Old 10-16-2010, 11:58 AM   #181
Originally Posted by bkspeedo View Post
Torque steer in created by placing the motor parallel to the chassis like the TC4. For lower turn motors (mod) this was a big problem, for high turn (stock) it was not as noticable.
By placing the motor perpendicular to the chassis, like today's belt cars, you eliminate this problem.
This is why all the car makers went to belt transmissions.
This car solved this issue by adding bevel gears from the spear gear to the drive-shaft. Over-all the shaft drive car should be quicker out of a corner because there's no belt stretch.
cheers, I see now, I knew about the old shafty,s I wounder how long it will take other manufactures to convert if this works
michael.branth is offline   Reply With Quote
Old 10-17-2010, 06:23 PM   #182
ottoman's Avatar
R/C Tech Charter Subscriber
So how did it do at the ETS?
Did it live up to the performance claims posted on this thread?
Doesn't look like there is room for a gear diff
ottoman is offline   Reply With Quote
Old 10-17-2010, 06:43 PM   #183
snoopyrc's Avatar
This is also why the older shaft drive cars get new life in VTA. The slow brushless motors still torque the chassis, but its not near as noticeable.
Yeah! It looks tight but I think if they wanted to do it they could get a gear diff jammed in there. Looks like they have a ball diff in the back and a spool up front.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 11-25-2010, 04:22 AM   #184
tc3team's Avatar
Originally Posted by PitNamedGordie View Post
Great pictures, they speak a 1,000 words.
Unfortunately I feel the one key thing that is missing here is regular updates from Oleg Babich (or anyone else senior) to advise how the car is performing, how the development is going and what plans there are to distribute this car.
Going a long time without any info is not good for business on a new product.
I cannot see it clearly enough from the pictures, but are the diff outdrives and the driveshaft ends both metal?
If so, surely metal outdrives and plastic replaceable ends would be better on the wear rate/cost for the user?
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 11-25-2010, 08:27 AM   #185
wingracer's Avatar
Trader Rating: 21 (100%+)
Looks like it has a small ball bearing on the ends of the pins.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 11-25-2010, 09:42 AM   #186
tc3team's Avatar
I thought it might have looked like that too, but wasnt sure
i've not seen much if any information regarding the specification of the car to confirm.
if it is a bearing, it looks like a very durable solution, but if not, metal on metal could wear quite quickly, depending on its material.
Old 11-25-2010, 09:46 AM   #187
Johnny Wishbone's Avatar
Didn't LOSI do the same thing with the JRXS?
Gary Lanzer
Team VBC HK
Team R1WURKS
Old 11-25-2010, 11:15 AM   #188
heretic's Avatar
I think it is more something B. Kinwald did, it's called the BK bones. I never saw it on a production car. D.Spashett's XXXS has had some.
I love wedge bodies. I love dish wheels.
heretic is offline   Reply With Quote
Old 11-26-2010, 02:05 AM   #189
tc3team's Avatar
The crown and pinion gears will also need very good shimming on this car, or they can fail quite quickly (I know this from the tenth technology predator which uses a similar transmission layout).
But a large root dimension of the gears is the most needed factor, being an on road car it should hold up better.
Old 11-26-2010, 04:31 AM   #190
heretic's Avatar
No matter how badly I setup the mesh of the bevel gears on my TC3, I never managed to break one single tooth, even when running mod/ into the boards / with a spool.
The hpi pro4 and TTech cars were famous for this weakness, though. So I assume it is more a matter of material than an inherent drawback of this design. The metal gears of the aweomatix look sturdy enough to me. Do the plastic gears come from a Pro4 ? I know previous prototypes used pro4 transmission cases.
Old 11-26-2010, 04:59 AM   #191
tc3team's Avatar
Yes, they increased the root dimension on the later ttech cars, which led to better reliability. Material, root dimension and how the gears are shimmed are the factors to determine reliability.
I'm not saying the Awesomatix will encounter the same problem, i'm just saying that sometimes a crown and pinion transmission layout can be tempermental.
Old 12-08-2010, 01:37 AM   #192
Latest pictures ( at race in Vladimir City, Russia).
Virtually the production car.
All bevel gears made of steel.
Spool weight 12.7 gr ( A7075 body with steel gear and outdrives + bearings).
Diff weight 22.7 gr (A7075 sealed body with steel gear and outdrives + bearings).
Awesomatix EP Touring Car-dscn0175_62000.750.jpg   Awesomatix EP Touring Car-dscn0176_b76f9.750.jpg   Awesomatix EP Touring Car-dscn0185_8e58c.750.jpg
Oleg Babich is offline   Reply With Quote
Old 12-08-2010, 01:52 AM   #193
looks great oleg, much more polished looking car.
how did it go?
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 12-08-2010, 02:36 AM   #194
how did it go?
Hi, Bradd
Looks nice on the track also.
At least we have won a 13.5 class this time.
Old 12-08-2010, 02:40 AM   #195
Default release date
Car does look great! Have you established an estimated release date and price of the kit?
Thank you,
Patrick
XCELL is offline   Reply With Quote
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 Yesterday 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
