Old 02-13-2012, 04:53 PM   #1606
I'm still waiting for my 2 A700 Kits to arrive
Number 49 Lou's Speedway Canada, Honda House www.hondahouse.com
ElliotCanada is offline   Reply With Quote
Old 02-14-2012, 12:06 AM   #1607
Tbone13's Avatar
Originally Posted by method699 View Post
thanks for answering..
i'm a big fan of the Tom Maquel AKA TBone13 setups..
but i've tried the IAS and was loosing the rear at fast sweeper entry..
i tried lowering the rear roll center by puttin 3mm on the inside camber links..
it didn't work..i taught it was the tires Ride32 the red one for asphalt..infortunatly we have to use them on carpet for the coming championship..pfff
i went back to the standard steering rack this time with the sorex 28 tires JB foam in the morning with the cold weather i started with the soft dampenin'..went from 5.4 (1.2) to soft front to 4.0 (1.2) and from 5.0(2.0) to soft rear 4.0(2.0).. and was the fastest car on the track..
but when the litlle gripp start coming i tried to stiffen a little bit the front and the car start loosing rear end at the fast sweeper..
now i think i should have gone for stiffer dampening front and rear at the same time..
i should have also checked for less toe out 1..actually i'm on 2 each side..
thanks.
Hy Guys,
thanks for the flowers
for the imposed tires the ride 36 with asphalt insert it is quite difficult to get a good setup cause these tires are not made for racing on carpet and they are quite high in shore with 36.
what you can try:
- use tires that have done already some runs and clean them very good cause the ride tire often has some graining on the rubber left. new ride's are alwys hard to drive konstant.
- heat them up befor the run so you got more grip and the insert is temperated. (recommend about 20minutes with 60-70 degres with sauced tires)
- use a little shorter upper links to keep the tires warm. (more roll in the chassis.
- close your front toe to 1 or 0,5 each side
when your back is spinning arround so try a little harder oil (2000) and also a little less drop at the back 4-4,5 front still at 6. This will calm your back but you will loose a little sterring. but i think a car that is understeering a little is easyier to manage as a oversterring car.
last recommandation and its the best i think is have fun ...it's only one race on carpet and all the others are on asphalt ...so so your best. Your improved yourslf a lot over the last races and congrads for your third place on the last one in Longwy
kind regards Tom
supported by and thanks to:
Modelconcept / Absima Racing / TeamC / Hacker Brushless motors / Awesomatix
Tbone13 is offline   Reply With Quote
Old 02-14-2012, 04:16 AM   #1608
Originally Posted by Airwave View Post
Huge news!
I'm gonna get my kit tomorrow, and now it has a distributor in my country!
Awesome!
Are you racing the Swiss Championship with A700?
Yes of course
For what do you need in the future feel free to contact me
Sasad is offline   Reply With Quote
Old 02-14-2012, 04:48 AM   #1609
Skiddins's Avatar
Originally Posted by hana166 View Post
Been hearing very positive things about the Subaru. Does anyone have an opinion about how it compares to a Speed6 ?
You might want to consider the Eastcoast Bodies Tune Mazda Speed 6.
I have been using it all winter, on Sunday swapped it for my LTC-R at Rug Racers in the final and found the LTC-R to be too safe compared with the East Coast, the lap times were slower as well.
Skiddins
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RD Disco
Skiddins is offline   Reply With Quote
Old 02-14-2012, 08:03 AM   #1610
Thanks Tom for the reply..
i think i'll try test the shorter links, and then reconsider my setup
around 1 toe out, play with the droop and try to heat a little the tires..
check my diff oil and get it to 2000 cst.
anyway this sunday me and my country folks comin' to see you at Longwy...
your advices made me improve so i only can say thanks mister..
some talkin' about slip angle..
that some tires need less or more ackerman..
with my ride32 with high sidewalls, do i need more or less ackerman??
thanks.
method699 is offline   Reply With Quote
Old 02-14-2012, 11:07 AM   #1611
Magnet Top's Avatar
Hi Freddy,
Do you use green loctite on your 10x6x3mm wheel axle bearings ? I've noticed over time the wheel hubs no longer fit tight around the bearings producing less consistency. I've been told Steen uses loctite on all the bearings.
If anyone has an opinion on this I'd like to hear it.
( btw, I have yet to try the 1500 cst oil in the rear gear dif , I wanted to do a back to back comparison but I simply ran out of time to make the change , I partially spun out off power again so I could have been even 1 second faster, yet I still managed to re-set the track record by 2 seconds )
Jake D.
Magnet Top is offline   Reply With Quote
Old 02-14-2012, 11:25 AM   #1612
Hi Jake
No, I don't use any loctite around the bearings. I just check the play from the drive axle between wheel axle and hub(bearing). In the Kit are enough spare shims to reduce it.
I also think that the green loctite is to heavy. You will have problems to get the bearings out again. :-)
LRP - Awesomatix
FreddySudhoff is offline   Reply With Quote
Old 02-14-2012, 11:33 AM   #1613
DS Motorsport's Avatar
I would advice using Loctite 603 for this application.
It's basically made for retaining bearings in bores. Just use one drop per bearing and it should retain the bearing put you're also able to push it out by hand or using a little heat.
You can also use loctite 641 which has less strength but in nitro cars the bearings come loose again when using this one.
http://www.bearing-king.co.uk/bearin...ant-250ml/5752
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 02-14-2012, 06:16 PM   #1614
Magnet Top's Avatar
Thanks for your reply Freddy and DS motorsports,
I'll shim out the axle ( if needed ), thanks. Also I may try loctite 603 to see how affective it is with our hubs, and see how difficult it is to remove. Will report back when a bearing fails. Hopefully it'll be a while
Cheers,
Jake D.
Old 02-15-2012, 05:52 AM   #1615
hana166's Avatar
Skiddins
I might order one of those too thanks for the tip
hana166 is offline   Reply With Quote
Old 02-16-2012, 12:16 AM   #1616
If you find one in stock in the uk, let me know where from.
Mb3195 is offline   Reply With Quote
Old 02-16-2012, 05:08 AM   #1617
hana166's Avatar
Do you have a product code for this (east coast) body plz?
Also anyone have any experience with Blitz bodies? They were brilliant on my 1/8 onroad, very good quality, just wondering how the 190mm bodies are.
Old 02-16-2012, 05:30 AM   #1618
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
Ultra Pro Series: 190MM 1/10 Touring bodies shell..Type: M-Speed 6 [16283126]
1/10 EP 190mm Touring Bodies Shell M-Speed 6 Spec 2009 [168M609]
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
nnick is offline   Reply With Quote
Old 02-16-2012, 06:31 AM   #1619
steveonamission's Avatar
Schumacher distribute East Coast bodies...
steveonamission is offline   Reply With Quote
Old 02-16-2012, 08:04 AM   #1620
wwddww34's Avatar
Trader Rating: 9 (91%+)
Does anybody have a spare A700 chassis that they can sell?
wwddww34 is offline   Reply With Quote
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10911 11-28-2016 07:09 AM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
