XRAY T2’009
#2251
#2252
Upgrades: Aluminum steering knuckles, C-hubs, rear hubs. Aluminum spool outdrives and ECS driveshafts (assuming rubber tire). Optional shock springs and rollbars. Parma hard foam bumper. If you get the hard foam bumper, that cuts down on a lot of breakage. The aluminum hubs and knuckles reduces the parts breakage to front and rear arms.
#2253
Thanks guys,
Well that's a lot of spare parts !
Imma follow your advices and get those.
Already got one ecs driveshaft as spare with the car, those are expensives !
So i was wondering how is it that usefull ?
Thanks again for the infos .
#2255
ok just got one. what are some tips for the build?
thanks,
Hayden
thanks,
Hayden
#2256
Take your time and read over the manual multiple times before you start the build!!!!
#2257
Just got my multi diff today. Am I suppossed to be using the drive shaft blades with it?? I ask because when I put the blades on they bind in the cup as soon as I attach the camber link. Without them on there is a tremendous amount of play and I would be worried about chewing up the cups. Any answers??
Thanks in advance
Davin
Thanks in advance
Davin
#2258
Thanks,
Hayden
#2259
shaggy11: i wouldnt use wd40 on the belts.. it will cause the belts to strech if you are using a low turn motor or even 13.5 these days.
Davin: yes you have to use bone blades with the multidiff if you dont it will chew the out drives up
#2260
Thanks in advance
Davin
Thanks in advance
Davin
#2261
hi , will the t3 front hub carriers work on the t2009 if they do will they b better then the standed ones ?
thanks
thanks
#2262
hey Im having trouble with my 009 belts wearing out quickly the belts not hitting anything.......anything I can do to stop them from wearing so fast o there as tight as they go ad still wearing out
#2265
they shouldn't be tight at all. loosen them off so they have some movement. mine are 6 months old and they look like new still, and that is with a 10.5
