LRP Vector x12 Brushless Motors
#542
I have a few questions for a friend of mine. He purchased a new LRX SSX stock spec v.2 and a Vector X-12 17.5 motor combo for running in our 17.5 TC carpet class. he has the car geared with a rollout of 4.0 the chassis is an Associated TC4.
the car ran fine in the first couple of qualifiers, but was getting really hot. in the 240° range. I'm running the same rollout but don't see anywhere near that temperature I'm more in the 170-180° range with my TC6.
there isn't anything binding as we checked it without having the motor installed and everything was running free and smooth.
so here is what is happening. when sitting on the bench the car will power and accelerate. but when you set the car down it will cutout when you accelerate to full power, then nothing. He thinks maybe he smoked the motor, but I have read that these X-12 motor are pretty heat resistant. I know his was on the hot side, but would it cause they symptoms that he has?
could it be a problem with the ESC? Motor Rotor? or possibly a problem with the sensors in the motor?
also any idea why it would be so much hotter while running the same rollout as other cars?
thanks in advance for your help.
#543
Definitely sounds like a sensor problem. Check the connections of the wire, and try a different wire. Ive also had one sensor go bad in the motor. Double check all the solder connections to the power wires, running that hot could expose a bad connection.
As for why it runs hotter, there could be a few factors. Im assuming the motor timing is the same on the 2 motors. The first thing that comes to mind is airflow. The motor is more tucked in and hidden if you will on a TC4 vs the 6, and doesnt see as much airflow. The other thing it could be is its just that motor. A great example is the Sonic's in my and my friends TC6's. Im at a 3.76 w/ 40* of timing, and I run around 160-170. He has to run a 4.0 and 30* to get the same temps. Motor to motor, motors are still different.
#544
#546
I cant speak for absolutely every instance, but I ran an LRP X12 13.5 on one cell with a Novak ESC for a few months (not by choice, I had to send the LRP back as it quit one day) and during that time we went from running boosted 1/12 scale to blinky 1/12 scale. Once I got my Stock Spec V2 back from LRP and set to Blinky mode with no boost or torque-feel, the car had a noticeable surge about halfway down the back straight compared to the Novak setup. Why? Ask LRP, but it was there I guarantee it.
#547
I search a feedback about 12.0 mm rotor. I m trying to have a smoother 4.5 octa.
But i don't know if 0.5 mm make a big difference
#550
Ok thanks,
I would to know if it s a big or a little improvement
#552
Ok thanks, i just want a smoother motor
#554
Ddrs 3 with - 100 throttle expo on my radio
Boost 0
Turbo between 30-40
Turbo slop 3°/0.1s or 6°/0.1 s, i m trying some different turbo setting
Turbo delay 0.1 sec.
On this videos i ve the turbo set at 40 ° with turbo slop 6°/0.1 sec
http://www.youtube.com/watch?v=i6xz_zWrXeg
I don't say that the x12 isn't smooth, i just want to reduce some torque
