Another CRC 1/12 newbie with questions
Well I saw part of an answer to one of my questions in another thread but I wanted to see if someone could clarify it for me-
I have a CRC 3.2
1. I have a speed passion speed control (which has a fan on top) What are my options for actually making it fit with the body on? I read in the other thread probably not the best to remove it I have a brushless trininty 17.5 currently, but plan on running 13. soon
2. It has a 88 tooth spur gear what would be a good place to start as far as a pinion gear? I know it depends on batterries, track size ect but I just need a starting point.
3. I am new to brushless technology I see that the speed control has an "A" B' and C wires for the motor, the motor that came with it was marked also but my trinity isnt so is it always the same order on all the brushless motors?
IN advance thank you for the information!!!!
I have a CRC 3.2
t
obviously alto to consider when gearing, but with a 88 spur you pretty much want to put as big of a pinion as you can fit. Most people are running a a 76 spur, and depending on track sizer gear from 47-53 for pinion. i dont think you will get the speedo to fit with the fan. i would just take it off. No need for it with a 17.5 and prob no nned for it with a 13.5 either. And all brushless motors, or al the ones i have seen are the same wire order. A b c, front front to back . if in a 12th scale.
Welcome to the 1/12th world. Theres really no reason to run a fan with 1/12th cars. You should even be able to grind the heat sink a bit. Have a look at the Novak 4 cell speedo or the LRP offering if your still worried about heat.
For a gear try to find a 78 spur. Makes gearing a little easyer.
Ok, I will take the fan off and see make sure the temp stays low. I am planning on running up at Timezone 2 and Rc plus here in the northwest.
As far as the spur I think I have spares and will try and find a 76, would I still be in the 20's (pinion) for that size spur?
Thank you so much for the help, i used to run 1/8 scale 10 years ago so I know the basics but the technology now is so crazy I've never seen so many options for a speed control it used to be good better best LOL.... Sheesh and Im only 27 years old and Im lost already!
no
your pinion will be around 50
I have a CRC 3.2
I have a CRC 3.2
