SMC 4000/25C/3.7V single cell Hardcase pack.
#857
We looked into making a single cell saddle pack but due to the size limits it will not be possible to make such a pack as the capacity would be to low. They would also be more expensive as to make small cells using the stacking method would be very time consuming. To keep the cost down the cells would have to be done using the winding method but this would increase the IR.
Just a thought.
#858
I just got my set of battery and booster from lefthanderrc the smc 4000mah 3.7v and the TQ booster for my 1/12 scale car. I loved the speed and handling I am running a 13.5 hacker and a lrp spx esc I found that this is a good combo, the car run for ten min. and there was no problem with the servo , receiver or transponder.
#859
Quick question about the voltage boosters, from the sales pitch on the novak it says you can run the same esc, receiver and servo as you normally would with 2S/4-6cell. So does the booster increase the voltage the esc runs at or just the receiver and servo?
I know my esc runs fine at just over 4 volts but i tested it the other day with a pack that was at 3.8 volts and the light came on and went off again straight away but the servo still worked, i dont have a variable power supply to test the range accurately but if my esc is only working of the 1S lipo (4.2/4.3 when peaked) voltage i might be a bit short of making a full run. Comments, please
#860
Conrad,
When you run the speed control with the switch on and no booster or receiver pack, the speed control's "brain" runs at the voltage of the main battery.
When you run a booster or receiver pack, you leave the speed control switch OFF and the speed control gets its power from the receiver, so its brain runs at the voltage of the booster or receiver pack.
#861
Excellent, thanks trips. Ok i had to stand up and look like a Diddy in front of everyone but at least i learned something
#862
So what is being done for the t-plate cars it seens like that all the newer cars that are coming out. I would like to run lipo in them too.
#863
The LHS got some of the SMC single cell packs in yesterday, and sold them all within hours. The Novak Smart Boost is back-ordered as you all know.
I have a 12R5 with a Novak 4-cell GTB, Spektrum micro receiver, and Futaba 9665 servo.
Would it work to plug in the e-flite battery for the CX-2 into the battery slot of the receiver? Since the car is underweight anyway, this battery could be placed on top of the SMC pack. The e-flite pack has the right connector on it, and I have a balancing charger for it already.
http://www.amainhobbies.com/product_...oducts_id/9314
#864
#866
#867
Has anyone tried putting in a faster motor say 4.5 or 3.5? What kind of pinion/spur gearing and time can you get?
Cheers.
Cheers.
#868
has anyone tried the Muchmore Lipo charger, this one here from Stormer?
https://www.ssl-stormerhobbies.com/c...&pn=MCHMMCTXLI
Any good?
Any good?
#869
Part time.
You have a PM.
You have a PM.
#870
Dan,
Just ordered 6 packs from stormer. Can you let me know roughly how much run time will I get from the packs with a 4.5R motor?
Also I am currently running 21/100 gear for my 4.5 with 4 cell, what would be the new pinion/spur I should try with the 1cell lipo?
Cheers. Can't wait to get my hands on them.
