XRAY T2’009
Old 09-17-2009, 07:57 AM
  #1756
For the T2R, the internal ratio is 1.7. I already use 78/48 spur with 28T pinion. This is the smallest spur I can found and largest pinion for the motor position. it is still not top speed enough for my 11.5 motor. What is the solution? thanks
ioxqq is offline
Old 09-17-2009, 10:12 AM
  #1757
cyanyde's Avatar
Are you sure thats the largest pinion? Anyway, with that ratio now its already pushing it a little with the 11.5T. If you wanna go faster get a hotter motor.
cyanyde is offline
Old 09-17-2009, 10:35 AM
  #1758
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
I agree, I don't have my 13.5 geared that high and I am also using the 78 tooth spur.
IIGQ4U is offline
Old 09-17-2009, 12:15 PM
  #1759
cyanyde: Yes. I am using ratio final drive ratio 4.7 and sure I can't go with bigger pinion as the motor is already to the front most. I want to use 4.5. I'm wondering how does people gearing with 13.5
the motor 11.5 i use is not stock spec
ioxqq is offline
Old 09-17-2009, 01:02 PM
  #1760
Trader Rating: 72 (100%+)
Need to kmow what esc, motor and battery you are using. What is the track size, and what is your motor temp after 5 minutes with that gearing?
patrick is offline
Old 09-17-2009, 01:54 PM
  #1761
Originally Posted by Skiddins
What do the team guys do with regard to building a good diff?
Particularly what they do with the thrust race when rebuilding, I have rebuilt other manufactures diff's and managed to get them very smooth and free but I'm really struggling with Xray's.
I can sand the diff plates easily and get a nice finish...but what else?
Skiddins
I found that if you use Losi Brown diff grease on the thrust it is smoother and holds up longer in between builds. For the diff balls I use associated Silicone diff lube not the stealth. Mike Blackstock told me it holds up better than the stealth lube.
kobiwan is offline
Old 09-17-2009, 02:30 PM
  #1762
vazzo's Avatar
Trader Rating: 101 (100%+)
I use the AE Black Grease on thrust and Schumacher Diff Lube.
vazzo is offline
Old 09-17-2009, 05:13 PM
  #1763
FK05 lover's Avatar
Trader Rating: 147 (99%+)
You can run almost any size RW 48p spur on 08/09 series, I use 72T
All you have to do is make a 1mm spacer (out of plastic) to replace the 1.5mm spacer (black 3 leaf clover type) that sits below spur pulley on the "spur side" of the layshaft... been using this since 08's came on the seen & can get any ratio/rollout I like..
FK05 lover is offline
Old 09-17-2009, 06:33 PM
  #1764
Skiddins
Try sanding the thrust washer plates as well as the diff rings, the TW plates seem to be made out of hardened cheese, and not only develop a score line where the balls run, but also seem to develop large divots.
I also tried something out of the Photon, and stacked the cone washers inside each other, this makes diff adjustment a lot more sensitive, but it also gives a lot more drive out of the diff while maintaining a free diff action.
Black AE grease on the Thrust, and AE Silicone grease on the balls and plates, the tube with the red writing, not the black writing stealth grease
Besercoe is offline
Old 09-18-2009, 05:21 AM
  #1765
LOSI123's Avatar
Trader Rating: 63 (100%+)
Can anyone help point me in the right direction to buy 395016XXL Blue xray t-shirt, I cant find anywhere online that has them that has stock or can ship to Australia.
LOSI123 is offline
Old 09-18-2009, 06:39 AM
  #1766
If you google '395016 xray' you'll find a few stores that have them in stock.
patrick is offline
Old 09-18-2009, 10:16 AM
  #1767
Regional Moderator
CarbonJoe's Avatar
Do the ECS driveshafts fit with the aluminum C hubs? In other words, are the aluminum C hubs considered "V2" or "V1"? The Xray web site has no indication either way, and they are only pictured from the side 3/4 view, so it is impossible to tell if they are big enough to fit the ECS driveshafts through.
CarbonJoe is offline
Old 09-18-2009, 10:30 AM
  #1768
The Evicerator
For those of you who are curious the 38/20 pulley conversion kit to run the 1.9 drive ratio runs very well ... ran it all last week at IIC.
I think it smooths out the on power to off power/vice versa transition handling of the car considerably.
A definate nice thing to have when throttle control is a must!
Steve Weiss is offline
Old 09-18-2009, 10:53 AM
  #1769
yokemad's Avatar
also which pin is the best for ecs driveshafts there are two different type v2 and one with flat spot ?
I 've already break two pins comes with drive shafts using top racing pins no problem so far but one of the driveshaft case pin hole has worned badly I thought that might be because of a little longer top pin...
cheers
yokemad is offline
Old 09-18-2009, 10:59 AM
  #1770
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by jubilee
Thanks, that's what I thought.
Rumours are abound, no doubt. I'm ready for a new tc, like yesterday!
But forcing myself to play the waiting game...probably thru November. If they shipped a "new" tc, even with the only changes being a different color and included ECS driveshafts I'd kick myself!
But if they DID include the ECS driveshafts in an 010, the kit would probably me $100 more than the 09. It would however be more "optimised"
Cpt.America is offline
