XRAY T2’009
#721
Even Losi and Associated current models are metric?? Slovakia sure ain't going to use standard......unless they figure out how to optimize it .....besides mine fits metric allens just fine
#723
Because it is the standard in US made things. However I am a big fan of the metric system and prefer it over the IMPERIAL system.
#725
#731
Is Anybody using this for lipos in their 009?
http://www.nexusracing.com/product_i...f5080dfc94d208
I am having a hard time picturing how you would mount your lipo... what keeps them from flying out of the car? My 009 didnt come with any way to mount a battery pack into the car.... I do have tape though.
#732
The Evicerator
I have been using similar plates in my car for quite a while now...
What I do is I servo tape the battery (with even more tungsten ballast) to the tray itself... Then I use strapping tape to secure the whole assembly into the car.
#734
One thing to do to these plates is to grind a little of the tray away where it meets the tape slot in the chassis. Once you get a tray, put it on the chassis with no battery, and try sliding it front to back. You will be able to see how the tray edge could cut through the battery tape, so grind a little bit of the tray, and try it again, etc. This way, if you hit something, the tray won't cut the tape, causing the whole thing to be ejected from the car at the next turn.
