Warpspeed Demon and Demon 2
#1876
Tonight went a bit better I still traction rolled, but only once or twice I even went white/yellow and took a little droop out all around.
I ended up in 3rd overall but, I definatly should have had 1st or 2nd, next week should be alot better, gonna try harder tires, and maybe the sway bar
Overall though, this chassis rocks! I had the secon fastest lap time of the night again!
#1878
I have always gone softer to solve traction rolling. If you let the car itself roll, it has some "give" to it before it starts to reach the limit, or traction roll. Try your setup with yellow/purple...or even purple/copper to see what happens. Maybe just as simple as gluing the sidewalls or adding a swaybar to the front...maybe more camber or change the camber links to allow more camber gain throught the corner so the tire stays flatter. Also one other thing to consider is your driving style. That too can lead to traction rolling. Are you driving hard into the corner then cranking the wheel? Or are you driving swoopy and connecting each corner and flowing smoothly? Try taking some dual rate out of the radio...could be as simple as too much wheel travel causing the traction roll. Glad to hear the warp car is doing good for you
#1879
MUFFIN - thanks for the setup man Ill post results here after I get home tomorrow
#1880
Thanks for the tips guys! I did glue the sidewalls, but heres my setup as of right now
Front:
springs: white
Tires: 42 shore
Camber Link: inner upper
Rear shock tower
Shocks in middle hole on tower, outer on arms
60 wt. oil, w/#2
4* blocks
3mm spacer under ballstud
ride hieght 5.5
camber: 2
Droop: set to touch spring while in the air
Rear:
springs: yellow (tried purple too)
Tires: 37 shore
Camber link: inner upper
shocks in middle on tower, outer on arms
40 wt oil w/ #2
R+3+2 block
camber: 2
ride hieght 5mm
Droop: set same as front
Its pretty much the same as Ariels, but I didnt get a chance to get the F+3+0 blocks.
Also someone told me try the F block on the inside rear instead of the rear one? anyone ever tried this, he said its supposed to feel a bit more free in the rear end
Any help is greatly appreciated
Front:
springs: white
Tires: 42 shore
Rear shock tower
60 wt. oil, w/#2
4* blocks
ride hieght 5.5
camber: 2
Rear:
Tires: 37 shore
40 wt oil w/ #2
R+3+2 block
camber: 2
ride hieght 5mm
#1881
I ran the D1 today and it was on rails!! The car was awesome all day and I tq'd and won sportsman. The car was flawless, but I made a few mistakes during the race.
#1882
already a win w/ your d1 Im waiting for my Moment to arrive. I have already put it in the 3rd postition in Expert Stock.
#1883
last weekend i tq'd and won the stock foam class. this weekend i had to announce the race and missed out on a great 19t foam class. man was i bumed watching them.
#1884
Im mad Cause I haven't Race For almost 1month and a half..Because of no ride to the races, and Parents Suck at Transportation or Supporting me in r/c.
#1885
WARPSPEED RACING
Great Job to all you WARPSPEED drivers:
Lynn Munno (sorry if misspelled) Tq'd and Won WOW!!
Ariel.....3rd place good job!
Matt D.......Tq'd and Won EXCELLENT!!
#1886
Yea the Cars a Bullet On Carpet. I haven't Tryed it on asphalt because too scared I will mess up setup and won't be same again .
#1888
Ray
#1889
Originally posted by R/C Anonymous
my D1 is definately a rocket in mod. foam next year i should have a little something something for the A-Mainers
#1890
Originally posted by rayhuang
The D1 on carpet in Modified is a dream to drive. Its so fast-easy to drive and has amazing forward traction and launches straight-every time. That was with a 2.5 chassis and 3mm top deck. I bet a 3mm chassis would be even faster, but I never tried it.
Peace guys ans Happy Racing!
Our new track is almost done! Will post pictures soon!
