Old 09-29-2003, 02:52 AM   #1
Default Need Help with Specialty GEARING
Dont know where in the forum this would belong so I will take a shot here
Here goes
What do I do if a company such as robinson racing doesnt care the gears I would need to get a certain ratio?
is there any alterantive?
I would need something insane like a 145 spur and an 11 pinion
either way you cut it I need a a gear ratio above 13
the setup is simple 1.1 gear box
But I need to run 5.5" tires
any help would be greatly apreciated
seriousre is offline   Reply With Quote
Old 09-29-2003, 03:28 AM   #2
well so far what I have come up with is that a 1/24 scale slot car also uses a motor with a 1/8" output shaft much like a 1/10 scale 540 motor
1/24 scale slot cars run pinions all the way down to 7 tooth with a 64 pitch
This means I could run a 125 spur from robinson and a 9 tooth pinion which would give me 13.889 gear ratio
I hope thats a good ratio for my application because by the looks of the pinion I would have to jb weld it on the motor shaft
here is a link to the pinions, says there 1/8" shaft
Old 09-29-2003, 08:59 PM   #3
Check with Stock Drive Products, York, or Berg. These are all industrial component manufacturers. They have huge inventories of just about any spur/pinion/belt you could imagine. And if you ask for a sample you might get the stuff for free. You could also request catalogs if you think you could be nededing this kind of stuff frequently.-Jeff
Jay Dub is offline   Reply With Quote
Old 09-29-2003, 09:16 PM   #4
Randy Caster's Avatar
Trader Rating: 45 (100%+)
You're a little mistaken on the slotcar gears. The 1/8" axle gears aren't pinion gears, that's the spur gear. The pinion gear has around a 1/16" hole for the shaft.
TC5 Gearing revrace Electric On-Road 2 04-27-2008 05:56 PM
Extra Cash: RC Specialty Business for sale robracer R/C Items: For Sale/Trade 0 11-22-2007 08:14 AM
MF II gearing? chasot Electric Off-Road 5 10-30-2007 11:25 PM
Gearing for an Evo IV HYPA Electric On-Road 8 11-09-2005 10:07 AM
gearing LancerEVO Electric On-Road 9 07-13-2004 05:50 PM
SEO by vBSEO 3.5.0
