Warpspeed Demon and Demon 2
#196
Does anybody know if/what is the website for the track that holds the US indoor champs?
#198
Thanks I don't know, I hope.
#199
Trinityracinnut-you have a warp car??
#202
Thanks Stephen, Jason, and Vick!
I know you'll do fine Stephen!
I'm also going to a Tri-State race next weekend at http://tfbraceway.com
The track I raced at last weekend is found here
http://www.intenseraceway.com, but if you want the results you have to go here
http://www.knology.net/~roadracing (the Nov 11th 2003 results)
Vick did you get my motor clamp yet?
Ryan
Ryan
#204
MUFFIN MAN
Originally posted by R.Fenstermacher
Who is Muffin?
Who is Muffin?
#205
j/k bro
#206
Well ran the D1 for the first time yesterday at the First Coast Carpet Champs. I only had two practice runs, and qualified 3rd and took 2nd in the A-Main, Touring Stock.
This car is a must have for carpet racers!!!! Totally dialed, some observations, the car is very easy to drive smooth and fast, and can be pushed no problem, I think this car will really shine in the 19 turn / modified class. The car tracks straight as an arrow, w/ even steering balance left to right. The car didn't feel like a TC3, to me it felt like the handling of a belt drive car with the benefit of the TC3 drive train. Also, had a lot of interest in the car w/ some taking pics....lol
Well-done Victor!!!! This car is awesome!!!!
#207
Post your set up and a pic. Great job on the race! New car and everything. Wow. Well done yourself!
#208
My set-up:
FRONT
yellow springs
#3 piston
60w oil
standard tower on front
top shock mount hole out
VerII arms lower mount inside hole
camber link inside upper hole
ntc3 rack
AE 4 degree castor block
F-2 block
front sway bar (custom)
5mm ride hight
5.5mm droop
0 degree toe out
-1.5 degree neg camber
REAR
purple springs
#3 pistons
50w oil
top shock mount outer hole
VerII arms outside mount hole
camber inner upper hole on tower
rear hubs forward
AE rear hubs / camber outer hole
no sway bar
2-2 block w/ F block in place of R
4.5 mm droop
5mm ride hight
-1.5 neg degree camber
TRC Plaid Front 55mm
TRC Purple Rear 55mm
and the car was dialed!!!
I must give credit to Billy Spence from the Track in Gaithersburg, MD for set-up tips!!! Thanks!
Guys you will not be disappointed w/ this set-up!
PICS to follow
FRONT
yellow springs
#3 piston
60w oil
ntc3 rack
F-2 block
5mm ride hight
5.5mm droop
0 degree toe out
REAR
purple springs
#3 pistons
50w oil
rear hubs forward
no sway bar
4.5 mm droop
5mm ride hight
PICS to follow
#210
Hi,
what chassis is better for carpet??? the D1 or D2. at this time we are running a milled/nitro rack TC3 on foams in stock. the only thing different is I run the nitro rack mounted 180 degrees to the NTC3. (tuning towards the drivers likes).
any input would be helpfull.
