Old 03-10-2012, 05:43 AM   #1756
Originally Posted by Kensei View Post
"On the setupsheets the topdeck has three holes on front and rear. In the manual it has five holes. How does that add up?"
Please explain.
Diagram of the upper deck in the setup sheet is simplified.
It only reports is the end of the upper deck fully fixed or floating.
The presence of additional holes in the scheme would not add any useful additional information.
Oleg Babich is offline   Reply With Quote
Old 03-10-2012, 06:42 AM   #1757
Hi Oleg,
I've a question about latest steen's setup:
What does he mean when he says in the comments: "gear box in 2 pic front and rear for more flex"
Hugo is offline   Reply With Quote
Old 03-10-2012, 08:55 AM   #1758
Sorry, but I am still busy with the basics. But not for long anymore.
As to joint grease as mentionend in the manual.
This one is good also?
http://www.hk-modellbau.de/default.a...790&kat_id=601
Kensei is offline   Reply With Quote
Old 03-11-2012, 12:40 AM   #1759
chrisman's Avatar
Send a message via MSN to chrisman Send a message via Yahoo to chrisman
Default A700
Hi Oleg, any idea how much longer until the next batch of cars be ready? Thanks.
CHRIS LIM
OVERGEARED RACING B.O.D
ORCA//AWESOMATIX USA//HEBIKI DESIGN WORKS//OPTION R/C//GRIPWORKS RC
chrisman is offline   Reply With Quote
Old 03-11-2012, 04:50 AM   #1760
Default Awesomatix A700
If I would order now or within a week from now, how long would it take then before receiving the car? Shipped to the Netherlands.
Very important to know.
I am a bit worried as to how fast you can ship and as to continuity. Especially as I see that the kit is out of stock.
Please let me know and please be frank here.
Worst case I have to move to another brand.
But I'd do that within a blink of an eye.
Old 03-11-2012, 12:03 PM   #1761
theatriks's Avatar
I came across a website called cosmic rc that i think has these kits instock give them a try
theatriks is offline   Reply With Quote
Old 03-11-2012, 01:33 PM   #1762
Oleg,
On your website it says the car is € 589.
How much are the shippingcosts to The Netherlands?
Old 03-11-2012, 03:04 PM   #1763
You can also try on awesomatix.ch but until the end of the week no A700 available.
Sasad is offline   Reply With Quote
Old 03-11-2012, 03:57 PM   #1764
Oleg,
On your website it says the car is 589.
~ 23 via EMS
Old 03-11-2012, 04:03 PM   #1765
~ 2-3 months.
Old 03-11-2012, 10:58 PM   #1766
chrisman's Avatar
Originally Posted by Oleg Babich View Post
~ 2-3 months.
Thanks Oleg for the heads up.
CHRIS LIM
Old 03-12-2012, 12:32 AM   #1767
TryHard's Avatar
Hi All,
Just attaching the copy of the latest running from this weekend. Having had a few weeks off since TITC, time to get back into driving again, so I headed to the local indoor asphalt track.
I started out with an adaptation of my TITC settings, but with much softer roll bars all round. Car worked well, but seemed to be missing something, and was crashing over the bumps a bit. No real vices, but didn't feel fast... so took it back to the pits and decided to stick on Steen's settings (or as close as I could get) from the last ETS..
Well, that made a massive difference. Car was much better over the bumps, but with such softer dampers it was really stopping in the middle of the corner.
Next few runs had a play around with the dampers and springs, trying harder damper and spring, as well as Asym and Sym. Overall, the spring rate seems to be good, but the damping needed to go up, and I tried going as far as I could without altering the spring (so 3mm out on A from Steen's). This was too far, so backed it down to 2mm out, and that felt pretty good. However, the car still had a tendancy to over-rotate mid-corner if I got aggressive on entry, so wasn't so consistent.
On the Asym and Sym comparison, the asym felt really not nice to drive, really initially reactive, but then completely numb... it was so bad I pulled the car off the track after 2mins to put the sym back on!
I switched out tyres from 28's to 32's at the end of the day to try and have representative few runs on tyres similar to what I'll use next weekend... surprisingly the car felt pretty good, although could do with softer damping now, and the over rotate tendancy was still there. Also, given the low temps (~8C!) the tyres took quite a while to heat up, but once they were there, and I got my head round driving it, popped in a series of laps with a fastest of 11.9, and a average of 12.1... so again, pretty consistent runs, which I'm happy with. Car was much more compliant over the bumps and ripples, actually felt like for the first time that it was riding rather than smacking them. Big improvement for sure.
Anyway, by that time it had got quite late, so left on my list for next weekend are to try a slightly softer rear spring, more rear camber, and overall lower damping/spring, to try and get the heat generated quicker. We'll see how it goes then... hopefully can get a decent run in, and even if the traction is super high I know that they'll be no hint of traction roll for me
Regards
Ed
Old 03-12-2012, 12:55 PM   #1768
Originally Posted by erchn View Post
True. I use a crescent wrench in both cases but the 12 could be handy if you need to change your spur without removing the top deck.
Thanks,
E
you need 2 common tools that aren't so common in rc cars:
10 mm wrench for gear differential tightening
12 mm wrench for spur gear nut tightening
Hi,
Could you please point me in the right direction as to what tools I should buy.
Sorry, but I have no clue.......
Old 03-12-2012, 01:00 PM   #1769
So these are the ones that fit for sure?
http://www.arrowmax-rc.com/index.php...+gear&x=21&y=8
http://www.arrowmax-rc.com/index.php...gear&x=11&y=14
Old 03-12-2012, 01:03 PM   #1770
What joint grease to use? See page 6. Please give brand and partnumber.
I use Hudy black grease (AE is extremely similar) on universals, and a dry wax lube on gears (ring and pinion for example).
On what other parts do I have to use the dry wax lube?
Only on the pinion or all other cogwheels too?
What "ring" do you mean?
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10911 11-28-2016 07:09 AM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
