Old 06-12-2012, 04:20 AM   #2191
hana166's Avatar
I heard the number of sets allowed was extremely limited. Wow its crazy. Is it possible to change the rules if enough drivers protest?
hana166 is offline   Reply With Quote
Old 06-12-2012, 05:14 AM   #2192
Yep, the Protest is in Progress. We hope the best :-)
LRP - Awesomatix
FreddySudhoff is offline   Reply With Quote
Old 06-16-2012, 09:09 AM   #2193
Default Thank U Ed "Try Hard" Clark
This is a shout-out to 'TryHard', used your TiTC setup in Malaysia at one the local tracks and it was right on the money. Thank you for sharing and your blog helps tonnes in getting the car right. I was hooked the moment i saw your car at TiTC and you certainly helped make up my mind with your detailed explanation and willingness to share.
Most of the guys in the this forum has been most forthcoming with the information sharing, really cool thing to see.
Cheers
viper1 is offline   Reply With Quote
Old 06-18-2012, 09:18 AM   #2194
theatriks's Avatar
Anybody else here having major gear diff leakage issues?
theatriks is offline   Reply With Quote
Old 06-18-2012, 09:21 AM   #2195
So far none from my geardiff.
Cheers
Old 06-18-2012, 09:59 AM   #2196
I have also no problems with leaking diffs. Where comes the Oil out? Maybe you forgot the big o-ring in the middle under the thread?
LRP - Awesomatix
Old 06-18-2012, 10:26 AM   #2197
Trader Rating: 18 (100%+)
Not at all. I still have originally built gear diffs with no leakage. One thing I did was to make sure the orings and threads were wet or pre-oiled before assembly. Always found that it help settle the parts together.
Check the orings to see if they were accidentally pinched during initial assembly.
● AWESOMATIX USA ● ABSOLUTEHOBBYZ ● HEBIKI DESIGN WORKS ●
MDawson is offline   Reply With Quote
Old 06-18-2012, 02:13 PM   #2198
abe-racing's Avatar
If your finding oil in plastic cover where the diff sits then this is the big o ring seal where Freedy has said, If oil is leaking outside without removing the cover then this would be the outdrive, outdrive would very rare to leak if not impossible if built correctly.
I have had the big O ring leak before, so i replaced this and never leaked a drop since, i must have caught it on a thread. Also makesure your not overfilling the diff as this will feel tight before it seals, but i would say you have caught the O ring like me.
Hope this helps.
ABE-Racing,Team Orion, Blakey Designs, Xray RcDisco,T-Shox
abe-racing is offline   Reply With Quote
Old 06-18-2012, 03:10 PM   #2199
jake95's Avatar
Trader Rating: 27 (100%+)
You are most likely over filling it causing it to come out of the out drives.
XRAY✯NOSRAM✯SANWA
jake95 is offline   Reply With Quote
Old 06-19-2012, 03:50 AM   #2200
Damon's Avatar
finally my first important result, TQ and win at the third race of Uisp Italian Championship (unofficial national championship) in Stock 13.5 class
my A700 was really fast on the hot asphalt (from 2 to 4 pm over 60C), and very easy to drive
I hope this result could increase the number of A700 in Italy, I just received many calls from people interested in trying the Awesomatix
in attachment some photos and my setup, derived from the one of Hugo Ragaut
I will fight for the title in the last race in September!
Awesomatix EP Touring Car-podio1.jpg   Awesomatix EP Touring Car-podio2.jpg   Awesomatix EP Touring Car-podio3.jpg
Awesomatix A800
Awesomatix A800AH
Damon is offline   Reply With Quote
Old 06-19-2012, 05:11 AM   #2201
hana166's Avatar
Congratulations
Very interesting high traction set up, asymmetric front damping only
Old 06-19-2012, 06:35 AM   #2202
Damon's Avatar
thank you! but the excellent setup I used is the result of the Hugo's work, with slight adjustments
the beautiful track where we raced:
Awesomatix EP Touring Car-pista2.jpg   Awesomatix EP Touring Car-pista3.jpg   Awesomatix EP Touring Car-pista4.jpg
Awesomatix A800
Awesomatix A800AH
Old 06-19-2012, 10:03 AM   #2203
Originally Posted by Damon View Post
finally my first important result, TQ and win at the third race of Uisp Italian Championship (unofficial national championship) in Stock 13.5 class .....
Our congratulations, Gabriele!
Oleg Babich is offline   Reply With Quote
Old 06-19-2012, 05:49 PM   #2204
theatriks's Avatar
Hey guys stupid question but when I'm looking at the setup sheets in the frame flex settings ....are the red x's and red dots the notches and screws they cut out or kept in ?
Old 06-19-2012, 06:15 PM   #2205
erchn's Avatar
Not stupid question, asked a few times and somewhat confusing.
Red X's on the top deck are cut outs.
Red dots indicate the screw is used in top and lower deck. Lack of red dot on top deck ends can also mean using an ST09 collar with a screw, so it's floating or not fixed.
erchn is offline   Reply With Quote
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
