XRAY T2’009
#2641
Super Moderator
Anyone know 64p spur and pinion I should order? Been running 5.5 48p temps at 130 with fan. So I figured I'd try 6.0 for starters, 17.5 boosted. I can figure the numbers but, I mainly ask because I'm not sure what would fit. Also I have 20/38 pulleys so I'm at 1.9 internally.
#2643
#2644
Do any of the belts avialable from Xray allow the use of 38t pulleys with the 20t layshaft pulley without using the forward motor conversion?
#2646
#2648
Just checked the XRay parts lists for T3 2010, 2011, and 2012. The part numbers listed above are standard for all T3's.
#2651
I had thought I was gonna be able to do the 38T conversion with the stock belts just by using the tension adjustment on the eccentrics. Boy was I wrong.
I wanted to keep the 38t pulleys etc. as it means I can use the Spec-R geardiff I had going spare.
So if you are going to use 38t pulleys with 20t layshaft pulley;
The belts you need are the standard items from the T3 series.
Front 305432 - 513mm
Rear 305446 - 189mm
They're the ones right up to the current T3'12
#2652
Already there have been many outdoor races here in sunny Southern California that were spoiled by rain. However, it doesn't stop people from racing in their real cars on the freeway in the rain and unlike our RC cars, many of them aren't even 4wd. Add texting to the mix and you can see what a show our freeways can be in the rain.
