Old 05-08-2012, 02:26 PM   #2116
theatriks's Avatar
Originally Posted by Airwave View Post
Which one?
its the first set up you see when u go to the awesomatix site it will say hugo ragaut may 2 2012 .....worked great!
theatriks is offline   Reply With Quote
Old 05-08-2012, 02:47 PM   #2117
Happy that the setup worked well for you.
This setup is based on Freddy's ETS setup.
If the track is bumpy, you should try rear symetric damper setting (it's on freddy's poland setup).
Hugo
Hugo is offline   Reply With Quote
Old 05-08-2012, 04:18 PM   #2118
Airwave's Avatar
I just wanna say that I'm so happy with this car, first because it is awesome, but also because we have an awesome community of drivers, with differents skills, sharing what they know and/or experiment and making this car more interesting, day after day...
So thank you guys!
And keep it the good work!
Airwave is offline   Reply With Quote
Old 05-08-2012, 05:22 PM   #2119
Which one?
http://www.petitrc.com/reglages/awes...829/index.html
Arn0 is offline   Reply With Quote
Old 05-08-2012, 10:21 PM   #2120
StickyFingaz's Avatar
Trader Rating: 12 (88%+)
Originally Posted by erchn View Post
Agreed, based on my calculations, the distance is quite a bit too far. I was never very good at trig, but the Interwebs have told me it should be around 3/4mm for 1 degree of sweep and 1.5mm for 2 degrees. Here's how I calculated it:
Code:
r = 44mm (distance between arm mount locations)
length of circular arc = degrees * (PI/180) * r
1 degree
1 * (3.141/180) * 44 = .7679mm
2 degrees
2 * (3.141/180) * 44 = 1.535mm
Of course, these could be totally wrong, so maybe someone with more skills can double check. ;-)
This guy's car is DIALED. Bringing back shaft drive here in Northern California and making it look FLOSSY.
Folks, take note. Totally legit.
Sidenote: Trigonometry????? Really?!?!? Crazy.
Team Tamiya/TRF - Team KO PROPO - NorCal Hobbies
StickyFingaz is offline   Reply With Quote
Old 05-09-2012, 03:52 AM   #2121
Damon's Avatar
I'm using the car without bars also on asphalt, and I really like the car, not inconsistent, but I think it's the entire setup to be considered. I used almost identical setups for two different tracks with good results, but always with the same type of tires (Sorex XG36-SY).
This is the last setup used in the second race of the UISP Italian Championship (unofficial national championship) in Stock 13.5 class. Very bumpy asphalt track, with medium grip (sugar-water). For bumpy track I tried asymetrical damper setting in front and symetrical rear, they worked well!
TQ for my A700, in the finals too many collisions on the first corner (not sanctioned) ruined my race and relegated me in fourth. The only final in which I turned the first corner without damage I set the track record for 13.5 class.
Very sorry for the result of the race, but otherwise very happy for the exciting performance of my car.
Awesomatix A800
Awesomatix A800AH
Damon is offline   Reply With Quote
Old 05-09-2012, 11:20 AM   #2122
erchn's Avatar
Please disregard this guys comments. He's Naturally Talented in the sarcasm department.
erchn is offline   Reply With Quote
Old 05-10-2012, 05:34 PM   #2123
theatriks's Avatar
Hey Oleg when are you gonna get some t-shirts made ....so we can rock them out at the races
Old 05-10-2012, 05:37 PM   #2124
Magnet Top's Avatar
Thumbs up
+1
Magnet Top is offline   Reply With Quote
Old 05-11-2012, 09:56 AM   #2125
John.C's Avatar
Trader Rating: 36 (100%+)
Well, I finally managed to break a part on the A700 last night. 'Break' might not be the best word choice here. The universal ring popped off after an encounter with the board causing the front universal to seperate. I eventually found the front U bone, U ring, bushings, and 1 of the 2 U-joint cross pieces all intact and in working condition. I was pleasantly surprised that nothing was bent, cracked, and/or deformed in any way. So at the end of the day I managed to lose a U-joint/pin. Unfortunatley, it ended my night as I didn't have a spare U-joint. Has anyone tried the new/revised front universal ring (A700-P20)? Does it seem to do a better job of holding the front universals together? I'll be putting an order together and will be giving these a try.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 05-11-2012, 09:59 AM   #2126
Trader Rating: 19 (100%+)
They work well. Cheap insurance
MDawson is offline   Reply With Quote
Old 05-11-2012, 10:03 AM   #2127
John.C's Avatar
Thanks Mark!! BTW did you move to Cali??
Old 05-11-2012, 10:11 AM   #2128
House is ready. Moving just after the Reedy Race
Old 05-11-2012, 10:56 AM   #2129
John.C's Avatar
Wow congrats! I'm sure it's to pursue bigger and better things. Good luck on your move!
Old 05-11-2012, 11:44 AM   #2130
Thank you John. Couldn't be more excited. Hold down the Awesomatix hope on the East Coast. You are the only hope
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17195 01-10-2017 05:04 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
