Old 03-26-2012, 09:05 AM   #1876
John.C's Avatar
Trader Rating: 36 (100%+)
I took a break from RC for a couple of months and it appears I've missed out on some things (some good and not so good). I can't wait to get the A700 out again at my favorite indoor asphalt track. Anyone try Steen's aspahlt setup? I'm looking for a good 17.5 stock setup for a technical, high bite, asphalt track.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 03-27-2012, 06:02 AM   #1877
theatriks's Avatar
Hey guys I got an A700 coming shortly thinking about putting a savox servo in it ....any reccomendations.... should it be low profile?
theatriks is offline   Reply With Quote
Old 03-27-2012, 06:22 AM   #1878
Trader Rating: 18 (100%+)
I would need to spend a couple weekends there. My initial runs were pretty tough on the car there. You are better off starting with Freddys setup with the following changes;
  • Mazda6 body
  • Front long camber links / medium rear camber links
  • Solid top deck
  • Front gear diff with 500k
  • 2.5 rear toe
  • Front arms raised 1.5mm / rear arms flat
  • Black front swaybar / brown rear swaybar
  • Any brand of the low profile work fine. Preference is the Spektrum, RadioPost, Futaba. I found that the low profile will give you the most flexibility of forward mounting the ESC to get a better weight balance
● AWESOMATIX USA ● ABSOLUTEHOBBYZ ● HEBIKI DESIGN WORKS ●
MDawson is offline   Reply With Quote
Old 03-27-2012, 06:31 AM   #1879
John.C's Avatar
  • Mazda6 body
  • Solid top deck
  • 2.5 rear toe
Thanks Mark!! I'll take a look at Freddy's setup sheet and make the appropriate changes.
Old 03-27-2012, 06:57 AM   #1880
The goal is to soften the car as much as possible. Take away initial steering and front bite, start with the spool - if it lacks steering try the gear diff.
The front roll center for the C is better when it is higher than what we usually run.
Old 03-27-2012, 07:25 AM   #1881
John.C's Avatar
After struggling at my last race (couple of months agao at MRH) I posted my setup. Oleg chimed in to confirm that I had made an error in setting my spring tension. My setup was SRS/RHS ARR I but I was using the SRS/RHS ARR II values resulting in a very stiff car (120+ gF/mm). As a result, I struggled mightly with rear grip, twitchy handling, and traction roll issues. I've since corrected this and I'm now in the appropriate range (60gF/mm - 80gF/mm) both front and rear. I'm cautiously optimistic at my chances for a better showing/result at my next outing.
Old 03-27-2012, 08:54 AM   #1882
bozzplayer's Avatar
Trader Rating: 16 (100%+)
Hey guys was hoping anyone can help me measure all the different ways of the shocks, example I'm looking to achieve this shock setting 100.2gf/mm 1.6mm(setting B) and 5mm(setting A) I'm using screw arrangement 2, i know how to setup setting B, but was hoping someone can make it little clear how to do all these settings and in what order, thanks for any help guys.
bozzplayer is offline   Reply With Quote
Old 03-27-2012, 06:52 PM   #1883
TryHard's Avatar
I always setup the A value first, as this also affects the damping rate, so use that to achieve the damper level I'm after. A is in effect the corser adjust, because it tunes both spring and damper.
Secondly, I'd set the B value, as this only affects the spring rate, so use this more as the fine tune to get your springing right.
HiH
Ed
Old 03-28-2012, 07:20 AM   #1884
John.C's Avatar
I'm looking to replace the (AT21) pivot ball with traditional ball studs in some areas. Has anyone found an suitable replacement ball stud that works/fits the (P13-x) ball end?
Old 03-28-2012, 08:37 AM   #1885
erchn's Avatar
Kyosho
erchn is offline   Reply With Quote
Old 03-30-2012, 07:27 AM   #1886
theatriks's Avatar
Hey guys is it normal for the drive shaft to have wear on it where it sits up against the bearings?
Old 03-30-2012, 07:30 AM   #1887
Are you using the shaft/bearing guides mid chassis?
Old 03-30-2012, 07:51 AM   #1888
theatriks's Avatar
Yes thats wear the wear is ....is it normal to have wear on the driveshaft wear it sits up against the bearings on the mid chassis bearing guide.
Old 03-30-2012, 08:01 AM   #1889
Both of my cars have some shadow of a wear line near the bearings. Sure that it is the natural rotation of the shaft at high speed with the way the chassis works.
I have not had any issue with it. Lots of miles on my cars without any case to worry.
Old 03-30-2012, 10:34 AM   #1890
erchn's Avatar
Same here.
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
