LRP Vector x12 Brushless Motors
#573
I need help!!
The other day I had the lower bearing blow apart on me during a race and now I can't get the outer race out of the can. What do you guys use to get them out when a bearing blows apart?
#575
Which way do the timing inserts go in ? Dots facing out ? if so do they go on top or on the bottom ? Or does it even matter .
#576
This U Tube video will give you visual indication on which way the inserts go and how it affects timing -
http://www.youtube.com/watch?v=ykFwX...F1On0B3wVtu9W3
(approx. 1 min. 10sec into the video).
#577
#578
dear burito, i'm having problem with Failed Motor bearings exploded and sprayed through motor destroying rotor and windings due to lack maintain from me, i need the part number for the inner bearing, so that i can get it from my local distributor for me to do the replacement, anyway, do you have any idea on how to maintain a lrp motor as well? hope to hear from you as soon as possible, thanks.
B.R.
Andrew
B.R.
Andrew
#579
Works Team Tools, Motor Bearing Replacer
Anyone try this tool for bearing replacement?
#580
what's safe to spray inside the entire motor? obviously the sensor board can't, but what is safe to spray with motor cleaner? blasting any part with compressed air isn't going to do the best job in taking the dirt away.
#583
General question
Hello all, I have a question about the motor turns.
I will be racing modified outdoor on rubber tires in the summer with a tamiya 417 on a 100+ foot track and I was wondering if getting a 2.5 or 3.5 is a mistake because all I see is people running 4.0t. or 4.5t
This will be for club racing so the competition is not intense and my goal is to focus/enjoy/learn to drive the most powerful car on the track. So if the 2.5 acutally works I would go for it.
However, if the lexan bodies could collapse under the windpressure or the car lifts up or the tires spin/drift because the torque is too high or the engine overheats because of the extra breaking I would like to know before purchasing a very low turn engine.
Has anyone had issues with low wind motors?
Or if anyone has raced with a 2.5t and has some pointers that would be much appreciated.
#584
Under 4.5 turns it s totaly useless. If you want more topspeed just set your ESC
#585
Trader Rating: 102 (100%+)
way too much power
2.5 is way too much power..
you will probably be spinning tires..and going thru them pretty quick..
not to mention drive train parts lifespan will decrease rather quick.
that may not be much fun...especially on the wallet.
try a 8.5 thru 10.5.
if the track is more technical...it will do just fine. ...if it's a drag strip type of track...(aka 2 straights + 2 turn) then lower winds would work.
Remember it's about having fun.
