-2012, 08:40 AM   #2277
Good to hear!! I have a stock pile of the current style joints. Hopefully, the revised pieces will be released before I burn through them...
One drop of thin CA glue between P01 and P02 after caster /camber adjustment will help you a lot now.
Further adjustments of suspension are possible after that without problems.
Old 07-18-2012, 08:42 AM   #2278
New lower deck will have adjustable flex at "right areas".
Old 07-18-2012, 04:48 PM   #2279
hana166's Avatar
My C01L is only about 90mm wide. With everything so inboard the car changes direction really quickly
hana166 is offline   Reply With Quote
Old 07-18-2012, 06:09 PM   #2280
theatriks's Avatar
You got any pics of that lower deck
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 Yesterday 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
